Topic: How to save data in EEPROM? (Read 2530 times) previous topic - next topic
jepoy12
Mar 08, 2013, 05:14 am Last Edit: Mar 10, 2013, 05:47 am by jepoy12 Reason: 1
since im using the RAM here every time I turn off my arduino the number stored in the num_save will be wipe. so I need to text again just to store my number at the num_save.
I want to store it in the Flash memory so that It will not be wipe after I turn off my arduino. I dont really understand how PROGMEM works. Should I just put the word PROGMEM next to the variable name? would that store the number?
Code: [Select]
char num_rcv [20];
char num_save [20];
gsm.readSMS(smsdata, 160, num_rcv, 20)    //receiving the number
strcpy( num_save, num_rcv );        // after receiving, store the num_rcv to the num_save
Osgeld
you can only save data in progmem when you upload the program, not whenever
http://www.arduino.cc/en/Reference/PROGMEM
what you want is eeprom
http://arduino.cc/en/Reference/EEPROM
http://arduino.cc/forum/index.php?action=unread;boards=2,3,4,5,67,6,7,8,9,10,11,66,12,13,15,14,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,86,87,89,1;ALL
jepoy12
how many numbers I can store in each address? I want to save atleast 20 of character arrays.
Nick Gammon
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
Osgeld
alexander_senseo
One.
There are of course 1kByte of data that can bestored therefore then.
Each being a Byte can store of course 0-255 of data.
so saying one is absolutely correct but might be slightly misleading to the quick reader.
It's one per address and there are 1k addresses.
I remember that there is some function that helps you to store arbitrary data in the EEPROM overcoming the limitation to save only 1 byte at a time. Maybe some helpful and knowing perons can give this info here to you.
what are you doing that you wana store data there?
gnusso
you can take this example:
Code: [Select]
* EEPROM Write
* Stores values read from analog input 0 into the EEPROM.
* These values will stay in the EEPROM when the board is
* turned off and may be retrieved later by another sketch.
#include <EEPROM.h>
// the current address in the EEPROM (i.e. which byte
// we're going to write to next)
int addr = 0;
  // need to divide by 4 because analog inputs range from
  // 0 to 1023 and each byte of the EEPROM can only hold a
  // value from 0 to 255.
  int val = analogRead(0) / 4;
  // write the value to the appropriate byte of the EEPROM.
  // these values will remain there when the board is
  // turned off.
  EEPROM.write(addr, val);
  // advance to the next address.  there are 512 bytes in
  // the EEPROM, so go back to 0 when we hit 512.
  addr = addr + 1;
  if (addr == 512)
    addr = 0;
  delay(100);
regards,
gnux
Nick Gammon
One.
Well, the question was: how many numbers can I store in each address?
More info:
kowalski
#8
Mar 10, 2013, 02:01 pm Last Edit: Mar 10, 2013, 02:51 pm by kowalski Reason: 1
If I understand the problem correctly this is what I would do:
Code: [Select]
#include <avr/eeprom.h>
#define NUM_MAX 20
char num_rcv [NUM_MAX];
char num_save [NUM_MAX] EEMEM; // You could have an initial value here
gsm.readSMS(smsdata, 160, num_rcv, NUM_MAX);
eeprom_write_block(num_save, num_rcv, NUM_MAX);
More details on the AVR GCC online manual: http://www.nongnu.org/avr-libc/user-manual/group__avr__eeprom.html#gac5c2be42eb170be7a26fe8b7cce4bc4d and this tutorial is great: http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=38417
I guess that you will also need to modify your startup to load the number saved in num_save back to num_rcv.
Code: [Select]
eeprom_read_block(num_rcv, num_save, NUM_MAX);
Data stored in EEPROM needs to be read with the special functions.
Cheers!
jepoy12
#9
Mar 11, 2013, 01:45 am Last Edit: Mar 11, 2013, 01:51 am by jepoy12 Reason: 1
Thanks everyone..+1 karma to all. : )
is this correct?
Code: [Select]
#include <SIM900.h>
#include <sms.h>
SMSGSM sms;
#define NUM_MAX 20
char  reg_num[NUM_MAX];        // for reading
char  save[NUM_MAX];               //store the number receive here
const char passRx[] = "Regpass#";     //password for registering
char  storage[160];                 //message receive storage
char  smsdata[160];                //message receive
char  EEMEM numberRx[NUM_MAX];               //number receive
void checkSMS()
 if(gsm.readSMS(smsdata, 160, numberRx, 20))     //read the sms
   if(strncmp (smsdata, passRx, 8) == 0)               //if password password is correct
   sms.SendSMS(numberRx, "Registered");              // send reply
   eeprom_write_block(save, numberRx, NUM_MAX);                  //save it on EEPROM
eeprom_read_block(reg_num, save, NUM_MAX);        //read the stored data
  else if (strncmp (numberRx, regnum, 20) == 0)           //if it is equal
       if (strlen(smsdata) < 151)                                   //check it if greater than 151
         sms.SendSMS(numberRx, "Message received");      //send reply
         strcpy( storage, smsdata );                               //store the message
       else        //if greater
      sms.SendSMS(numberRx, "Max char reached");        //send reply
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
