Topic: Interface to LTC1298 Serial 12 bit ADC (Read 1 time) previous topic - next topic
mcsarge
Oct 19, 2009, 01:59 am Last Edit: Oct 19, 2009, 02:01 am by mcsarge Reason: 1
Hi all,
This is a simple program that I created to read an LTC1298 12 bit ADC. I am using it to read an MPX4115 pressure sensor. Here is the code:
Code: [Select]
LTC1298 - Arduino interface
Matt Sargent
October 2009
This example is essentially a port of the code that is contained in the
Peter Anderson article. I believe the code was written by Towanda Malone, Baltimore, MD in Apr, '99.
Here is a link to the article:
http://www.phanderson.com/PIC/PICC/CCS_PCM/1298.html
I updated the code to work with the Arduino. I am using the default board, so I did not make any
adjustments for the speed at which the conversions are being made. I do take 20 samples and delay 1 ms
between each and then average them. I have added an error amount that I have found is needed to get my
barometer to match the local one at the Naval Air Station.
Connections:
The LTC1298 is connected thus:
LTC1298  |  Arduino Pin (not ATMEGA328)
CLK  (7) |   Pin 2
Din  (5) |   Pin 3  Note same pin as below
Dout (6) |   Pin 3  Note same pin as above
!CS  (5) |   Pin 4
Data sheets:
http://cds.linear.com/docs/Datasheet/128698fs.pdf
References:
const int CS_PIN=4;
const int Dinout_PIN=3; //Din and Dout are both connected to pin 3...
const int CLK_PIN=2;
void setup(void)
 //Set output pins to output
 pinMode(CS_PIN, OUTPUT);
 pinMode(CLK_PIN, OUTPUT);
 //Setup this pin, though it changes from input to output and vice versa
 pinMode(Dinout_PIN, OUTPUT);
 // start serial port
float samples;
float analogValue;
float adjustment = 1.0;
float P; //pressure in millibars
float temp;
void loop(void) {
  samples = 0.0;
  for (int i = 0; i < 20; i++)
    temp = ReadFromLTC1298(0x0d); //single ended Ch 0
    samples = samples + temp;
    delay(1);
  //now average the 20 samples
  analogValue = samples / 20.0;
  P = analogValue * 0.272 + 105.5 + adjustment;   //For 12 bit ADC
  // print the result:
  Serial.print("P(avg)=");
  Serial.print(P);
  P = P * 0.0295301;  //convert to in Hg...
  Serial.print("; in Hg = ");
  Serial.print(P);
  Serial.print("  Analog Value=");
  Serial.println(analogValue);
  delay(500); //wait a 1/2 second so the screen does not fly by...
int ReadFromLTC1298(int command)
 int aBit;
 int n;
 int result = 0x0000;
 //Set data pin for output so we can send the command
 //make sure the chip is not selected
 digitalWrite(CS_PIN, HIGH);
 //Initialize the clock high
 digitalWrite(CLK_PIN, HIGH);
 //Select the chip (LTC1298 will reset)
 digitalWrite(CS_PIN, LOW);
 //write the command to the LTC1298
 for (n=0; n<4; n++)
   aBit = (command >> (3-n)) & 0x01;
   digitalWrite(Dinout_PIN, aBit); //Most sig fig first
   //Pulse in the bit...
   digitalWrite(CLK_PIN, LOW);
 //Change the Dinout to input for reading
 pinMode(Dinout_PIN, INPUT);
 //dummy clock pulse
 //Read in the 12 bits of data
 for (n=0; n<12; n++)
   //Pulse the clock...
   aBit = digitalRead(Dinout_PIN);
   result = (result << 1) | aBit;
 digitalWrite(CS_PIN, HIGH); //De-Selected the chip
 return result;
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
