Topic: Smartec UTI (Read 3554 times) previous topic - next topic
PeterT
Hi!
I need help im trying to read the values from Smartec UTI (http://server3.uswdh.com/~myfavou/intl/docs/dsuti.pdf) with 3 PT1000 connected to it.
The signal from the UTI looks like this:
But the values im getting looks like this:
19856      19857      19876      19881      19860      19893
the code im using for now is:
Code: [Select]
#include <stdio.h>
#define UTI_PIN 5
#define UTI_RESISTANCE_REF 1000
 pinMode(UTI_PIN, INPUT);
 int i=0,x=0;
 long total=0;
 int values[12];
 while(i<12) {
   values[i]=pulseIn(UTI_PIN,HIGH);
   values[i]+=pulseIn(UTI_PIN,LOW);
   i++;
 while(x<12){
   Serial.print(values[x]);
   Serial.print("\t");
   total+=values[x];
   x++;
 Serial.print(" = ");
 Serial.print(total);
 Serial.print("\n");
 delay(2000);
/PeterT
PeterT
This is the connections i have made:
PeterT
Can somebody help me?
weirdo557
did you connect pin 8 to ground?
PeterT
No isnt pin 8 power supply?
PeterT
Ok Vss is negative power supply = GND i did not know that, but i get exactly the same values!
PeterT
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&p=268826 this is someone who uses avr tor read the output from UTI
PeterT
The values should look something like this:
Code: [Select]
9933 9938 30212 31151 19881
PeterT
Isnt there anyone who knows what im doing wrong?
PeterT
Finally got it working :)
Code: [Select]
#include <stdio.h>
#include "pins_arduino.h"
#define UTI_PIN 5
 double res1,res2,res3;
  if(ReadUTI(UTI_PIN,&res1,&res2,&res3,UTI_RESISTANCE_REF)) {
     Serial.print("Resistance 1: ");
     Serial.print(res1);
     Serial.print("\t");
     Serial.print("Resistance 2: ");
     Serial.print(res2);
     Serial.print("\t");
     Serial.print("Resistance 3: ");
     Serial.print(res3);
     Serial.print("\t");
   else {
     Serial.print("Not Found");
   Serial.print("\n");
  delay(2000);
int ReadUTI(uint8_t pin, double * res1,double * res2,double * res3,int refRes)
   int state = HIGH;
   int i,startindex=-1;
   uint8_t bit = digitalPinToBitMask(pin);
   uint8_t port = digitalPinToPort(pin);
   uint8_t stateMask = (state ? bit : 0);
   unsigned long width[12] = {0,0,0,0,0,0,0,0,0,0,0,0};
   double nOff=0,nAB=0,nCD=0,nBC=0,nDF=0;
   while ( (*portInputRegister(port) & bit) != stateMask)
   for(i=0;i<12;i++) {
     while ( (*portInputRegister(port) & bit) == stateMask)
         width[i]++;
         width[i]++;
   for(i=1;i<12;i++) {
     if(i<7) {
       if(width[i]<width[i+2]&&width[i]<width[i+3]&&width[i]<width[i+4]&&width[i]<width[i+5]&&width[i+1]<width[i+2]&&width[i+1]<width[i+3]&&width[i+1]<width[i+4]&&width[i+1]<width[i+5]) {
         startindex=i;
         i=12;
   if(startindex!=-1) {
     nOff=width[startindex]+width[startindex+1];
     nAB=width[startindex+2];
     nCD=width[startindex+3];
     nBC=width[startindex+4];
     nDF=width[startindex+5];
     *res1=((nBC-nOff)/(nAB-nOff))*refRes;
     *res2=((nCD-nOff)/(nAB-nOff))*refRes;
     *res3=((nDF-nOff)/(nAB-nOff))*refRes;
     return 1;
   else {
     return 0;
zgon81
Hi PeterT
Can you please comment your code a little bit? I am also interested in using the UTI in my project and I would like to understand your code better...
Why there is a stateMask = (state ? bit : 0)? It is always = bit...
regards
PeterT
I dont really understand that statemask part myself i saw that in another function and just used it in my code.
Code: [Select]
   int state = HIGH;
   uint8_t stateMask = (state ? bit : 0); //State HIGH
   while ( (*portInputRegister(port) & bit) != stateMask) //While state is LOW
   for(i=0;i<12;i++) { //Count 12 cycles so you are sure you get the whole.
     while ( (*portInputRegister(port) & bit) == stateMask) //Count the HIGH time
         width[i]++;
     while ( (*portInputRegister(port) & bit) != stateMask) //Count the LOW time and add them together
         width[i]++;
   for(i=1;i<12;i++) { //Find the Index for Toff cycle
     if(i<7) {
         startindex=i;
         i=12;
     //Save the cycles (Makes it easier to know what you are calculating
     //Do the calculations according to the UTI manual.
     return 1; //Return 1 if the cycles where found
   else {
     return 0;
zgon81
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
