Topic: Ubuntu 12.04 unable to find /dev/ttyACM0 (Read 8425 times) previous topic - next topic
ultimatebuster
Hi all,
I have an Arduino Mega ADK and I'm unable to connect to it from my Ubuntu 12.04 machine. /dev/ttyACM0 is simply not present. Here's the only dmesg output that appears when I connect my arduino. It seems like cdc acm is not firing?
Code: [Select]
[10522.351860] usb 1-1.1: USB disconnect, device number 6
[10525.104918] usb 1-1.1: new full-speed USB device number 7 using ehci_hcd
Any ideas?
Thanks.
geoland
I added username to dialout then plugged UNO in. It was recognised and reported on /dev/ttyACM. Tried to upload - error message.
Disconnected without closing Arduino interface, reconnected and upload successful. Fails on serial console sometimes.
ultimatebuster
I'm in dialout, plug in and out doesn't work for me. Restart doesn't either.
On a different computer with the same ubuntu version and kernel version the arduino works just fine..
It seems to be an issue with this specific computer... Does anyone know what could possibly affect this?
ultimatebuster
SOLUTION FOUND!!
So the solution: unplug the arduino, unload cdc_acm and reload cdc_acm
Commands for people unfamiliar with linux:
Code: [Select]
# rmmod cdc_acm
# modprobe cdc_acm
