Topic: QUESTION ABOUT SOLAR PANELS (Read 1 time) previous topic - next topic
julienne
Our project is SOLAR-POWERED CHARGING STATION
My question is:
How many volts will be consumed by one laptop if we used 100watt solar panel?
Can you give some formulas for the computation?
cr0sh
You'll need to give us more information - how about a link to the panel(s) in question. Also, do you propose a direct-drive from the panel, or are you going to use an inverter (plus, will there be a battery bank in use)...?
We'll also need more information on the power needs of the laptop in question (which is what?)...
cbagz
DC volts to watts calculation formula
The power P in watts (W) is equal to the voltage V in volts (V), times the current I in amps (A):
P(W) = V(V) × I(A)
A standard laptop is 19 volt's 3.42 amp's = 64.98watt's
