Topic: Ethernet server with client´s IP address filter (Read 4578 times) previous topic - next topic
Slavo
Hello evereyone,
I´m using arduino with the ethernet shield and arduino webserver example. In this example, arduino reads client´s get requests and respond with some html page. My problem is, that I want to respond only for one defined client. In header of every packet of client´s get request is his source IP address. So, i would like to read this IP, compare with pre the predefined and if there is a match, then send the response...but i can´t find some function in the ethernet library to access packet header or specifically its source IP address. Is there someone, who knows, how to do this stuff ? Is there any additional library to work with packets ?
Every suggestion is welcomed.
SurferTim
#1
Dec 01, 2012, 04:36 pm Last Edit: Dec 01, 2012, 06:20 pm by SurferTim Reason: 1
I modified the IDE v1.0.2 ethernet library to retrieve the client ip. I attached the modified files to this post.
Ethernet.h
Ethernet.cpp
EthernetClient.h
EthernetClient.cpp
Save your original library files first! Then replace with these.
To get the client ip in your sketch:
Code: [Select]
 if(client) {
   Serial.print("Client IP: ");
   Serial.println(client.remoteIP());
 // rest of your loop code
edit: I put the comment "// SurferTim added" at each change in the files if you want to know what was changed.
If you want to restrict your remote IP to the 192.168.1.x subnet, this works:
Code: [Select]
    IPAddress ipBuf;
    ipBuf = client.remoteIP();
    Serial.println(ipBuf);
    if((ipBuf[0] == 192) && (ipBuf[1] == 168) && (ipBuf[2] == 1)) Serial.println("IP OK");
    else Serial.println("IP fail");
zoomkat
Probably a similar way to get the remote IP in the discussion below.
http://arduino.cc/forum/index.php/topic,82416.msg619420.html#msg619420
Code: [Select]
//zoomkat 12-8-11
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
byte rip[4];
//byte rip[] = {0,0,0,0};
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server LED test 1.0"); // so I can keep track of what is loaded
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
client.getRemoteIP(rip);
for (int bcount= 0; bcount < 4; bcount++)
        Serial.print(rip[bcount], DEC);
        if (bcount<3) Serial.print(".");
          //now output HTML data header
             if(readString.indexOf('?') >=0) { //don't send new page
               client.println("HTTP/1.1 204 Zoomkat");
               client.println();
               client.println();
             else {
          client.println("HTTP/1.1 200 OK"); //send new page
          client.println("Content-Type: text/html");
          client.println();
          client.println("<HTML>");
          client.println("<HEAD>");
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("</HEAD>");
          client.println("<BODY>");
          client.println("<H1>Zoomkat's simple Arduino button</H1>");
          client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
          client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
          //client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
          client.println("<IFRAME name=inlineframe style=\"display:none\" >");
          client.println("</IFRAME>");
          client.println("</BODY>");
          client.println("</HTML>");
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf("on") >0)//checks for on
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led On");
          if(readString.indexOf("off") >0)//checks for off
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led Off");
          //clearing string for next read
          readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
SurferTim
@zoomkat: It probably does if the ethernet library has been modified to include this function. This is not a function in the standard ethernet library.
Code: [Select]
There is really one way to get the remote IP in the W5100 code. All roads lead to Rome, so to speak.
Slavo
Thank you very much, it works as I wanted ... :)
zoomkat
Code: [Select]
it is interesting that the "rip" way I used only required two file mods and your way used four. Maybe the "ethernet" files actually call the "ethernetclient" files during the compile process. My code calls ethernet.h but I modified the ethernetclient files (and things seem to work).  I'm sure it all goes back to the programming of the w5100 chips and what is available there for use.
SurferTim
#6
Dec 01, 2012, 07:42 pm Last Edit: Dec 01, 2012, 07:57 pm by SurferTim Reason: 1
@zoomkat: That was the first challenge. The IPAddress stuff is in Ethernet.h and Ethernet.cpp, and the socket number is in EthernetClient.h and EthernetClient.cpp. I make an intermediate call to the EthernetClient module to get the current socket number. I use the Ethernet module to be able to return an IPAddress type. Just a matter of convenience, I guess. It stays in convention with the other ip address functions.
For those who haven't figured out what this does, it is a miniature firewall.
Seky
Hello.. I see this is old topic but I have a problem using this modifications to libraryes.. When I have download your modified files and put them in my src folder of ethernet library it says:
Proba_server.ino: In function 'void loop()':
Proba_server:76: error: 'class EthernetClient' has no member named 'remoteIP'
I tried changing few diffrent things in librarys that i have seen on forum but nothing helps
SurferTim
If you got that message, you did not successfully replace the files. Did you download and replace all four files in libraries/Ethernet? All these:
EthernetClient.h
EthernetClient.cpp
Ethernet.h
Ethernet.cpp
I always recommend renaming the originals so you have something to go back to if all else fails.
Seky
Thanks for quick reply,
I didn't bother of making backups because you nicely marked what you changed.
And I did replaced all 4 files. 2 or 3 times to be sure. Thats why I do not understand bug. I use 1.0.6 version of software and arduino uno
SurferTim
Are you certain you replaced the correct files? Are you using Windows? They may be in c:/Program files/Arduino.
Seky
I feel little stupid now. I don't know why but I had ethernet library in My Documents\Arduino. When I replaced ones in C:\Program Files it started to work. And I explicitly imported the replaced libraryes from My Documents so I do not understand now. But it is importat that it works now
Thank you  :D
Seky
I'm reading trough ethernet and ethernetclient libraryes and I can't find some function that can return socket number of curent client that I'm printing IP of. I don't know how to add that to library file.
If i understood it right socket number is something like a channel on which server and client communicates and I have a need to see that channel. If there is a way to see it I would be grateful
SurferTim
#13
Mar 09, 2015, 01:23 pm Last Edit: Mar 09, 2015, 01:24 pm by SurferTim
I haven't tried it, but this should do it for you.
Add this in EthernetClient.h after the status function prototype
Code: [Select]
  uint8_t status();
// add this
  uint8_t getSocket();
Add this to EthernetClient.cpp after my remoteIP function
Code: [Select]
// SurferTim added
IPAddress EthernetClient::remoteIP() {
    return Ethernet.remoteIP(_sock);
// end of add
// add this
uint8_t EthernetClient::getSocket() {
  return(_sock);
Then use it like this:
Code: [Select]
byte thisSocket = client.getSocket();
It will return the socket numbers 0 to 3 (or 0 to 7 if w5200) or MAX_SOCK_NUM, which is 4 (or 8 if w5200) if no socket number.
Seky
The result is as expected. I use 2 clients in local network. But every time i make a request to server client get diffrent socket. They're jumping from 0 to 1. Sometimes 2. I thought that when they connect they will have static socket just for that client until it dissconets
Take a look at code. This does nothing smart but I'm trying to implement some light security for home automation
The index page have Text box and submit button. Page 2 only have one paragraph which says you are logged in
I want for multiple user to be able to connect and each have to insert password and then then they can change some stuff on page 2. I welcome every idea and suggestion.. In meantime i will try some more stuff
Code: [Select]
#include <SPI.h>
#include <SD.h>
#define REQ_BUF_SZ   40
byte mac[] = {
byte ip[] = {
  192, 168, 0, 102 }; // ip in lan
byte gateway[] = {
  192, 168, 0, 1 }; // internet access via router
byte subnet[] = {
EthernetServer server(80);
; //server port
File webFile;                    // handle to files on SD card
char HTTP_req[REQ_BUF_SZ] = {
  0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
boolean sifra_ok=0;
boolean sifra[4]={0};
byte ip_klijennt[4]={0};
void setup(){
  // disable Ethernet chip
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  // initialize SD card
  Serial.println("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("ERROR - SD card initialization failed!");
    return;    // init failed
  Serial.println("SUCCESS - SD card initialized.");
  // check for index.htm file
  if (!SD.exists("index.htm")) {
    Serial.println("ERROR - Can't find index.htm file!");
    return;  // can't find index file
  Serial.println("SUCCESS - Found index.htm file.");
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  Serial.println("Pass test"); // so I can keep track of what is loaded
void loop(){
  if (client) {
   Serial.print("Socket je:");
   Serial.println(thisSocket);
    boolean currentLineIsBlank = true;
        if (req_index < (REQ_BUF_SZ - 1)) {
          HTTP_req[req_index] = c;          // save HTTP request character
          req_index++;
Serial.print(c);
        if (c == '\n' && currentLineIsBlank) {
         Serial.println(HTTP_req);
           //see what was captured
if(StrContains(HTTP_req, "Pass=sifra"))
sifra_ok=1;}
else if(StrContains(HTTP_req, "Pass=") || StrContains(HTTP_req, "GET / ")  || StrContains(HTTP_req, "GET /index.htm"))
{sifra_ok=0;
webFile = SD.open("index.htm");}
          client.println(F("HTTP/1.1 200 OK"));
          client.println(F("Content-Type: text/html"));
          client.println(F("Connnection: close"));
          client.println();
          if (sifra_ok) {
            webFile = SD.open("page2.htm");        // open web page file
          else if (StrContains(HTTP_req, "GET / ")  || StrContains(HTTP_req, "GET /index.htm")) {
            webFile = SD.open("index.htm");        // open web page file
          // send web page to client
          if (webFile) {
            while(webFile.available()) {
              client.write(webFile.read());
            webFile.close();
          // reset buffer index and all buffer elements to 0
          req_index = 0;
          StrClear(HTTP_req, REQ_BUF_SZ);
        // every line of text received from the client ends with \r\n
        if (c == '\n') {
          // last character on line of received text
          // starting new line with next character read
        else if (c != '\r') {
          // a text character was received from client
          currentLineIsBlank = false;
      } // end if (client.available())
    } // end while (client.connected())
    delay(1);      // give the web browser time to receive the data
    client.stop(); // close the connection
  } // end if (client)
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
  for (int i = 0; i < length; i++) {
    str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
  char found = 0;
  char index = 0;
  char len;
  len = strlen(str);
  if (strlen(sfind) > len) {
    return 0;
  while (index < len) {
    if (str[index] == sfind[found]) {
      found++;
      if (strlen(sfind) == found) {
        return 1;
    else {
      found = 0;
    index++;
  return 0;
