Topic: Fixing String Crashes (Read 3853 times) previous topic - next topic
James-Brown
Jan 30, 2013, 12:04 am Last Edit: Mar 07, 2013, 05:33 am by Nick Gammon Reason: 1
If your having trouble with the String library crashing your sketch you might want to take a look at this site:
http://www.seti.net/Cosmic%20Rays/Engineering/engineering.htm
nickgammon
#1
Jan 30, 2013, 12:40 am Last Edit: Jan 30, 2013, 12:57 am by Nick Gammon Reason: 1
Good catch! I didn't realize it was that easy.
On a Mac you need to right-click to "Show Package Contents" of your app:
Then copy malloc.c to the folder as shown:
On Windows, it will be something like this (depending where you installed the Arduino app):
After installation:
In case the linked site goes down, I made a copy (right-click and "Save Link As ..."):
http://gammon.com.au/Arduino/malloc.c
Test code:
Code: [Select]
// This sketch will crash after about three iterations.
// It's caused by the malloc bug in the String library
 }  // end of setup
 int n = 0;
 while (n <= 100)
   int u = 20 * n;
   int v = 30 * n;
   String str = String (n) + ", " + String (u) + ", " + String (v);
   Serial.println (str);
   delay (300);
   n++;
 Serial.println ("Done");
 }  // end of loop
Please post technical questions on the forum, not by personal message. Thanks!
More info: http://www.gammon.com.au/electronics
zoomkat
I tried something similar recently based on anothers postings on the subject, and it caused a compile failure with the SdFat library.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
nickgammon
I just compiled my "hex uploader" program which uses SDfat and it compiled OK.
Also the SDInfo example from the SDfat distribution.
zoomkat
Below is what I get when compiling the  quickstart sdfat code.
Code: [Select]
core.a(malloc.c.o):C:\Users\zoomkat\Desktop\Stuff\arduino IDE\arduino-1.0.1-rc2-windows\arduino-1.0.1-rc2\hardware\arduino\cores\arduino/malloc.c:194: first defined here
nickgammon
That compiles OK for me, so I have to assume the SDfat author added in his own malloc.c to work around the known bugs. See if you can find a copy in your SDfat library folder.
nickgammon
Looks like I am right, I just checked the latest version. He probably got tired of waiting for the official fix. It is probably safe to remove his one. Unless there is some subtle problem with it.
I just did a "diff" and the file malloc.c from SdFatBeta20121203.zip, and the one alluded to above, are identical. So there should be no problems in simply deleting it.
zoomkat
Well, will the sdfat version of malloc.c be in the compile path for librarys other than the sdfat ones?
nickgammon
nickgammon
Try running the torture test. If it fails, there is your answer.
