Topic: engine start stop with push and push+hold (Read 3275 times) previous topic - next topic
JamesAus
Nov 12, 2012, 10:48 am Last Edit: Nov 13, 2012, 08:16 am by Coding Badly Reason: 1
Hi guys this is first post and first time using an arduino board
My plans were to use a start stop button with LED's to display the modes im in.
After searching the web for an already made sketch that i could  use for my build i came across one made by
Jeff Saltzman.
Code: [Select]
/* 4-Way Button: Click, Double-Click, Press+Hold, and Press+Long-Hold Test Sketch
By Jeff Saltzman
Oct. 13, 2009
To keep a physical interface as simple as possible, this sketch demonstrates generating four output events from a single push-button.
1) Click: rapid press and release
2) Double-Click: two clicks in quick succession
3) Press and Hold: holding the button down
4) Long Press and Hold: holding the button down for a long time
#define buttonPin 19 // analog input pin to use as a digital input
#define ledPin1 17 // digital output pin for LED 1
#define ledPin2 16 // digital output pin for LED 2
#define ledPin3 15 // digital output pin for LED 3
#define ledPin4 14 // digital output pin for LED 4
// LED variables
boolean ledVal1 = false; // state of LED 1
boolean ledVal2 = false; // state of LED 2
boolean ledVal3 = false; // state of LED 3
boolean ledVal4 = false; // state of LED 4
// Set button input pin
pinMode(buttonPin, INPUT);
digitalWrite(buttonPin, HIGH );
// Set LED output pins
pinMode(ledPin1, OUTPUT);
digitalWrite(ledPin1, ledVal1);
pinMode(ledPin2, OUTPUT);
digitalWrite(ledPin2, ledVal2);
pinMode(ledPin3, OUTPUT);
digitalWrite(ledPin3, ledVal3);
pinMode(ledPin4, OUTPUT);
digitalWrite(ledPin4, ledVal4);
// Get button event and act accordingly
int b = checkButton();
if (b == 1) clickEvent();
if (b == 2) doubleClickEvent();
if (b == 3) holdEvent();
if (b == 4) longHoldEvent();
// Events to trigger by click and press+hold
void clickEvent() {
ledVal1 = !ledVal1;
void doubleClickEvent() {
ledVal2 = !ledVal2;
void holdEvent() {
ledVal3 = !ledVal3;
void longHoldEvent() {
ledVal4 = !ledVal4;
MULTI-CLICK: One Button, Multiple Events
Oct 12, 2009
Run checkButton() to retrieve a button event:
Click
Double-Click
Hold
Long Hold
// Button timing variables
int debounce = 20; // ms debounce period to prevent flickering when pressing or releasing the button
int DCgap = 250; // max ms between clicks for a double click event
int holdTime = 2000; // ms hold period: how long to wait for press+hold event
int longHoldTime = 5000; // ms long hold period: how long to wait for press+hold event
// Other button variables
boolean buttonVal = HIGH; // value read from button
boolean buttonLast = HIGH; // buffered value of the button's previous state
boolean DCwaiting = false; // whether we're waiting for a double click (down)
boolean DConUp = false; // whether to register a double click on next release, or whether to wait and click
boolean singleOK = true; // whether it's OK to do a single click
long downTime = -1; // time the button was pressed down
long upTime = -1; // time the button was released
boolean ignoreUp = false; // whether to ignore the button release because the click+hold was triggered
boolean waitForUp = false; // when held, whether to wait for the up event
boolean holdEventPast = false; // whether or not the hold event happened already
boolean longHoldEventPast = false;// whether or not the long hold event happened already
int checkButton()
int event = 0;
// Read the state of the button
buttonVal = digitalRead(buttonPin);
// Button pressed down
if (buttonVal == LOW && buttonLast == HIGH && (millis() - upTime) > debounce) {
downTime = millis();
ignoreUp = false;
waitForUp = false;
singleOK = true;
if ((millis()-upTime) < DCgap && DConUp == false && DCwaiting == true) DConUp = true;
else DConUp = false;
DCwaiting = false;
// Button released
else if (buttonVal == HIGH && buttonLast == LOW && (millis() - downTime) > debounce) {
if (not ignoreUp) {
upTime = millis();
if (DConUp == false) DCwaiting = true;
else {
event = 2;
DConUp = false;
DCwaiting = false;
singleOK = false;
// Test for normal click event: DCgap expired
if ( buttonVal == HIGH && (millis()-upTime) >= DCgap && DCwaiting == true && DConUp == false && singleOK == true) {
event = 1;
DCwaiting = false;
// Test for hold
if (buttonVal == LOW && (millis() - downTime) >= holdTime) {
// Trigger "normal" hold
if (not holdEventPast) {
event = 3;
waitForUp = true;
ignoreUp = true;
DConUp = false;
DCwaiting = false;
//downTime = millis();
holdEventPast = true;
// Trigger "long" hold
if ((millis() - downTime) >= longHoldTime) {
if (not longHoldEventPast) {
event = 4;
longHoldEventPast = true;
buttonLast = buttonVal;
return event;
Below is a link off the button running with the sketch uploaded
http://s414.beta.photobucket.com/user/charged_z/media/IMG_3512.mp4.html
my problem is i would like to be able to scroll between the acc and on mode with separate clicks.
first press ACC LED turns on
second press turns off ACC and the ON LED switches on
third press will switch the button off
press and hold will switch the engine on and off.
could someone please help me sort this out.
Regards James
Moderator edit: [code] [/code] tags added.
PaulS
You're not really using buttons are you?
Quote
How do you switch a button off?
GoForSmoke
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
fungus
Quote
I dunno...but that's an awful user interface design! Good taste prevents me from helping in this project.
No, I don't answer questions sent in private messages (but I do accept thank-you notes...)
JamesAus
Hey guys thanks for the replys!!!
It is a momentary switch im using, if this sketch is not 2 user friendly I'd be happy to try and make my own I just thought that this would be a nice base to start with.
Regards James
JamesAus
GoForSmoke
An engine cut-off that takes a second or more to effect is probably -a very bad idea-. I hope it doesn't take a lawyer in court to get that across. What you modify, you may become some or all responsible for.
