Topic: update to LiquidCrystal (Read 2052 times) previous topic - next topic
ladyada
I re-wrote much of the LiquidCrystal library (for non-graphical LCDs like 16x2 line ones, etc)
it should now work much better for people and I'm looking to get it included in the next rev of the Arduino IDE and have it be the 'gold standard' for LCD interfacing
what has been added:
4-bit init. works even without power-cycling
correct timing delays reduce chance of 'garbling'
R/W pin not needed, saves 1 pin!
more commands to control the LCD display
you can set it up for 2 or 4 line displays with begin()
example for creating custom characters
much faster than old LiquidCrystal and LCD4Bit
etc.
please check it out, let me know how it works for you!
http://www.ladyada.net/learn/arduino/LiquidCrystal-07-06.zip
pwillard
Awesome!  This is a very welcome update!
UncleBone
Nice! I did have to ground RW after disconnecting in order to get it working.
"way befer" Really? And I though that was a local thing...
Why do it right the first time, when building and rebuilding is  so much fun?
ladyada
oh right yes you need to ground r/w
forgot to mention
TBAr
Thanks for the update to the library. It's always nice to see new features added.
floresta
ladyada:
Quote
I hope you have more luck than I did.  LiquidCrystal certainly needs some help.
Don
ladyada
here are some new tutorials as well!
http://arduino.cc/en/Tutorial/LiquidCrystal
Beardy241
Correct me if I'm wrong...
I'm seeing conflicting pin numbers on the page http://arduino.cc/en/Tutorial/LiquidCrystal
The wiring diagram image shows LCD pins D0-D4 in use, while the code below says:
"  * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2"
ASIDE:
I used the old library with great success but in upgrading I'm getting some funky hieroglyphics -- I'm guessing that might be caused by the pin issues mentioned above as I've got flying leads from my 40x2 panel connected to D4-D7.  Out with the 'iron again I guess!   :-/
[m]
beanoman
Looks like the wiring diagram has the data pins backwards- should be D0-D7 from left to right instead of D7-D0. The text has the correct information. Four bit mode always uses the top 4 data pins, D4-D7. If you've had it working before, the wires you have soldered to the LCD are fine.
Beardy241
Thanks for that beanoman, you saved me a lot of bother.
I had already tried wiring 'backwards' (D7-D4) to no avail.
More tinkering required.
[m]
gunric
Great!
I can not find an updated keywords file in the link. That could be nice.
I had to change the offsets in setCursor to { 0x00, 0x40, 0x10, 0x50 } to get the third and fourth line to start correctly but I guess that has something to do with my display (JHD164A).
tigoe
Which datasheet are you using for the HD44780?  I was using this one from Adafruit:  http://www.ladyada.net/media/lcd/RT162.pdf  And this one from Sparkfun:  http://www.sparkfun.com/datasheets/LCD/GDM1602K-Extended.pdf
Both of them show the pinouts as shown in the LiquidCrystal Tutorial.  I've tried that wiring with a half dozen different LCD's from different sources, and all worked properly for me. I also tried them on pins 0 - 4 according to those diagrams and got garbage.  So I'm perplexed as to why you've got different pinouts, or different documentation for it.  But if you've got a link to different docs on the module, I'm happy to try them out.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
