Topic: Strange issues on digitalread (Read 959 times) previous topic - next topic
PeteOC
I seem to have an issue where by if I do a digitalRead on pin 8, if I don't have anything connected to pin 8 it reads low however as soon as I connect a cable without anything attached, thats right a wire with nothing on the end the Arduino reads high.
My code is as follows
Code: [Select]
val = digitalRead(8);
  if (val == 1)
    Serial.println(val);
Any ideas why this is?
AWOL
Floating pin.
Common noob problem.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
nickgammon
If I set my multimeter to the millivolts range, and wave the cables around in the air, it gives "readings". Same thing.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
AWOL
Quote
Yup, my new LED-based electrician's screwdriver scared the pants off me the first time it flashed, a good 20cm from anything solid or conductive.
nickgammon
If I wave the cat around in the air, that gives readings too. ;)
More info:
liuzengqiang
What do you intend to do with that pin? If you want to sense a button with it, you need pullup or pulldown resistors.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
GoForSmoke
Arduino has built-in pullups, just set the pin as INPUT and HIGH. Lovely bit of part-count reduction there.
Nick Gammon on multitasking Arduinos:
1) http://gammon.com.au/blink
2) http://gammon.com.au/serial
3) http://gammon.com.au/interrupts
