Topic: Display time (Read 27373 times) previous topic - next topic
roli
Feb 17, 2009, 08:00 pm Last Edit: Feb 17, 2009, 08:02 pm by roli Reason: 1
So I am trying to find a way to display the time on a LCD screen. Probably I can't know what time is it without using some sort of external hardware? So what is the easyest way to get time display on arduino?
mem
Probably the easiest way to manage dates and times without external hardware is to use the DateTime library here: http://www.arduino.cc/playground/Code/DateTime
You will need a way to set the clock,  the example code uses the serial port to get time from a PC, but you can also set the time using buttons.  I recently saw a very clever clock that used tilt sensors for setting the time: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1233339782/4
Driving a typical text LCD with output from the library is simple,  in the example sketch, change the calls from Serial.print to calls to print to the LCD
roli
Thank you!
Now I just need to figure out how to set time at the time of uploading the sketch to the arduino. I don't need serial communication and/or buttons. And I only need hours and minutes. So any hint about that? I don't know how to set the time and then display it.
mem
#3
Feb 17, 2009, 09:46 pm Last Edit: Feb 17, 2009, 09:47 pm by mem Reason: 1
Here is a simple sketch that displays the hour/minute/seconds on an lcd. It uses the LiquidCrystal library that is distributed with the arduino and I suggest you get the LCD example 'hello world' sketch going first and when you have something displaying on the lcd you can try this sketch to display a digital clock.
Have fun!
Code: [Select]
#include <LiquidCrystal.h>
#include <DateTime.h>
// simple sketch to display a digital clock on an LCD
// see the LiquidCrystal documentation for more info on this
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
void setup(){
 DateTime.sync(1230768000); // set jan 1 2009 as the default time
void  loop(){
 if(DateTime.available()) {
   unsigned long prevtime = DateTime.now();
   while( prevtime == DateTime.now() )  // wait for the second to rollover
   DateTime.available(); //refresh the Date and time properties
   digitalClockDisplay( );   // update digital clock
void printDigits(byte digits){
 // utility function for digital clock display: prints preceding colon and leading 0
 lcd.print(":");
 if(digits < 10)
   lcd.print('0');
 lcd.print(digits,DEC);
void digitalClockDisplay(){
 lcd.home();
 // digital clock display of current time
 lcd.print(DateTime.Hour,DEC);
 printDigits(DateTime.Minute);
 printDigits(DateTime.Second);
I have not run this sketch so let me know how you get on
roli
I figured it out a few minutes ago myself. But thanks for this! Now just to integrate this into my other functions. It is a little strange that after using this the other parts of my program are running slower.
mem
#5
Feb 17, 2009, 10:50 pm Last Edit: Feb 17, 2009, 10:51 pm by mem Reason: 1
The example sketch I posted above wastes a lot of time doing nothing !
as long as you call the following functions in your loop when you want the time updated you should be fine:
roli
So this part:
Needs to be in the home screen function?  Or can I call this only when I need to display the time?  Because I am using functions and the home screen (where the time is) gets called when the user selects it. So does this have to be in the loop or can it be in the home function? And I am using my own formatting to display the time so I don't need digitalClockDisplay.
mem
#7
Feb 17, 2009, 11:54 pm Last Edit: Feb 17, 2009, 11:56 pm by mem Reason: 1
You only need to call DateTime.available just before you display the time.
The purpose of that function is to update the internal time counter and take a snapshot of the time properties so that subsequent calls to get the time properties will be up to date and consistent .
roli
Great! Working like it should now!
mem
Good to hear you have it going. Please post more about your project when you have it finished
roli
I will!
Just another question. If I need someday to set the time using buttons, I can use something like this?
    DateTime.sync(DateTime.makeTime(0, 40, 10, 18, 2, 2009));
mem
#11
Feb 18, 2009, 11:00 am Last Edit: Feb 18, 2009, 11:00 am by mem Reason: 1
Quote
Yep, thats how you can do it  ;)
Have fun!
roli
#12
Feb 18, 2009, 02:15 pm Last Edit: Feb 18, 2009, 02:25 pm by roli Reason: 1
Great! I just added the ability to set the time when arduino starts. For that I am using a potenciometer.
If anyone is interested - here is the code for function that sets time:
Code: [Select]
void nastaviuro()
 char buffer[2]; //this is a buffer for printing on a screen
 lcd.clear(); //clear the display
 lcd.printIn("Sekunde: "); //Print Sekunde -> Seconds: in english
 int sekunde1 = vnos_stevila(); //get a first digit of seconds and store it in variable sekunde1
 lcd.cursorTo(2,0); //Move a cursor to second row, first column
 itoa(sekunde1,buffer,10); //Convert integer sekunde1 to char and store it in the buffer
 lcd.printIn(buffer); //Print the buffer
 int sekunde2 = vnos_stevila(); //get the second digit of seconds and store it in variable sekunde2
 itoa(sekunde2,buffer,10);
 lcd.cursorTo(1,0);
 lcd.printIn("               "); //Clear the first line of the screen
 lcd.cursorTo(1,0);
 lcd.printIn("Minute: "); //Print Minute -> Minutes in english
 lcd.cursorTo(2,1);
 lcd.printIn(":");
 int minute1 = vnos_stevila();
 itoa(minute1,buffer,10);
 lcd.cursorTo(2,3);
 int minute2 = vnos_stevila();
 itoa(minute2,buffer,10);
 lcd.cursorTo(2,4);
 lcd.printIn(":");
 lcd.cursorTo(1,0);
 lcd.printIn("               ");
 lcd.cursorTo(1,0);
 lcd.printIn("Ure: "); //Print ure -> Hours in english
 int ure1 = vnos_stevila();
 itoa(ure1,buffer,10);
 lcd.cursorTo(2,6);
 int ure2 = vnos_stevila();
 itoa(ure2,buffer,10);
 lcd.cursorTo(2,7);
 delay(3000); // Wait 3 seconds
 lcd.clear();
 lcd.printIn("Dan:"); //Print dan <- Day in english
 int dan1 = vnos_stevila();
 itoa(dan1,buffer,10);
 lcd.cursorTo(2,0);
 int dan2 = vnos_stevila();
 itoa(dan2,buffer,10);
 lcd.cursorTo(2,1);
 lcd.printIn(".");
 lcd.cursorTo(1,0);
 lcd.printIn("               ");
 lcd.cursorTo(1,0);
 lcd.printIn("Mesec: "); //print mesec ->  month in english
 int mesec1 = vnos_stevila();
 itoa(mesec1,buffer,10);
 lcd.cursorTo(2,3);
 int mesec2 = vnos_stevila();
 itoa(mesec2,buffer,10);
 lcd.cursorTo(2,4);
 lcd.printIn(".");
 lcd.cursorTo(1,0);
 lcd.printIn("               ");
 lcd.cursorTo(1,0);
 lcd.printIn("Leto: "); //Print leto -> year in english
 int leto1 = vnos_stevila();
 itoa(leto1,buffer,10);
 lcd.cursorTo(2,6);
 int leto2 = vnos_stevila();
 itoa(leto2,buffer,10);
 lcd.cursorTo(2,7);
 int leto3 = vnos_stevila();
 itoa(leto3,buffer,10);
 lcd.cursorTo(2,8);
 int leto4 = vnos_stevila();
 itoa(leto4,buffer,10);
 lcd.cursorTo(2,9);
 delay(3000);
 char sekunde3[6]; //Create a char array for seconds
 char sekunde4[2];
 char minute3[6];
 char minute4[2];
 char ure3[6];
 char ure4[2];
 char dan3[6];
 char dan4[2];
 char mesec3[6];
 char mesec4[2];
 char leto5[12];
 char leto6[2];
 char leto7[2];
 char leto8[2];
 itoa(sekunde1,sekunde3,10); //Converts sekunde1 to char and store them in sekunde3
 itoa(sekunde2,sekunde4,10);
 itoa(minute1,minute3,10);
 itoa(minute2,minute4,10);
 itoa(ure1,ure3,10);
 itoa(ure2,ure4,10);
 itoa(dan1,dan3,10);
 itoa(dan2,dan4,10);
 itoa(mesec1,mesec3,10);
 itoa(mesec2,mesec4,10);
 itoa(leto1,leto5,10);
 itoa(leto2,leto6,10);
 itoa(leto3,leto7,10);
 itoa(leto4,leto8,10);
 strcat(sekunde3,sekunde4); //Combines two digits of seconds and stores them in sekunde3
 strcat(minute3,minute4);
 strcat(ure3,ure4);
 strcat(dan3,dan4);
 strcat(mesec3,mesec4);
 strcat(leto5,leto6);
 strcat(leto5,leto7);
 strcat(leto5,leto8);
 //Displays this:
 // HH:MM:SS
 // DD.MM.YYYY
 lcd.clear();
 lcd.cursorTo(1,6);
 lcd.printIn(ure3);
 lcd.printIn(":");
 lcd.printIn(minute3);
 lcd.printIn(":");
 lcd.printIn(sekunde3);
 lcd.cursorTo(2,6);
 lcd.printIn(dan3);
 lcd.printIn(".");
 lcd.printIn(mesec3);
 lcd.printIn(".");
 lcd.printIn(leto5);
 delay(5000);
 int ure = atoi(ure3); //converts char back to integer
 int minute = atoi(minute3);
 int sekunde = atoi(sekunde3);
 int dan = atoi(dan3);
 int mesec = atoi(mesec3);
 int leto = atoi(leto5);
 DateTime.sync(DateTime.makeTime(sekunde, minute, ure, dan, mesec, leto));  //sets the time
 ura_nastavljena = true; //The time is now set
The ura_nastavljena part just indicates that the clock has been set so my code doesn't ask me to set the time again. You can use that or delete it.
And here is the code for numeric input using one potenciometer and one button:
Code: [Select]
int vnos_stevila()
 while(1) //Create a loop
     int vrni = 0; //Number to return
     int dobi = analogRead(1); //Get a value from potenciometer on analog pin 1
     int gumbi = 0; //Here is stored a value from a button
     if (dobi <=102) //If input from a potenciometer is between 0 and 102 then variable vrni is 0
         vrni = 0;
     else if (dobi <= 204)
         vrni = 1;
     else if (dobi <= 306)
         vrni = 2;
     else if (dobi <= 408)
         vrni = 3;
     else if (dobi <= 510)
         vrni = 4;
     else if (dobi <= 612)
         vrni = 5;
     else if (dobi <= 714)
         vrni = 6;
     else if (dobi <= 816)
         vrni = 7;
     else if (dobi <= 918)
         vrni = 8;
     else if (dobi <= 1023)
         vrni = 9;
     char znak[2]; //declare a variable znak
     itoa(vrni, znak, 10); //convert a variable vrni to char and store it in znak
     lcd.cursorTo(2,14); //Move screen cursor to second row, 14 column
     delay(100); //wait
     lcd.printIn(">"); //A little marker for nicer input
     lcd.printIn(znak); //Print the current value
     gumbi = digitalRead(gumb); //Read the value from a button
     if (gumbi == 1) //If button was pressed, return the current value
         return vrni;
Variable names are in slovenian language but the comments are in english so probably you can understand it. The code is VERY unoptimised and takes a lot of RAM. But it works for me! I am using LCD4Bit library to write on the screen.
the only question now is -> Will this library display the right time for a whole month? +/- 5min
halley
#13
Feb 18, 2009, 02:46 pm Last Edit: Feb 18, 2009, 02:49 pm by halley Reason: 1
Code: [Select]
char buffer[[glow]2[/glow]]; //this is a buffer for printing on a screen
itoa(sekunde1,[glow]buffer[/glow],10);
Dangerous!  You don't give enough space in your character buffer to fit the number.  If the number of seconds is 10, the buffer needs at least 3 bytes of space, the '1', the '0', and the NUL terminator.  If you have numbers larger than 99 (like your year "ledo"), or smaller than 0, you need even more space.
roli
Buffer can only store numbers up to 9. No more! The same goes for the others. leto5 -> combines 4 digits and is 12 places long.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
