Topic: fiber optic transceiver (Read 3291 times) previous topic - next topic
Victorb17
Hey guys, I have a micro board, and need to use the usb communications to a computer.  However I want the micro to be completely electrically isolated from the pc.  So I want to decouple using a fiberoptic transceiver.  Have any of you ever done this?  Also I need a very small form factor.  Just need something to point me in the right direction.  Thanks.
larryd
I haven't done exactly that but have designed fiber optic modems.
I used HFBR1414Z as the transmitter and a HFBR2412Z as the receiver.
http://www.avagotech.com/pages/en/fiber_optics/general_purpose_industrial_control_data_link_820nm/hfbr-2412z/
You obviously need 2 each of the above for RX &TX.
You can start by looking at the data sheets pages 11, 13 and 19
No technical PMs.
The last thing you did is where you should start looking.
retrolefty
#2
Jan 08, 2013, 03:38 am Last Edit: Jan 08, 2013, 03:39 am by retrolefty Reason: 1
There is another way to isolate that by using a isolating USB device. Many different makers of these things.
http://keterex.com/kxusb150.php
This one has the advantage of being able to pass 400 ma of 5 volt power to the remote device which fiber optic cannot provide.
Lefty
MichaelMeissner
It occurs to me another way to optically isolate the Arduino from the PC would be to use a bluetooth or wifi radio device.
One way to use fiber is to use it as a network device.  Recently, I was curious and did a google search, and saw you could get low end ethernet->fiber converters for about $50 each.  Couple that with an ethernet shield should get you the connection.
The post BlinkIt in the exhibition gallery shows another way to communicate: http://arduino.cc/forum/index.php/topic,140698.msg1057787.html, and presumably you could use it via a fiber optic cable if you could put a light sensor on the PC.
Victorb17
Hey, thanks for the ideas about wireless.  I am doing this design work for someone else though, and the specs are usb to the pc.  I have seen a very small (<1") fiber optic transceiver in another setup.  two components were connected by a single fiber.  I will try to find the part number on the existing system I saw.  This is new territory for me... :smiley-eek-blue:
