Topic: Softserial (base on digital pins) + IR (Read 9898 times) previous topic - next topic
hamlet
Is there anyone who tried to do the following experiment?
Based on the IR library by Mikal Hart (http://sundial.org/arduino/index.php/newsoftserial/)
And serial to IR converter (like this http://www.midondesign.com/CIR-II/CIR-II.html)
Would it be possible to build an IR serial using 2 digital pin, a high efficient IR LED and an IR detector?
I may give it a try ...
Cheers~
retrolefty
In theory it should work. In reality there seems to be lots of sources of IR 'noise' in the real world that could limit range and reliability of such a direct serial IR data link. It's worth experimenting with.
What is mostly used in the real world of IR remote links is to send a serial data stream but modulating it onto a 38khz 'carrier' frequency. Then using standard 38khz IR demodulator modules as shown in the below link.
This demodulator has discrimination circuitry and automatic gain controls that filter random IR noise sources and bad effects from direct sunlight, etc. However the 38khz carrier would place a limit on how high a serial baud rate you could run through it. Most likely 1200 or 2400 baud but only experimentation would prove out the max baud rate that could be used.
http://www.sparkfun.com/commerce/product_info.php?products_id=8554
Lefty
hamlet
hamlet
Oh, btw, how to send a serial data stream and modulate it onto a 38Khz 'carrier' frequency?
hamlet
Opps, simple googling should solve the case...
http://www.picaxeforum.co.uk/archive/index.php/t-3970.html
retrolefty
Quote
Well it can be done by ANDing a 38,000hz square wave (maybe from a 555 timer chip) with the serial transmit output pin.
A possible minimum component solution (it would depend on the current requrement of the IR emitter) would be to wire the cathode of the emitter to the serial output pin of the ARduino the other end of the emitter to a series current limiting resistor and the other end of the resistor to a Arduino output pin that is programmed to output a continous 38,000 square wave. You have to size the resistor such that the current is limited to 40ma or less.
Lefty
jabstarr
#6
Aug 05, 2009, 08:35 pm Last Edit: Aug 05, 2009, 08:48 pm by jabstarr Reason: 1
Quote
this works!  :D
check this link for a demo video and setup/schematic pics: http://tthheessiiss.wordpress.com/2009/08/05/dirt-cheap-wireless/
thanks retrolefty!
code as follows:
TX
Code: [Select]
//dirt cheap wireless TX
//generates 38kHz carrier wave on pin 9 and 10
//sends data via TX every 500ms
 pinMode(9, OUTPUT);
 pinMode(10, OUTPUT);
 // Clear Timer on Compare Match (CTC) Mode
 bitWrite(TCCR1A, WGM10, 0);
 bitWrite(TCCR1A, WGM11, 0);
 bitWrite(TCCR1B, WGM12, 1);
 bitWrite(TCCR1B, WGM13, 0);
 // Toggle OC1A and OC1B on Compare Match.
 bitWrite(TCCR1A, COM1A0, 1);
 bitWrite(TCCR1A, COM1A1, 0);
 bitWrite(TCCR1A, COM1B0, 1);
 bitWrite(TCCR1A, COM1B1, 0);
 // No prescaling
 bitWrite(TCCR1B, CS10, 1);
 bitWrite(TCCR1B, CS11, 0);
 bitWrite(TCCR1B, CS12, 0);
 OCR1A = 210;
 OCR1B = 210;
 Serial.begin(2400);
 Serial.println("testing testing testing");
RX
Code: [Select]
 Serial.begin(2400);
 pinMode(13, OUTPUT);
 // if incoming serial
 if (Serial.available()) {
   readSerial();
   digitalWrite(13, HIGH);
   digitalWrite(13, LOW);
 delay(10);
void readSerial() {
 char val = Serial.read();
 Serial.print(val);
Jeremyvnc
Great work with that jabstarr!  My next question is, can this be done to send and receive on the same arduino so that one can have two-way communication.
Any Ideas?
-Jeremy
CaptainObvious
Hey Jeremy, I've got to agree, this is AWESOME!
As far as getting the two arduinos to talk, it should be fairly easy with the sketch he's provided!
Just upload the sketch to each arduino, and you can use the Serial.print and Serial.read commands, just as if it were a real serial connection.
I haven't experimented with back and fourth communication, but I did try the sketch between two and was amazed at how.. well.. easy and awesome it was!!
I just wish I could figure out how to calculate all the timers to produce the 38KHZ signal!
But anyways, you'll need to set your Serial.read to an integer;
int serialdata = 0;
serialdata = Serial.read();
// then simply use it to compare incoming information!
if (Serial.available() > 0) {
 if (serialdata == 'testing testing testing') {
      digitalWrite(ledpin, HIGH);
      digitalWrite(ledpin, LOW);
You'd just need to compare information coming in to what you want, then have it send out what you need! Something like if (serialdata == 'send me data'){
Serial.print(analogValue);
to send the value from an analogSensor of sorts.
Keep in mind, this was all just typed up, haven't tested so, hope it works!!
I'll see if I can come up with a simple sketch for communicating between the two when I get home:D
Jeremyvnc
#9
Aug 26, 2009, 10:45 pm Last Edit: Aug 26, 2009, 10:50 pm by jeremyvnc Reason: 1
Captain Obvious,
  To compare the incoming data with what you think it should be denotes that you know what the data should be.  I don't want to care about what the data is or previously know what it should be.
Here is what I did.  Using the same concept as jabstarr, I made a crosstalk between two serial ports.  One port is the hardware serial, the other is a NewSoftSerial (http://arduiniana.org/libraries/newsoftserial/).  Works great.  Each side echos what is typed locally.  Below is the code:
Code: [Select]
//Echos data sent locally
//Sends/recieves data through IR through a newsoftserial port
#include <NewSoftSerial.h>
#define rxPin 2
#define txPin 3
NewSoftSerial mySerial(rxPin, txPin);
 pinMode(9, OUTPUT);
 pinMode(13,OUTPUT);
 // No prescaling
 OCR1A = 210;
 OCR1B = 210;
 mySerial.begin(1200);
 Serial.begin(1200);
 //Serial.println("testing testing testing");
 if(Serial.available())
   char dataIn = Serial.read();
   Serial.print(dataIn);
   mySerial.print(dataIn);
   digitalWrite(13,HIGH);
   digitalWrite(13,LOW);
 if(mySerial.available())
   Serial.print((char)mySerial.read());
 delay(10);
On a side note: I didn't even realize the original author had a link to the NewSoftSerial library.  I found it through google. lol.
tekhertz
I have been trying to use jeremyvnc's code but i keep getting garbage back i set baud at 1200 on both my arduino and boarduino and the monitor.It stops when i unplug the boarduino so i know its coming from there and not just noise. I only have a usbtinyisp for programming the boarduino so it just sends
Code: [Select]
     mySerial.println("testing");
my arduino has a 328 would that mess up the carrier wave and if so how would i fix it
Jeremyvnc
Can you tell me more about the hardware you are using in terms of the IR emitter and reciever?  I used an Arduino Pro Mini 8MHz with a 168.  When I used radioshack parts, I got a distance of 3-4 inches for receiving and about 12 inches with sending.  However, when I bought some vishay parts, I was able to easily get 3 feet with a good angle.
I don't think the code is any different for the 328.
tekhertz
#12
Sep 29, 2009, 08:46 pm Last Edit: Sep 29, 2009, 08:47 pm by tekhertz Reason: 1
i'm using a diecimila that i swapped out the 168 with a 328 connected though usb with a radioshack 38khz receiver (276-640) attached to pin 2 and for the transmitter i have a boarduino connected though my USBtinyISP with the Phototransistor (from radioshack 276-142) connected through a 50ohm to pin 9 and directly to Tx(pin3)
Jeremyvnc
#13
Sep 29, 2009, 08:51 pm Last Edit: Sep 29, 2009, 08:52 pm by jeremyvnc Reason: 1
What distances have you tried?  The radioshack parts have a bit of a sweet spot.  If you move it too close, it won't communicate well.  Same as if you move it far away.  Are you getting garbage and that's it no matter the distance?
-Jeremy
tekhertz
its about 14in apart  i have tried both closer and farther i get the same type of junk at any distance
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
