Topic: virtual wire (Read 2018 times) previous topic - next topic
francisroan
Apr 06, 2012, 08:49 am Last Edit: Apr 06, 2012, 04:14 pm by CrossRoads Reason: 1
guys could u help me???
im having a problem with virtual wire.!!
this is the code the first time i used it the led was lighting up constant when i press the button on the transmitter but now after a few months the led is blinking instead of lighting up constant (this is the receiver code)
Code: [Select]
#include <SoftwareServo.h>
#include <VirtualWire.h>
SoftwareServo servo1;
 Serial.begin(9600); // Debugging only
   Serial.println("setup");
 servo1.attach(9);
 vw_set_ptt_inverted(true); // Required for DR3100
   vw_setup(2000); // Bits per sec
   vw_set_rx_pin(2);
   vw_rx_start();       // Start the receiver PLL running
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(13, OUTPUT);
pinMode(1, OUTPUT);
 digitalWrite(3, LOW);
  digitalWrite(4, LOW);
  digitalWrite(5, LOW);
  digitalWrite(1, HIGH);
 servo1.write(71);
 SoftwareServo::refresh();
uint8_t buf[VW_MAX_MESSAGE_LEN];
   uint8_t buflen = VW_MAX_MESSAGE_LEN;
   if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
       digitalWrite(13, true); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
   Serial.print(buf[i]);
       if(buf[i] == '1'){digitalWrite(3, HIGH);}//fwd
       if(buf[i] == '2'){digitalWrite(4, HIGH);}//bck
       if(buf[i] == '5'){digitalWrite(5, HIGH);}//lit
       if(buf[i] == '3')//lft
 servo1.write(0);
if(buf[i] == '4')//rht
  servo1.write(150);
 Serial.println("");
  digitalWrite(13, false);
i  remodeled this code from sparkfuns example code!!!
this is the transmitter code(which is working properly)
Code: [Select]
//transmitter
   // Initialise the IO and ISR
       vw_set_tx_pin(3);
       pinMode(7, INPUT);
       pinMode(8, INPUT);
       pinMode(9, INPUT);
       pinMode(10, INPUT);
       pinMode(11, INPUT);
       pinMode(12, OUTPUT);
digitalWrite(7, HIGH);//fwr
digitalWrite(8, HIGH);//bkwr
digitalWrite(9, HIGH);//lft
digitalWrite(10, HIGH);//rht
digitalWrite(11, HIGH);//lit
digitalWrite(12, HIGH);//pwr
 char *msg;
 if(digitalRead(7) == LOW){
   char *msg = "1";
     digitalWrite(13, true); // Flash a light to show transmitting
   vw_send((uint8_t *)msg, strlen(msg));
   vw_wait_tx(); // Wait until the whole message is gone
   digitalWrite(13, false);}
 if(digitalRead(8) == LOW){
   char *msg = "2";
 if(digitalRead(9) == LOW){
   char *msg = "3";
 if(digitalRead(10) == LOW){
   char *msg = "4";
 if(digitalRead(11) == LOW){
   char *msg = "5";
 pls help!
Moderator edit: [code] [/code] tags added.
PaulS
Quote
Would that be the LED on pin 3, 4, 5, 13, or 1?
Why are you diddling with pin 1 AND using Serial at the same time?
What are you doing on the sender? What do your Serial.print()s show you?
How are the LEDs connected? Are there resistors, too?
How are the Arduinos powered? Via USB? How is the servo powered?
Nowhere near enough detail to help you.
PS. Before posting code again, use Tools + Auto Format. That code is a mess. Also, use the # icon when posting code, so the moderators don't have to, making one block of code where there should be two.
CrossRoads
Yes, which LED(s)?
It would seem the Tx/Rx LED would only be on continuously if you pressing a button continuously.
francisroan
hey guys now i fixed half the problem by changing the pins for the pwr to the rx module now the led is flickering (both tx and pin 11)
CrossRoads
Being miswired always tends to complicate things ;)
Are you using RF module with PTT pins?
If not, take this line out of both codes
