Topic: Unofficial Leonardo Pinout Diagram (Read 23701 times) previous topic - next topic
pighixxx
Feb 11, 2013, 06:36 pm Last Edit: Jul 31, 2014, 05:58 pm by pighixxx Reason: 1
New version.
Download here: http://pighixxx.com/leonardopdf.pdf
& 32U4 processor pinout here: http://t.co/XJAVtV6bsj
Quote
Hi, All
As promised the pinout diagram of Leonardo.
ARDUINO LEONARDO
New version 2.0!
Arduino Leonardo v2
Download PDF
rev4 on line. (12-feb-2013)
The ATMega32U4 Pinout
Download PDF
moonpyk
#2
Feb 11, 2013, 06:43 pm Last Edit: Feb 11, 2013, 06:55 pm by moonpyk Reason: 1
Thank you a lot !
Awesome work, will you put the source files on CC license too ?
Edit : A little mistake I think, the Leonardo has two separate serial interfaces, a virtual CDC (to the computer) which is used for programming and TTL (hardware) on pins 1 and 2. So the information bubble regarding programming is maybe false.
Edit2 : The ADC10 background is blue instead of green. Still awesome work, it's a beta :)
pighixxx
Thank you a lot !
Edit : A little mistake I think, the Leonardo has two separate serial interfaces, CDC (to the computer) which is used for programming and TTL on pins 1 and 2. So the information bubble regarding programming is maybe false.
Thanks!
I correct the error in next release.  ;)
moonpyk
I edited my message way too many times :D
Quote
pighixxx
pighixxx
maxid
thanks a lot - again ! very good work
El que pregunta aprende, el que responde aprende a responder.
pighixxx
Posted a new version (2.0) on 1st post.  :D
bernt
Hi pighixxx,
Thank you for the great work. It really speeds up finding the pins!
I think I found a little error on the Leonardo, Leonardo V2 and Arduino Micro pinouts :
PIN PC6 should be the inverted OC4A, the line above OC4A is missing there.
(It is correct on the ATMEGA32U4 pinout.)
Bernt
bernt
Oh, and there is another, on the Arduino Micro pinout only:
PIN PB5 should be the inverted OC4B, the line above OC4B is missing there.
Thank you,
   Bernt
Ixodides
I can't access those links. Would someone be able to post them again?
pighixxx
Sorry for the late  :D
NEW VERSIONS AVAILABLE
kiplantt
Hello, this line seems to still be missing on OC4A for PC6.
Thanks for your great work!
