Topic: LED cube,shift registers and fun. (Read 14644 times) previous topic - next topic
Hippynerd
Maybe you should try the common anode version.
I never used any transistors in my build, If it was working fine with them before, than it should work find after also, but the cube should run without them (like mine and many others work).
Shift registers should work with to source or sink current, so it shouldnt matter if you have CC or CA setup, but the transistors probably are for sourcing current, which leads me to believe you have a common cathode setup.
https://sites.google.com/site/rgbledcubes
dutchronnie
yES :)
IT IS WORKING
I now have tried your code for the common anode, and changed the lines
      pinState= 1;  // Flip these bits to suit your cubes common lead (cathode or anode)
      pinState= 0;  // Flip these bits to suit your cubes common lead (cathode or anode)
but stil i think i do have an common kathode cube.
The colums are the positive leads of the led
The planes are the negative leads of the led
Thanks Hippynerd for your help
Hippynerd
That bit there, and the bit at the top that says cathode/anode are the only differences between the 2 programs. I should change that to a binary variable (true/false) and embed it with a comment.
The cube setups that I have seen that use 4 transistors on the planes are common anode, and the transistors are to source current to the plane. I think you could also use transistors to sink current to the planes also, but I dont think that i have seen that yet. I think all the LED rigs I have setup are common cathode, even when I tried to make one common anode! Shift registers should work with either setup.
Now that things are working, you can start messing around with data fields, and make up your own patterns. Please share all the cool patterns that you come up with, post them here, or link them here, and I will try them out on my cube.
There are other 4x4x4 cube programs out there to try, I had trouble getting them to work on my cube, but they may run on your cube.
fotomarco
very good job , i like it !!!
from spain
Sparkie
Seasons Greeting All
Sparkie4080 Here
New to this fourm.
Hi Hippynerd
Spotted your comments on the 4x4x4 led cube, and was glad to follow your code input, just what I was looking for.
I am hopefully attaching my schematic and code for my 4x4x4 led cube. I built mine on a 4.25x6.5 purfaboard and point to point wiring. the cube works well with the off board uno, but brighter with a 5Volt 2Amp wall wort.
I had a bit of trouble finding a working code for this unit. the one I found didn't have the collum part so I added it as:
int data=2; //pin 2 on the arduino board
int data=3; //pin 3 on the arduino board
int data=4; //pin 4 on the arduino board
int Col1=5; //pin 5 on the arduino board
int Col2=6; //pin 6 on the arduino board
int Col2=7; //pin 7 on the arduino board
int Col2=8; //pin 8 on the arduino board
Im going to try your code and see if it works on my cube.
Let me know if the attached files made it
Thanks
Sparkie4080
Don't Shoot The Messenger
Hippynerd
Hi Sparkie4080,
Thats a real nice looking schematic. My cube started as just 4 resistors, and 64 white LEDs, Then upgraded it to 2 shift registers and then 16 resistors. 1 resistor. It looks like you are sourcing with your shift registers, sinking with the 4 transistor, which is a much better way to do it than my, and its really only 8 more parts. I also notice you have a 1k resistor on pin 74hc595 10(MR) what it that for?
Thats a much nicer circuit. It looks about how I probably should have made my first cube.
Sparkie
Happy New Year to all
Hi Hippynerd
Thank You for your reply.
I found that schematic somewhere on the internet, just can't remember where though.
I built that circuit on a perfiboard with point to point wiring. The Arduino Uno is off board for now as I not sure weather I want to use the Arduino Atmel328 or use a PIC chip. I have room on the board for one or the other, but I'll have to do more research.
Being a NUBE in C++ programming it's a problem understanding what I'm doing.
I've done some Basic programming back in the Vic20 days, but haven't done anything in C or C++.
As for the Program I'm using Now, (Which I Attached in my last message) I found it again somewhere on the internet. It didn't have any way of controlling the Columns, so I added the four lines to bring the Transisters High to Sink the Columns.
Looking at the schematic, notice on the top left are two sets of input pins that get the signals from the offboard Arduino Uno. I had trouble setting the pins, forgetting that the pins are labled 0-7 on the Arduino, but on the schematic, they are marked 1-7, I had put the Data-Clock and Latch in the wrong Place.
I'm Going to try to upload the code in this message....HOPE IT Works...;-)
And Hope You and others can guide me with C++.
Thanks.
/*    Arduino Experimentation Kit Example Code             |
*    CIRC-05 .: 8 More LEDs :. (74HC595 Shift Register)   |
*    We have already controlled 8 LEDs however this does it in a slightly
*    different manner. Rather than using 8 pins we will use just three
*    and an additional chip.
// This is My Version of the Pin Connections
//Pin Definitions
//The 74HC595 uses a serial communication
//link which has three pins Data-Clock and Latch
// Pins 5-6-7-8 are the Columns
int data = 2;
int clock = 3;
int latch = 4;
int Col1 = 5; // Transistor1 Base
int Col2 = 6; // Transistor2 Base
int Col3 = 7; // Transistor3 Base
int Col4 = 8; // Transistor4 Base
//Used for single LED manipulation
int ledState = 0;
const int ON = HIGH;
const int OFF = LOW;
/*setup() - this function runs once when you turn your Arduino on
* We set the three control pins to outputs
  pinMode(data, OUTPUT);
  pinMode(clock, OUTPUT);
  pinMode(latch, OUTPUT);
  pinMode(Col1, OUTPUT);
  pinMode(Col2, OUTPUT);
  pinMode(Col3, OUTPUT);
  pinMode(Col4, OUTPUT);
* loop() - this function will start after setup finishes and then repeat
* we set which LEDs we want on then call a routine which sends the states to the
74HC595
void loop()                     // run over and over again
  int delayTime = 100; //the number of milliseconds to delay between LED updates
  for(int i = 0; i < 256; i++){
   updateLEDs(i);
   delay(delayTime);
* updateLEDs() - sends the LED states set in ledStates to the 74HC595
* sequence
void updateLEDs(int value){
  digitalWrite(latch, LOW);     //Pulls the chips latch low
  shiftOut(data, clock, MSBFIRST, value); //Shifts out the 8 bits to the shift
register
  digitalWrite(latch, HIGH);   //Pulls the latch high displaying the data
  digitalWrite(Col1, HIGH);   //Pulls the Col1 high and turn on transistor-1
  digitalWrite(Col2, HIGH);   //Pulls the Col1 high and turn on transistor-2
  digitalWrite(Col3, HIGH);   //Pulls the Col1 high and turn on transistor-3
  digitalWrite(Col4, HIGH);   //Pulls the Col1 high and turn on transistor-4
/* updateLEDsLong() - sends the LED states set in ledStates to the 74HC595
* sequence. Same as updateLEDs except the shifting out is done in software
* so you can see what is happening.
void updateLEDsLong(int value){
  for(int i = 0; i < 8; i++){  //Will repeat 8 times (once for each bit)
  int bit = value & B10000000; //We use a "bitmask" to select only the eighth
                               //bit in our number (the one we are addressing this
time through
  value = value << 1;          //we move our number up one bit value so next time
bit 7 will be
                               //bit 8 and we will do our math on it
  if(bit == 128){digitalWrite(data, HIGH);} //if bit 8 is set then set our data
pin high
  else{digitalWrite(data, LOW);}            //if bit 8 is unset then set the data
pin low
  digitalWrite(clock, HIGH);                //the next three lines pulse the clock
pin
  delay(1);
  digitalWrite(clock, LOW);
  digitalWrite(latch, HIGH);  //pulls the latch high shifting our data into being
displayed
//These are used in the bitwise math that we use to change individual LEDs
//For more details http://en.wikipedia.org/wiki/Bitwise_operation
int bits[] = {B00000001, B00000010, B00000100, B00001000, B00010000, B00100000,
B01000000, B10000000};
int masks[] = {B11111110, B11111101, B11111011, B11110111, B11101111, B11011111,
B10111111, B01111111};
* changeLED(int led, int state) - changes an individual LED
* LEDs are 0 to 7 and state is either 0 - OFF or 1 - ON
void changeLED(int led, int state){
   ledState = ledState & masks[led];  //clears ledState of the bit we are
addressing
   if(state == ON){ledState = ledState | bits[led];} //if the bit is on we will
add it to ledState
   updateLEDs(ledState);              //send the new LED state to the shift
register
Sparkie
Hippynerd
Pin 10 on the 74hc595 is the master reset, and needs to be active Low.
Also if you notice on the schemo, on the bottom left is the pinout for the IC's Power Pins 8(GND) and 16(VCC) and has Two .1uF caps needed for both IC's.
As I stated before, I powered VCC with an external 5V Power Supply, + to VCC, and - to Ground and also Ground to the Arduino as well for signal return.
By Offboard powering, the Led's are Brighter, and I don't pull too much from the Arduino.
I also have about a thousand Questions about C++ programming, but I have to settle for a few for now.
(1)
How would I set up a data file of different patterens, and make the program point to it.
(2)
How would I set it to Randomly make it's own patterns?
I'm Attaching the Datasheet for the 74hc595 for viewing
Thanks
Hippynerd
The code I wrote/modified, should run on your cube. You may need to change it a tiny bit, or use the CA or CC version (one is for common cathode planes, the other is common anode planes).
The major difference is the transistors, and you dont need to change the code for that. You just need to wire the cube like I did, or change the code to suit your wiring.
I also made this instructable, it has some pictures and stuff that are not on this forum thread, you may find good stuff there too:
http://www.instructables.com/id/4x4x4-LED-cube-upgrade-with-Shift-Registers-74hc5/
that instructable is all about converting parallel to serial communication, but it has pertinent info about what you are trying to build.
I understand that the MR need to be connected to the power source(high), but I havnt seen one with a 1k resistor on it. The caps are called decoupling caps, and they are just there to make sure the shift registers dont go hungry.
The size of the resister on the columns will depend on the LEDs you use. Different color LEDs have different forward voltages. Its a simple calculation to figure out the right resistor, but you need to know your LEDs forward voltage, red ones are often around 1.9v, blue ones are often over 3 volts, I am unsure about the white ones that I used, but I think that they were in a flashlight running at 4.5v with no resistor, so I guessed and stuck 100 ohm resistors in.
C/C++ is object oriented programming, and a lot more robust than basic. a lot of that basic knowlege will be handy when writing new code, but object oriented programming is dramatically different. I consider myself a terrible programmer, but I manage to muddle through it.
The program I posted is a pattern based solution, you have to create the pattern for it to display, and it just repeats the pattern. There are other ways, like applying math and graphing it on the cube. or random, like you ask about, thats machine generated patterns and not static, but rather dynamic.
The cube works by holding a column high/low, while holding the plane high/low. In your example you will need to turn one plane low, and one column high to illuminate one LED.
The way i have the program setup, it sequences through each plane, with a loop, within that loop, it reads in 16 bits of data, and shuffles them out to the shift registers in a serial fashion.
To do what you want, you would do it completely different.
What you want to do is pick a random number(integer) between 1 and 4, and pick a number between 1 and 16. The first number you bring that plane low, the second number you bring the column high. That lights up an LED, then you wait a few miliseconds, and turn it off. Then repeat the procedure.
With the parallel program that was a bit straightforward, but with the shift registers, you will have to do it a bit differently, since you will need to pad the other 15 bits with 0s. Lets say you randomly pick plane 2, and LED 5, you will need to send the shift registers 4 0's, then a 1, then 11 more 0s.
I dont know how you could separate the data from the program. There is a way to get the arduino to read data via serial, its possible to run the cube from serial data, but I havnt done that.
I never had a vic20, but I had a c64, and a TRS-80, I did a lot of basic, back in the 70s 80s and 90s even. I didnt learn C until just before this century.
Sparkie
Hi Again Hippynerd
Seen your Instructable..Not Bad..
If I master the 4x4x4 cube I might try the 8x8x8 RGB Cube Next.
this is where I got the original code from
http://oomlout.com/a/products/ardx/circ-05/
I found this site helpful with some of the layouts for testing the LED's using the 74hc595 shift reg.
After I made the cube and mounted the components, I tested each LED by putting 5v to the base resister and one of the IC socket pins (1-7 and pin 15). this was done before the IC's were plugged in. Bread boarding the LED's and the 74hc595 first, and using a program that took input from the keyboard numbers 1-8, I could press the #1 key and the #1 LED would Light.
From there I used the perfaboard to mount the components with Point to Point wireing. The next board I will etch and put the Arduino Chip on board or use a Pic.
So you used to own a Commie 64 Eh..kinda shows your age ;-) I think my first kit computer was the Timax St Clair with 1k of memmory and a bubble keyboard.
Hope this post helps someone
TTFN
Sparkie
Hippynerd
I remember the sinclair, and that horrible keyboard, similar to the atari 400 keyboard. I think they still use that style keyboard in restaurant cash registers.
The C64 wasnt my first computer, it wasnt even the first computer that I had at home.
I havnt built one with its own dedicated micro-controller. I got some cheap nanos that cost about what the parts for a basic build your own arduino with usb and voltage regulator.
Then I use connectors to plug the nano onto the cube.
Even though an arduino has a lot more memory than those older computers, you can easily fill the 32k memory with program. I have some RGB LEDs blinking on 30k of code, and it only lasts about 2 minutes before you've seen the whole program.
Sparkie
Hi Again
Have you had a chance to look at my code??
I have some questions i'd like to ask.
TTFN
Sparkie
FYI
Sparkie comes from my days as a radio operator in the Army. We were called sparks back then.
Hippynerd
HI, just glancing over the code, this seems odd.
I dont know if you can use a for statement, and there doesnt seem to be a next or else statement.
It also seems like it turns the LEDs on, and has a delay, then loop, and I think you will also want to turn those LEDs off. before looping. Maybe it doesnt matter...
Sparkie
Im not sure eather.
it may be different in C++
I think it is saying that the int=0 and that i is less than 256 and then adds 1????
At least thats how I see it, if it had a <<256 it would mean to shift left 256 bits, which wouldn't make sence.
I think the line you are refering to is:
void loop()   //runs over and over again
int delayTime = 100; //the number of milliseconds delay between led updates
updateLEDs (i);
delay (delayTime);
I think it is saying that the int i is the place holder for ledState, the integer ledState waits for the update
from the line you mentioned....I Think....???
it took me a while to read it over and over again to semiunderstand it.
But you say it works on your 74hc595 setup??
let me know.
TTFN
Sparkie
Tom Carpenter
What is a for loop?
   ... //some code
When you declare a for loop, you have to supply up to four bits of information:
[1] The initialisation
[2] The conditional
[3] The end statement (for lack of a better name)
[4] The code to execute
In the format shown below.
for ( [1] ; [2] ; [3] ) {
  [4]
Any of the four options can be omitted if you don't need them.
The way it works is best summarised in the equivalent block of code below:
  [1]
  while ([2]) {
     [3]
     [4]
At the start, the 'initialisation' is performed. This is usually something along the lines of creating a variable which will be used for the while() condtion.
Then the code enters a while loop whose condition is the 'conditional' part of the for loop. What that means is the block of code inside the while loop will be executed repeatedly while the conditional is true.
In each pass of the while loop, first the 'code to execute' portion is run, then the 'end statement' is run.
If we take the for loop you were wondering about, it becomes this:
{ //create a scope for the while loop.
  int i = 0; //create a variable called i and assign it a value of 0
  while (i < 256) { //check if i is less than 256. This is true at the beginning as i is initially 0
     ... //some code
     i++; //Increment i at the end of the loop.
  //After 256 passes, i == 256, which mean the while() condition becomes false and so the loop completes.
Hopefully that helps. If there is anything you are unclear on, let me know.
~Tom~
