Topic: Adafruit bootloader, boards.txt problems (Read 5466 times) previous topic - next topic
gsila
Hello guys
I recently upgradet my arduino IDE to 1.0.1. and i can't get IDE to work properly. I have arduino Nano with adafruit bootloader and i always get this error.
Code: [Select]
In file included from sketch_aug24a.cpp:3:
C:\Users\Grega\Desktop\arduino-1.0.1\hardware\arduino\cores\arduino/Arduino.h:213:26: error: pins_arduino.h: No such file or directory
This is what i added to Boards.TXT
Code: [Select]
atmega328ADA.name=Arduino Duemilanove or Nano ATmega328 w/Adafruit bootloader
atmega328ADA.upload.protocol=stk500
atmega328ADA.upload.maximum_size=30720
atmega328ADA.upload.speed=19200
atmega328ADA.bootloader.low_fuses=0xFF
atmega328ADA.bootloader.high_fuses=0xDA
atmega328ADA.bootloader.extended_fuses=0x05
atmega328ADA.bootloader.path=atmega
atmega328ADA.bootloader.file=ATmegaBOOT_xx8_adaboot328.hex
atmega328ADA.bootloader.unlock_bits=0x3F
atmega328ADA.bootloader.lock_bits=0x0F
atmega328ADA.build.mcu=atmega328p
atmega328ADA.build.f_cpu=16000000L
atmega328ADA.build.core=arduino
I copied all files from adafruit zip to bootloaders directory
does anyone know what im doing wrong ?
kaor
Same problem here.
The boards.txt file has been taken from here
http://arduino.cc/en/Tutorial/ArduinoToBreadboard
Copyed pins_ardino.h file from \Arduino\arduino-1.0.1\hardware\arduino\variants\standard to D:\Arduino\arduino-1.0.1\hardware\arduino\cores\arduino and problem has gone.
But I think Arduino team should patch this anyway.
dxw00d
You think the Arduino team should provide a patch for a third party's bootloader? Isn't that up to the third party?
kaor
Is this third party?
dxw00d
Sorry, no, that one isn't. I thought you were referring to the OP's Adafruit bootloader.
kaor
As I see Adafruit's bootloader file is the same.
Problem isn't in bootloader, problem is in Arduino.h file, there is statement
Code: [Select]
#include "pins_arduino.h"
that instructs compiler to load the library from local folder, but there is no such file in the same folder.
vicpino
The breadboard.zip file from the tutorial in http://arduino.cc/en/Tutorial/ArduinoToBreadboard contains only the file boards.txt in the subfolder breadboard.
This file is missing a line at the end to indicate the board variant:
Code: [Select]
atmega328bb.build.variant=standard
The subfolder must also contain the standard variant with the corresponding pins_arduino.h file.
So, follow the instructions in the tutorial to open your sketchbook folder and create the subfolder \hardware\breadboard\ containing the file boards.txt.
Then edit the file boards.txt to add the missing line.
Then create a subfolder \variants\standard\, and copy the file pins_arduino.h from the folder hardware\arduino\variants\standard\ in your Arduino IDE installation.
In Ubuntu 12.10 this is \usr\share\arduino\ when the Arduino IDE is installed using the Ubuntu Software Center.
This will make the compilation work also for gnoduido.
