Topic: PROGMEM char array (Read 5691 times) previous topic - next topic
shineangelic
consider this snippet, compiled with Arduino IDE:
Code: [Select]
PROGMEM  char charSet[]  = { 0x0, 0x8, 0x4, 0xc, 0x2, 0xA , 0x6, 0xE, 0x1, 0x9,0x5, 0xD, 0x3,0xB,0x7,0xF };
char reversed[]  = { 0x0, 0x8, 0x4, 0xc, 0x2, 0xA , 0x6, 0xE, 0x1, 0x9,0x5, 0xD, 0x3,0xB,0x7,0xF };
char ff;
for (int i=0; i < 16; i++) {
Serial.print(" ");
Serial.print(reversed[i], HEX);
Serial.println(" ");
Serial.print(" ");
ff = pgm_read_byte(&charSet[i]);
Serial.print(ff);
I would expect the two for loops to produce same output. But the output is:
Code: [Select]
     0 8 4 C 2 A 6 E 1 9 5 D 3 B 7 F
     FFFFFF94 FFFFFFB0 6 FFFFFF80 FFFFFF91 FFFFFFC7 3 62 FFFFFFE3 E FFFFFF94 5E 29 FFFFFF99 23 39
What am I missing? Thank you
pYro_65
try a different declaration
Code: [Select]
char charSet[]  PROGMEM = { 0x0, 0x8, 0x4, 0xc, 0x2, 0xA , 0x6, 0xE, 0x1, 0x9,0x5, 0xD, 0x3,0xB,0x7,0xF };
also try below instead of assigning to ff
Code: [Select]
Serial.print( pgm_read_byte( charSet + i ) );
Forum Mod anyone?
https://arduino.land/Moduino/
MarkT
The AVR microcontrollers are Harvard architecture - code and data are in separate memories (flash and SRAM respectively).
countrypaul
Surely you want Serial.print(ff, HEX); rather than just Serial.print(ff);
if you want the output to look the same.
Having said that, it looks like serial.print is assuming you have passed a long rather than a char, which I don't understand yet.
Paul
shineangelic
Quote
Yes, you're right. Anyway the output is the same. Also
Code: [Select]
Serial.print( pgm_read_byte( charSet + i ), HEX );
produces same output. I really can't understand
jraskell
All of the various print(type, base) overloads are piping through print(long, base) apparently to avoid code duplication.  The unfortunate side effect is that Hex values print with too many leading Fs.
AWOL
Quote
Only if you're using signed datatypes.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
countrypaul
So ff should be an unsigned char  as in?
Code: [Select]
unsigned char ff;
Paul
AWOL
Or "byte", as in " pgm_read_byte"
shineangelic
I'v tried with unsigned char and byte, but no luck. The output is:
Code: [Select]
91 C8 3 A8 16 B9 6 CA 6 DB 6 A1 F0 E 94 D3
The code I'm using is:
Code: [Select]
byte charSet[] PROGMEM = { 0x0, 0x8, 0x4, 0xc, 0x2, 0xA , 0x6, 0xE, 0x1, 0x9,0x5, 0xD, 0x3,0xB,0x7,0xF };
byte reversed[]  = { 0x0, 0x8, 0x4, 0xc, 0x2, 0xA , 0x6, 0xE, 0x1, 0x9,0x5, 0xD, 0x3,0xB,0x7,0xF };
byte ff;
Serial.print(" ");
Serial.print(" ");
WizenedEE
Code: [Select]
const byte charSet[] PROGMEM = { 0x0, 0x8, 0x4, 0xc, 0x2, 0xA , 0x6, 0xE, 0x1, 0x9,0x5, 0xD, 0x3,0xB,0x7,0xF };
byte ff;
Serial.print(" ");
Serial.print(" ");
returns
Code: [Select]
on my computer/arduino.
Code: [Select]
$ avr-gcc -v
Using built-in specs.
COLLECT_GCC=avr-gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/avr/4.7.1/lto-wrapper
Target: avr
Configured with: /build/src/gcc-4.7.1/configure --prefix=/usr --libdir=/usr/lib --libexecdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --enable-languages=c,c++ --disable-libssp --disable-nls --target=avr --with-as=/usr/bin/avr-as --with-ld=/usr/bin/avr-ld --with-gnu-as --with-gnu-ld
Thread model: single
gcc version 4.7.1 (GCC)
$ pacman -Qi avr-libc
Version        : 1.8.0-4
URL            : http://savannah.nongnu.org/projects/avr-libc/
Licenses       : BSD
Groups         : None
Provides       : None
Depends On     : avr-gcc
Optional Deps  : None
Required By    : None
Conflicts With : None
Replaces       : None
Installed Size : 23684.00 KiB
Packager       : schuay <jakob.gruber@gmail.com>
Architecture   : any
Build Date     : Sun Jun 24 01:12:18 2012
Install Date   : Thu Jun 28 08:33:48 2012
Install Reason : Explicitly installed
Install Script : No
Description    : The C runtime library for the AVR family of microcontrollers
arduino uno r2
shineangelic
thank you. I had to add const keyword and to move the declaration outside the function.
Now it works.
AWOL
That's why we prefer it that you DON'T post code snippets
shineangelic
The snippet is part of a rudimental Air conditioner IR driver, I thought it was too long to be posted for a simple issue.
I'll post it, so maybe someone will find other inconsistencies in my rusty C code. It works, but I'd like to decrease memory usage furthermore.
Thanks to anyone who'll be looking at it.
Code: [Select]
#include <avr/pgmspace.h>
//These are Samsung MH026FB specific
#define tempmask 0xF//temp e` quarto byte dell'input
#define funmask 0xF0
#define fanmask 0x700
#define swirlmask 0x800
#include "IRremoteInt_light.h"
#include "IRremote_light.h"
#define DEBUG 1
Souliss Aircon MH026FB Driver
implements IR logic. Commanded by Souliss AirCon protocol
SAMSUNG MH026 series
//IR_Remote lite library
IRsend irsend;
Counts number of 1 in a long
int NumberOfSetBits(long i)
    i = i - ((i >> 1) & 0x55555555);
    i = (i & 0x33333333) + ((i >> 2) & 0x33333333);
    return (((i + (i >> 4)) & 0x0F0F0F0F) * 0x01010101) >> 24;
Reverse the bit in a byte via a lookup table
Bit reversal lookup table
0100 --> 0010
//TODO use progmem
char revbits(int n)
return pgm_read_byte(&charSet[n]);
//return reversed[n];
Compute Samsung crappy checksum
Command is split between data and data2
Samsung checksum
1. Count the number of 1 bits in all the bytes except #2 (checksum)
2. Compute count mod 15. If the value is 0, use 15 instead.
3. Take the value from 2, flip the 4 bits, and reverse the 4 bits.
4. The checksum is Bn where n is the value from the previous step.
Note that step 2 is mod 15, not mod 16 (which you might expect). I
don't know why 15 is used as a special case instead of 0.
For step 3, the results in order are F, 7, B, 3, D, 5, 9, 1, E, 6, A,
2, C, 4, 8, 0. Note that these are exactly the same as the values you
got for byte 5 (temperature). This suggests that the reversed /
inverted bits are more "fundamental".
Thanks to Ken Shirriff
long computeChecksum(long data, long data2){
char temp;
temp = NumberOfSetBits(data2);
temp +=NumberOfSetBits(data);
temp = temp%15;
if (temp == 0)
temp = 15;
#ifdef DEBUG
Serial.print("NUMBITS SET:");
Serial.println(temp, HEX);
#endif
temp = ~temp;
temp -=0xF0;
#ifdef DEBUG
Serial.print("INVERTED:");
Serial.print("REVERSED:");
Serial.println(revbits(temp), HEX);
#endif
return 0xB0 + revbits(temp);
Remap Souliss AirCon data with device specific one (Samsung MH026FB).
You'll have to re-implement this function to support your
Air Conditioner. Souliss INPUT Data is:
0xABCD
A = 4 bit mask (XYZT X= powerON, Y PowerOFF, ionizer (airclean) , pwrsave)
B = Fan/Swirl (1bit switch + 3bits for four possible fan values)
C = Function (auto,cool,dry,fan,heat)
D = Temperature (from 16 to 30, see .h)
I comandi sono formati da due o tre burst
OUTPUT (Samsung specific)
Codice dati da inviare: 7F       XX       80       71       F    1    7    7    F0
const    check    swirl    const    ion  tem  fan  fun  const
DEFAULT 00000000 00000000 00000000 01110001 0000 0000 0000 0000 00000000
void sendMH026FB(unsigned long data, U8 *memory_map, U8 slot){
long part1=0;
long part2=0;
#ifdef DEBUG
Serial.print("Souliss AirCon input:");
Serial.println(data, HEX);
#endif
if (data & 0x8000){//if first bit of input=0 TURN ON
#ifdef DEBUG
Serial.println("POWERON!");
#endif
irsend.sendSamsung(0xBFB20FFF, 0xFFFFF0);
irsend.sendSamsung(0x7FB40FFF, 0xFFFFFF);
//*status = Souliss_T_IrCom_AirCon_Pow_On;
//go on with command
else if (data<<1 & 0x8000) {//if second bit of input=0 SHUT OFF
#ifdef DEBUG
Serial.println("POWEROFF!");
#endif
irsend.sendSamsung(0xBFB20FFF, 0xFFFFFC);
irsend.sendSamsung(0x7FB08A71, 0xF84FFC);
//*status = Souliss_T_IrCom_AirCon_Pow_Off;
//memory_map[MaCaco_OUT_s + slot] = *status;
//memory_map[MaCaco_OUT_s + slot + 1] = *status;
memory_map[MaCaco_IN_s + slot] = Souliss_T_IrCom_AirCon_Reset;
return;
else {//Comando da due bursts, primo costante
irsend.sendSamsung(0xBFB20FFFUL ,0xFFFFF0UL );
//starting values
part1 =  0x7f000000;
part2 =  0x0000F0;
//last part1 const (andrebbe 11 -> turbo) e 01->Powersave
unsigned int powerMode = Souliss_T_IrCom_AirCon_opt_normal;
//FAN is bit 2,3,4 of 2nd BYTE of INPUT
char fan = (data & fanmask)>>8;
//FUN = 3rd byte of INPUT
char fun = (data & funmask)>>4;
//TEMP = 4th byte of INPUT
long temperat = data & tempmask;
//swirl OFF by default
unsigned int swirl = 0x80;
//swirl (if deflector has to swing)
if (data & swirlmask){
swirl=0x8A;
//Eco bit Toggle, only in cool mode
if ((data<<3 & 0x8000) && (fun == Souliss_T_IrCom_AirCon_Fun_Cool))
powerMode = Souliss_T_IrCom_AirCon_opt_eco;
//PART2
//OPT if terzo bit = 1 IONIZER
if (data<<2 & 0x8000)
part2 += 0x700000;//Ion ON
part2 += 0xF00000;//F = Ion OFF
//Fan has only 24 degrees
if (fun == Souliss_T_IrCom_AirCon_Fun_Fan)
temperat = Souliss_T_IrCom_AirCon_temp_24C;
//Dry has only AUTO fan setting
if (fun == Souliss_T_IrCom_AirCon_Fun_Dry)
fan = Souliss_T_IrCom_AirCon_Fan_Auto;
//Auto mode adjust: fan and options are fixed
if (fun == Souliss_T_IrCom_AirCon_Fun_Auto){
fan = 0x4;
//swirl=0x8A;
part1 += swirl<<8;
part1 += powerMode;
//temperature on sixth byte
part2 += temperat<<16;
part2 += fan<<12;
part2 += fun<<8;
//has to be last call
part1 += computeChecksum(part1, part2)<<16;
//send command
irsend.sendSamsung(part1, part2);
#ifdef DEBUG
Serial.print("Sending 0x");
Serial.print(part1, HEX);
Serial.print(" ");
Serial.println(part2, HEX);
#endif
//*status = data;
