Topic: Temperature Sensor (Read 4382 times) previous topic - next topic
map7
I want to be able to monitor Temperature and Humidity using the Arduino board.  Can anyone suggest a Temperature sensor which will work nicely?
or do I have to create a circuit to monitor temperature and pass the output to the Arduino board?
If I have to create a circuit can anyone suggest any beginner style temperature circuits?
MikMo
Sparkfun has a combination humidity / temp. sensor.
http://www.sparkfun.com/commerce/product_info.php?products_id=8257
A little pricy at 42$, but the advantage is that it is fully calibrated, something that can be difficult to do yourself.
Or you can just google "Arduino temperature sensor" = lots of info
thefatmoop
check the playground and see there's a few guides on thermresistors
Anachrocomputer
The word you should look for is "thermistor".  Or, you could go for a digital version and get a DS18S20 temperature sensor that connects with I2C (the "wire" library): http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230763968
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
