Topic: [library] SerialCommands: easy command-based sketches (Read 3103 times) previous topic - next topic
tuxduino
The purpose of this library is to ease the implementation of a command set.
Each command has an identifier, which is just a simple string. The identifier can be followed by 0 or more characters, which are passed the command implementation as its only argument.
Defining what those characters mean is up to the function that executes the command.
Each command + parameters string is supposed to be terminated by \r or \n or both. These characters are not passed to the command function.
A simple example:
LIGHTON
LIGHTOFF
the command identifier here is "LIGHT". The function implementing it would work more or less like this:
if arg == "ON"
    turn on the light
else if arg == "OFF"
    turn off the light
    print "ERR"
endif
If we had a single temperature sensor we could have a
TEMP
command that would just ignore its argument and simpli print back the sensor value.
A command to get or set the current date could be:
DATE2012-01-01
which would work as follow:
if strlen(arg) > 0
    d = parse date (arg)
    if date was properly formatted
        set current date = d
        print "ERR"
    endif
    d = curr date
    print(d)
endif
Here's a complete example sketch:
Code: [Select]
#include <SerialCommands.h>
const byte LED_PIN = 13;
SerialCommands commands;
// Purpose: making sure the sketch is still alive.
// Expected argument: none.
// Behaviour: prints back the command identifier.
void pingFunction(struct SerialCommand* cmd, const char* str) {
    Serial.println(cmd->cmdString);
// Purpose: turn on or off a led. The pin number is code-defined.
// Expected argument: '0' or '1' to turn the led off or on respectively.
// Behaviour: if the argument is '0', drives the pin LOW
// if the argument is '1', drivers the pin HIGH.
void ledFunction(struct SerialCommand* cmd, const char* str) {
    if (str == NULL) {
        printErr();
    if (str[0] == '0') {
        digitalWrite(LED_PIN, LOW);
        printOk();
    else if (str[0] == '1') {
        digitalWrite(LED_PIN, HIGH);
        printErr();
    else {
        printErr();
// Purpose: read one or more analog channels.
// Expected argument: a list of analog channels to read, for example 01234
// Behaviour: for each char, reads the corresponding analog channel, or prints error if the char is outside the '0'..'5' range.
void readAnalogsFunction(struct SerialCommand* cmd, const char* str) {
    if (str == NULL) {
        printErr();
    for (byte i = 0; i < strlen(str); i++) {
        char ch = str[i];
        if (ch >= '0' && ch <='5') {
            byte anCh = ch - '0';
            Serial.println(analogRead(anCh));
        else {
            printErr();
void cmdNotFound(const char* receivedString) {
    if (receivedString != NULL) {
        Serial.print(receivedString);
        Serial.println(": command not found");
void bufferFull() {
    Serial.print("Serial buffer full. Size = ");
    Serial.println(commands.BUFFER_SIZE);
void printOk() {
    Serial.println("OK");
void printErr() {
    Serial.println("ERR");
// Print a list of available commands.
void listCommands() {
    Serial.print(commands.getNumCommands());
    Serial.println(" commands defined.");
    for (byte i = 0; i < commands.getNumCommands(); i++) {
        Serial.print("command ");
        Serial.print(i, DEC);
        Serial.print(": ");
        Serial.println(commands.getCmdString(i));
    pinMode(LED_PIN, OUTPUT);
    commands.setCmdNotFoundCallback(cmdNotFound);
    commands.setBufferFullCallback(bufferFull);
    commands.addCommand("PING", pingFunction);
    commands.addCommand("LED", ledFunction);
    commands.addCommand("ANREAD", readAnalogsFunction);
    listCommands();
    if (Serial.available() > 0) {
        commands.parseCh(Serial.read());
The attached zip file contains the library, an example and doxygen-generated documentation (work in progress...).
I hope somebody will find this useful. Comments and suggestions are welcome.
TODO: the SerialCommand struct should probably be turned into a proper class, to avoid exposing its internals to the command implementations...
PaulS
Quote
A simple example:
LIGHTON
LIGHTOFF
If the command identifier can be 0 to 5 characters, how does the library parse the command identifier as LIGHT, rather than L or LI or LIG or nothing?
tuxduino
Conceptually, the library tests if the received string startsWith(command identifier), and stops at the first command that satisfies this condition.
There's no 5 characters limitation to the command identifier length, although I admit that may seem the case by looking at my example above.
The command ids are _not_ copied to an internal array, just their pointers are stored. That's why there's a warning about the need to pass string literals to the addCommand() method (global const char* strings would be fine, too).
PaulS
I think it is easier to understand the process if the command name is separated from the command data by some sort of separator.
Afterallthatisafairlystandardpartofanycommunicationsprocess.
tuxduino
Currently nothing stops one from writing
LIGHT ON
LIGHT OFF
The command routine would just see " ON" and " OFF" instead of "ON" and "OFF".
But you got me thinking... I could just ignore the first char after the command, so it would appear as if a blank was required between the command identifier and its arguments. That would certainly make for more readable examples :)
tuxduino
This new version ignores any space (0 or more) between the end of the command identifier and the first non-blank char.
That is, all these three strings:
LIGHTON
LIGHT ON
LIGHT    ON
are "parsed" as command id "LIGHT", argument "ON". The blanks between the command and ON are discarded. Any blank _after_ the first non blank char are _not_ ignored, though. Therefore LIGHT   O N  would be invalid.
(doxygen docs and an example included)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
