Topic: Driiving external motor and heater IRLZ44N Mosfet (Read 10579 times) previous topic - next topic
joe10
Hi Everyone,
I have a small 12v 10amp heater and a small 12v 600mA motor that I would like to drive from the Arduino. I have the external power supply that can provide the required volts and amps. I just want to clarify a few points around the MOSFETs.
I have some IRLZ44Ns laying around that I would like to use.
http://www.irf.com/product-info/datasheets/data/irlz44n.pdf
Can I just put a 1k or 2.2K resistor between Arduino pin and the MOSFET and call it good, or do I also need a diode in this circuit to prevent the current from flowing back.
Since the heater uses 10amps can I still use the traditional 1N4001 diode? Using a setup like they show here:
http://www.arduino.cc/playground/uploads/Main/relays.pdf
Thanks for  the help.
Joe
retrolefty
#1
Dec 31, 2008, 04:55 am Last Edit: Dec 31, 2008, 04:59 am by retrolefty Reason: 1
Joe;
That MOSFET is a winner device for allowing the Arduino to control lots of high power devices. Just be sure to heat sink the MOSFET if passing more then just a couple of amps. Turns out the the heat dissipation rating tends to be the limiting factor, rather then volts or amps rating, in keeping the device in it's SOA, safe operating area.
Actually a series resistor is not required between the Arduino output pin and the MOSFET gate and a higher ohm series resistor will act to actually slow down the turn-on and turn-off times as the MOSTFET gate acts like a capacitor and should be driven with as much current drive as possible during the switching transitions. The key to these power MOSFET devices is to insure they switch on and off quickly as the more time spend in the transition region adds significantly to the heat dissipation problem.
Once the MOSFET is fully on or off the gate draws no DC current at all. That aside it's always a good practice to have a smallish series resistor on all Arduion I/O pins but for other reasons, and a 330 ohm series resistor is more then enough to protect an output pin. A 1K or 2K resistor is a good value for a series protection diode for an input pin.
No series protection diode is needed for the output pin and in fact would interfere with the proper turning on or off of the MOSFET gate. What you might consider as a safety precaution is to wire a pull down resistor at the MOSFET gate to ground, say 2K ohms or so. If the arduino was to be powered off, but the 12vdc was still on there is a tendency for the gate of the MOSTFET to 'float' and cause the device to turn on slightly, but a pull down resistor will insure it remains off if gate drive signal is lost.
As far as the a diode connected in reverse bias across a load, it is not be needed for driving a resistive load like a heater or large lamp, as they are non-inductive loads. When turning off an inductive load like a motor or a solenoid, the magnetic field collapses and cause a very short reverse voltage spike that can approach X4 negitive the normal applied positive voltage. That is where a diode wired across the inductive load can help by allowing the spike to just circulate between the coil and the diode and dissipate the spike current thus protecting the switching device.
The spike is very short so a 1 amp diode should be able to handle the spike current OK and the 1N400X series is a pretty popular choice in the past, although the newer Schottky diodes have faster switching times and are more often used these days even if they costs more then the 1N400X series diodes.
Note the most power MOSFET have built in protection diodes but it never hurts to have an external diode installed right at the motor or solenoid terminals as it helps limit the electrical noise and spike that can otherwise radiate and bounce the power and ground wiring.
Lefty
halley
#2
Dec 31, 2008, 05:37 am Last Edit: Dec 31, 2008, 05:39 am by halley Reason: 1
I'm a visual guy, and a complete noob at MOSFETS or otherwise, but it sounds like you're describing and advocating this circuit for an inductive load (say, solenoid), right retrolefty?  The inductive load is the unmarked rectangle next to the diode.
I'm taking VDD as being the logic level power supply (say, 3.3V or 5V from the Arduino regulator), and VMM as being the motor level power supply (say, 12VDC).  The signal is a logic HIGH or LOW, such as straight from an Arduino digital output.
retrolefty
joe10
Thanks for the information Lefty this is exactly what I needed to know.
Halley thanks for the visual that helps me double check the circuit I am building.
Joe
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
