Topic: Uno : subtract digi inputs (Read 4094 times) previous topic - next topic
nimba
Hi :)
I work with a flow meter with Hall-effect sensors to read the flow through a pipe (sensor A). some of the flow is not "used" and comes back in a different tube for sensor B)
I have programmed two digital inputs (2 and 3) to read the signal from the sensors
But .. can anyone help me to subtract the input signal so that I only read  the total of flow  (Sensor A - Sensor B)
The hall-effect sensors connects to pin 2 and 3 and uses interrupt 0,
byte sensorInterruptA = 0; // 0 = pin 2; 1 = pin 3
byte sensorInterruptB = 1; //1 0 = pin 2; 1 = pin 3
byte sensorPinA = 2;
byte sensorPinB = 3;
Thanks...
MarkT
I suggest reading each flow meter separately into its own variable (by the relevant interrupt routine), and do the subtraction in loop() or whatever as needed - this means you have the option of calibrating each flow sensor separately before taking the difference.
nimba
okey ... both sensors are identical and calibrated to show the same flow in input 2 & 3
Does this under say you anything ?
// The hall-effect flow sensor outputs approximately 4.5 pulses per second per
// litre/minute of flow.
float calibrationFactor = 10;
volatile byte pulseCount;
float flowRate;
unsigned int flowMilliLitres;
unsigned long totalMilliLitresA;
unsigned long totalMilliLitresB;
unsigned long oldTime;
  pinMode(sensorPinA, INPUT);
  pinMode(sensorPinB, INPUT);
  digitalWrite(sensorPinA, HIGH);
  digitalWrite(sensorPinB, HIGH);
  pulseCount = 0;
  flowRate = 0.0;
  flowMilliLitres = 0;
  totalMilliLitresA = 0;
  totalMilliLitresB = 0;
  oldTime = 0;
  // The Hall-effect sensor is connected to pin 2 which uses interrupt 0.
  // Configured to trigger on a FALLING state change (transition from HIGH
  // state to LOW state)
attachInterrupt(sensorInterruptA, pulseCounter, FALLING);
  attachInterrupt(sensorInterruptB, pulseCounter, FALLING);
PeterH
Even so, I'd use the approach MarkT suggested and process each sensor separately and then subtract the resulting flow values.
nimba
hmm...?? I dont now if I understand you , the inputs (2 and 3) read each sensor separately already .
:smiley-red:
PaulS
Quote
Yep. It says "INCOMPLETE!".
MarkT
If you know the rates are calibrated the same you can get the interrupt routines to manipulate the same counter variable - you just need
to be sure that one interrupt routine can't interrupt the other (offhand I don't know, the datasheet for the ATmega328 should say).
nimba
Hi
The Arduino boards have two external interrupts: numbers 0 (on digital pin 2) and 1 (on digital pin 3).
so I would assume it would be possible, I have tested both inputs, but I can not put up a new calculation for both on the same display, someone will help a newbie ...
* Water Flow Gauge
* Uses a hall-effect flow sensor to measure the rate of water flow and
* output it via the serial connection once per second. The hall-effect
* sensor connects to pin 2 and uses interrupt 0, and an LED on pin 13
* pulses with each interrupt. Two volume counters and current flow rate
* are also displayed on a 2-line by 16-character LCD module, and the
* accumulated totals are stored in non-volatile memory to allow them to
* continue incrementing after the device is reset or is power-cycled.
* Two counter-reset buttons are provided to reset the two accumulating
* counters. This allows one counter to be left accumulating indefinitely
* as a "total" flow volume, while the other can be reset regularly to
* provide a counter for specific events such as having a shower, running
* an irrigation system, or filling a washing machine.
* Copyright 2009 Jonathan Oxer <jon@oxer.com.au>
* Copyright 2009 Hugh Blemings <hugh@blemings.org>
* This program is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version. http://www.gnu.org/licenses/
* www.practicalarduino.com/projects/water-flow-gauge
123456789abcdef
1239.4L 8073.4L
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
// set the LCD address to 0x27 for a 20 chars and 2 line display
byte  sensorInterrupt = 0;// 0 = pin 2; 1 = pin 3
byte sensorPin = 2;
float calibrationFactor = 50;
float flowRate;
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.setCursor(0, 0);
delay(100);
  lcd.begin(16, 2);
  lcd.print(" ");
  lcd.setCursor(0, 1);
  lcd.print(" ");
  // Initialize a serial connection for reporting values to the host
  // Set up the status LED line as an output
// We have an active-low LED attached
  // Set up the pair of counter reset buttons and activate internal pull-up resistors
  pinMode(sensorPin, INPUT);
  digitalWrite(sensorPin, HIGH);
  pulseCount = 0;
  flowRate = 0.0;
  oldTime = 0;
  attachInterrupt (sensorInterrupt, pulseCounter, FALLING);
* Main program loop
  if((millis() - oldTime) > 1000)
  // Only process counters once per second
    // Disable the interrupt while calculating flow rate and sending the value to
    // the host
    detachInterrupt(sensorInterrupt);
    //lcd.setCursor(15, 0);
    //lcd.print("*");
    // Because this loop may not complete in exactly 1 second intervals we calculate
    // the number of milliseconds that have passed since the last execution and use
    // that to scale the output. We also apply the calibrationFactor to scale the output
    // based on the number of pulses per second per units of measure (litres/minute in
    // this case) coming from the sensor.
    flowRate = ((1000.0 / (millis() - oldTime)) * pulseCount) / calibrationFactor;
    // Note the time this processing pass was executed. Note that because we've
    // disabled interrupts the millis() function won't actually be incrementing right
    // at this point, but it will still return the value it was set to just before
    // interrupts went away.
    oldTime = millis();
    // Divide the flow rate in litres/minute by 60 to determine how many litres have
    // passed through the sensor in this 1 second interval, then multiply by 1000 to
    // convert to millilitres.
    flowMilliLitres = (flowRate  / 60) * 1000;
    // Add the millilitres passed in this second to the cumulative total
    // During testing it can be useful to output the literal pulse count value so you
    // can compare that and the calculated flow rate against the data sheets for the
    // flow sensor. Uncomment the following two lines to display the count value.
    //Serial.print(pulseCount, DEC);
    //Serial.print(" ");
    // Write the calculated value to the serial port. Because we want to output a
    // floating point value and print() can't handle floats we have to do some trickery
    // to output the whole number part, then a decimal point, then the fractional part.
    unsigned int frac;
    // Print the flow rate for this second in litres / minute
    Serial.print(int(flowRate )); // Print the integer part of the variable
    Serial.print("."); // Print the decimal point
    // Determine the fractional part. The 10 multiplier gives us 1 decimal place.
    frac = (flowRate - int(flowRate )) * 10;
    Serial.print(frac, DEC) ; // Print the fractional part of the variable
    // Print the number of litres flowed in this second
    Serial.print(" "); // Output separator
    Serial.print(flowMilliLitres);
    // Print the cumulative total of litres flowed since starting
    lcd.print(" ");
    lcd.print("Flow:");
    if(int(flowRate ) < 10)
      lcd.print(" ");
    lcd.print((int)flowRate ); // Print the integer part of the variable
    lcd.print('.'); // Print the decimal point
    lcd.print(frac, DEC) ; // Print the fractional part of the variable
    lcd.print(" L");
    lcd.print("/min");
    // Reset the pulse counter so we can start incrementing again
    pulseCount = 0;
    // Enable the interrupt again now that we've finished sending output
    attachInterrupt(sensorInterrupt, pulseCounter, FALLING);
* Invoked by interrupt0 once per rotation of the hall-effect sensor. Interrupt
* handlers should be kept as small as possible so they return quickly.
void pulseCounter()
  // Increment the pulse counter
  pulseCount++;
PaulS
Quote
Not with this code, you haven't.
Quote
Sure. You take the first step, and we'll let you know if you are going the right way.
nimba
Thanks... :) :)
Then this will be my first step...if I "aktivate" Interrupt 1 on pin 3
This will give me the opportunity to read a sensor at pin 3 ??
#include <Wire.h>
byte  sensorInterrupt = 1;// 0 = pin 2; 1 = pin 3
byte sensorPin = 2;
byte sensorPin = 3;
float flowRate;
  :smiley-red:
PaulS
Quote
Yes.
Code: [Select]
The compiler won't like this, and will let you know. You need different names for the two variables.
Code: [Select]
byte sensorPin = 2;
byte sensorPin = 3;
Ditto.
Code: [Select]
I'm pretty sure you'll need two of these, too. Can't use the same name for both of them, either.
nimba
In a earlier scetch I just use different letters to make them different...and it works !
So I try here...
#include <Wire.h>
byte  sensorInterruptA = 0;// 0 = pin 2; 1 = pin 3
byte  sensorInterruptB = 1;// 0 = pin 2; 1 = pin 3
volatile byte pulseCountA;
volatile byte pulseCountB;
:smiley-red:
PaulS
Quote
So I try here...
It's a good start.
nimba
:) fun...
and the rest before setup.. its the same
#include <Wire.h>
float flowRate;
:smiley-red:
PaulS
That code is the crappiest possible way to read the flow meter output.
Using interrupts to catch the pulses while you have your head buried in the sand is ... Well, stupid is the only thing that comes to mind.
Disabling interrupts and then calling functions that rely on interrupts is not too bright.
I don't know why you expect output on pin 3, since it is clearly an input pin AND you do not cause anything to happen to pin 3.
You also don't have an interrupt handler attached to pin 3, so expecting something to happen when pin 3 changes state is unrealistic.
