Topic: Serial.write() on Leonard is diffrent from Uno and others (Read 8837 times) previous topic - next topic
mnoriaki
I found that following two statements can be compiled for Uno and Duemilanove (probably for all mega168 and 328s) but not for Leonard with Arduino-IDE 1.0.1.
Serial.write("test");
Serial.write((const uint8_t*)"test\n", 5);
Is this a bug or the feature?
// Noriaki Mitsunaga
nickgammon
Edit USBAPI.h.
Find the class: Serial_
Add this line:
Code: [Select]
  using Print::write; // pull in write(str) and write(buf, size) from Print
Now it compiles without errors.
eg.
Code: [Select]
// Serial over CDC (Serial1 is the physical port)
class Serial_ : public Stream
private:
ring_buffer *_cdc_rx_buffer;
public:
void begin(uint16_t baud_count);
void end(void);
virtual int available(void);
virtual void accept(void);
virtual int peek(void);
virtual int read(void);
virtual void flush(void);
virtual size_t write(uint8_t);
        using Print::write; // pull in write(str) and write(buf, size) from Print    <-------- add this
operator bool();
extern Serial_ Serial;
Sounds like a bug, who knows?
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
mnoriaki
After adding  "using Print::write;" to USBAPI.h works fine.
Thank you.
Maybe fixed in future release ?
