Topic: Joystick Mouse Control issue (Read 4708 times) previous topic - next topic
freerpg
http://arduino.cc/en/Tutorial/JoystickMouseControl
thats the tutorial but when I compile the program I get errors
sketch_feb20a.ino: In function 'void setup()':
sketch_feb20a:51: error: 'Mouse' was not declared in this scope
sketch_feb20a.ino: In function 'void loop()':
sketch_feb20a:74: error: 'Mouse' was not declared in this scope
sketch_feb20a:81: error: 'Mouse' was not declared in this scope
sketch_feb20a:81: error: 'MOUSE_LEFT' was not declared in this scope
sketch_feb20a:88: error: 'Mouse' was not declared in this scope
sketch_feb20a:88: error: 'MOUSE_LEFT' was not declared in this scope
so what am I missing? is there a library I can't see? or is there something missing in the code?
zoomkat
Quote
Per your link, do you have this library?
Quote
Using the Mouse library, you can controls...
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
Quick5pnt0
Am I correct in assuming you're using a Leonardo?
freerpg
no I just compiled it no arduino board connected, and where is the library?
PaulS
Quote
Which Arduino? There are over a dozen models.
From: http://arduino.cc/en/Tutorial/JoystickMouseControl
Quote
Hardware Required
    Arduino Leonardo, Micro, or Due board
If you have one of them, you have the Mouse library. If you don't, you still have the library. It's just not included.
And, if you don't have one of them, the Arduino that you have won't be able to output the correct information to do anything.
LoganPIerce15
Hi everyone,
I am trying to make my joystick mouse completely functioning (normal click, drag, etc.). As of now I am stuck with how to allow it to differentiate between a regular click and a drag click (I'm using variable called: var). Here's my program (it started as the example on the website):
Controls the mouse from a joystick on an Arduino Leonardo or Micro.
Uses a pushbutton to turn on and off mouse control, and
a second pushbutton to click the left mouse button
Hardware:
* 2-axis joystick connected to pins A0 and A1
* pushbuttons connected to pin D2 and D3
The mouse movement is always relative. This sketch reads
two analog inputs that range from 0 to 1023 (or less on either end)
and translates them into ranges of -6 to 6.
The sketch assumes that the joystick resting values are around the
middle of the range, but that they vary within a threshold.
WARNING:  When you use the Mouse.move() command, the Arduino takes
over your mouse!  Make sure you have control before you use the command.
This sketch includes a pushbutton to toggle the mouse control state, so
you can turn on and off mouse control.
created 15 Sept 2011
updated 28 Mar 2012
by Tom Igoe
this code is in the public domain
// set pin numbers for switch, joystick axes, and LED:
const int switchPin = 5;      // switch to turn on and off mouse control
const int selPin = 4;    // input pin for the mouse pushButton
const int xAxis = A0;         // joystick X axis
const int yAxis = A1;         // joystick Y axis
const int ledPin = 7;         // Mouse control LED
// parameters for reading the joystick:
int range = 12;               // output range of X or Y movement
int responseDelay = 5;        // response delay of the mouse, in ms
int threshold = range/4;      // resting threshold
int center = range/2;         // resting position value
boolean mouseIsActive = false;    // whether or not to control the mouse
int lastSwitchState = LOW;        // previous switch state
int var = 1;
int varstate = digitalRead(selPin);
  pinMode(switchPin, INPUT);       // the switch pin
  pinMode(ledPin, OUTPUT);  // the LED pin
  pinMode(selPin, INPUT);
// take control of the mouse:
  digitalWrite(selPin, HIGH);
  Mouse.begin();
  // read the switch:
  int switchState = digitalRead(switchPin);
  // if it's changed and it's high, toggle the mouse state:
  if (switchState != lastSwitchState) {
    if (switchState == HIGH) {
      mouseIsActive = !mouseIsActive;
      // turn on LED to indicate mouse state:
      digitalWrite(ledPin, mouseIsActive);
  // save switch state for next comparison:
  lastSwitchState = switchState;
  // read and scale the two axes:
  int xReading = readAxis(A0);
  int yReading = readAxis(A1);
  // if the mouse control state is active, move the mouse:
  if (mouseIsActive) {
    Mouse.move(xReading, -yReading, 0);
  for(int i = 1; varstate == LOW; i++) {
    var++;
    if (varstate == HIGH && var > 1 && var < 150) {
    Mouse.click(MOUSE_LEFT);
    var = 1;
     while(var > 150 && varstate == LOW) {
       Mouse.press();
       var++;
       varstate = digitalRead(varstate);
     Mouse.release();
     var = 1;
  Serial.println (var);
    delay(10);
int readAxis(int thisAxis) {
  // read the analog input:
  int reading = analogRead(thisAxis);
  // map the reading from the analog input range to the output range:
  reading = map(reading, 0, 1023, 0, range);
  // if the output reading is outside from the
  // rest position threshold,  use it:
  int distance = reading - center;
  if (abs(distance) < threshold) {
    distance = 0;
  // return the distance for this axis:
  return distance;
Let me know if you have any ideas or answers.
Thanks in advance!
PaulS
Quote
You could learn to post code correctly. There are two interesting stickies at the top of this forum that should be required reading.
LoganPIerce15
#7
May 07, 2013, 10:15 pm Last Edit: May 07, 2013, 10:18 pm by AWOL Reason: 1
Quote
Moderator edit. Removed offensive content.  Please, read the stickies.
And here's my code:
Code: [Select]
Hardware:
updated 28 Mar 2012
by Tom Igoe
int var = 1;
 Mouse.begin();
 // read the switch:
   var++;
   var = 1;
      Mouse.press();
      var++;
    Mouse.release();
    var = 1;
   delay(10);
   distance = 0;
 return distance;
PaulS
Quote
Perhaps you should start by explaining what a "regular click" is, and what a "drag click" is. Perhaps we know the actions under different names.
LoganPIerce15
"regular" as in LEFT click
"drag click" as in LEFT "click" then "drag" the mouse to highlight...
tobyb121
What is this supposed to be doing?
Code: [Select]
       Mouse.press();
       var++;
You assign varstate to the pin state of the pin varstate? in a loop?! so next time you are reading the state of pin 0 or 1, depending on what they read last time???
When you say you don't know how to differentiate between a click and a click+drag, that should be up to your pc to decide, Mouse.click() just calls Mouse.press then Mouse.release immediately afterwards. You should just call mouse.press when your button goes low, and mouse.release when your button goes high.
LoganPIerce15
