Topic: Why use LEDs when you can use Nixies and lethal voltage levels? (Read 3150 times) previous topic - next topic
JoeN
Nixies are cooler, for sure.  First Nixie project:
Nixies and the 5V-to-170V converter are from TaylorEdge.  It makes this all pretty easy to do.  Next part, interfaciing that red Sparkfun RTC breakout board.
http://www.tayloredge.com/storefront/SmartNixie/
I will never ask you to do anything that I wouldn't do myself.
strykeroz
Looking good.  Shame the RTC brings you back down to using low voltage.  At least you can compensate some by having the alarm generated through a tuned plasma arc or something :)
Geoff
"There is no problem so bad you can't make it worse" - retired astronaut Chris Hadfield
JoeN
Geoff
I'm going to have to work a Jacob's Ladder in here for the alert feature I think...
JoeN
Now with the RTC working, showing the time (central, 24 hour format) from a few minutes ago.  The RTC retains time and date on power-off.  Need to implement the switches now so time and alarm can be set and include a peizo.
