Topic: Arduino wave sheild (Read 860 times) previous topic - next topic
TTU.ABD
Mar 05, 2013, 10:48 pm Last Edit: Mar 05, 2013, 10:50 pm by TTU.ABD Reason: 1
I want to know what the name of library for this code on the link ( http://www.elechouse.com/elechouse/images/product/Arduino%20Wave%20Module/Arduino_Wave_Code.pde )
for the ( http://www.elechouse.com/elechouse/index.php?main_page=product_info&cPath=168_170&products_id=2161 )
and I'd know if the sheild has useless pins on analog { I didn't find that in manual }because I think connect TFT lcd with sound sheild , where when I press on tft lcd write analog signal on pwm pin of arduino mega and  receive this signal analog pin of arduino uno then play audio file ?
Erdin
The code is the full code, it doesn't use a library.
The code is very simple, since it expects to have AD4 coded audio files on the SD card. The code is able to play a file.
The manual has a schematic. The analog pins A4 and A5 pins are used, and A0...A3 are not used. Also digital pin 4 and 8...13 are not used.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
