Topic: 5v to 12v relay? (Read 1 time) previous topic - next topic
thepartybot
Hi everyone i just recently purchased the Arduino Duemilanove, and i know the out put is 5v from the i/o's and i was looking to hook these up to some kind of relay so i could hook up roughly 40-50 10mm leds to each channel and have them stobe in quad flashes like police car i have a 12v 7.2 amp hours source to power the leds...any help would be much appreciated.
Grumpy_Mike
In this case motors and LEDs are the same sort of load:-
http://www.thebox.myzen.co.uk/Workshop/Motors_1.html
peter247
Don't directly connect the relay to the pin, you need some sort of buffering.
http://peter224722.blogspot.com
thepartybot
okay looked at that tutorial and could only read bits and pieces as the pic for some reason were covering info...and also what kind of buffering? and i seen i could use a transistor?
peter247
Yes a transistor, or something like a ULN2803A which is like 8 transistors in one package.
Grumpy_Mike
Quote
Sorry you must have an old browser.
Try this:-
http://www.kpsec.freeuk.com/trancirc.htm
mikester
http://www.phoenixcontact.com/signal-level-matching/31255_31384.htm
darudude
you prob dont need the relay, just the transistors should be enough. just make sure the ones you get are rated for the current and voltage you want.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
