Topic: Interfacing 3.3v GPS with 5v Freeduino (Read 1 time) previous topic - next topic
Leonti
Hello!
I've just assembled Freeduino board and it works perfectly.
I have usb GPS which I want to use with my arduino.
The chip inside the receiver has only 4 wires - +/GND/RX/TX which is very convenient. Unfortunately I don't know the name of the chip. What I do know that it uses 3.3.v.
I can't connect it to the board as it draws more than 40ma.
So I think I'm going to use LD1117 for power, but what about serial lines?
Do I have to use something? If so, examples would be very appreciated.
Thank you in advance!
Leonti
peter247
Same thing you need to do with xbee,s .
you need to use a voltage divider from 2 resistors for the Rx on the gps , but you don`t have to do anything about the tx from the gps , 3.3v is still o.k
http://peter224722.blogspot.com
retrolefty
This would work nicely to convert 2 signal lines to and from 3.3-5.0 volts.
http://www.sparkfun.com/commerce/product_info.php?products_id=8745
Lefty
Leonti
Thank you for replies!
peter247, how this divider would look like? What would be the resistors values?
Lefty, I'm writing from Poland, so it would take to long to get that converter and too expensive (shipping).
Leonti
peter247
I just used 2 equal vaule resistors (4.7k)
(gnd) resistor (rx) resistor ( 0 )
                                  ( tx )
Which converts the 5v to 2.5v which worked with the xbees
But if you wanted 3.3v just mess with the ratio of the resistors to get 3.3v at rx
clifdweller
the sparkfun device is just a couple mosfetts and resistors which you could build as well if you have access to the parts
peter247
The Arduino work with 3.3 volt so there is no point in using a mosfet to level up.
The level down part is just like my I did , but with 10k resistors.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
