Topic: Trying to Interface with Parallax data logger (Read 741 times) previous topic - next topic
Mark Mayhem
I am trying to data log with this Parallax Memory Stick Data Logger (based on the Vinculum USB controller):
http://www.parallax.com/StoreSearchResults/tabid/768/List/0/SortField/4/ProductID/434/Default.aspx?
But I am not having any luck.  I tried modifying some Propeller code, and also tried using the VMUSIC2 example, since it uses the same chip and command set:
http://techartblog.blogspot.com/2007/08/vmusic2-on-arduino.html
Does anyone have resources concerning how to use the USB Stick data logger?
Alternatively, does anyone have other data logging setups that have been proven?  I'm just trying to store some sensor data without having a computer attached...
Here is my code, simplified to the max, to just try to create a file and close it:
     Serial.begin(9600);                    // opens serial port, sets data rate to 9600 bps
       delay(2000);
       Serial.print("IPA");                  // sets the vdip to use ascii numbers
       Serial.print(13, BYTE);               // return character to tell vdip its end of message
   delay(2000)  ;
   Serial.print("OPW test.txt");
   delay(2000);
   Serial.print("CLF test.txt");
   delay(2000);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
