Topic: Not enough I/O pins (Read 2670 times) previous topic - next topic
specialedster
Jun 21, 2010, 08:11 am Last Edit: Jun 21, 2010, 08:13 am by specialedster Reason: 1
Hey all,
I recently decided to take my first dive into the arduino pool and have come up with what I thought was a fairly simple project.  However, after pondering on the details for a short time I realized I might have more work ahead of me than I thought.  The problem is that I need to be able to read analog input from 10 different photocells and use that information to control the output of 10 corresponding digital I/O pins. This is a problem since the arduino only has 6 analog input pins.  I thought for a bit that I could multiplex the inputs using a 3/8 multiplexer, but that would require the use of 3 digital I/O pins, thereby leaving me at least 1 short in that department since there are only 12 available to begin with.
I guess my question is, short of getting another board is there any way to have read so many inputs and still have control over so many outputs individually?
EDIT: I should also mention that the digital I/O pins are to be driving individual transistors which are in turn driving 6 LED's each.
Jeremy1998
google: "analog to digital converter"
MikMo
Use a cd4051 analog mux to get 8 more analog ins (at the cos of one aanalog and 3 digital pins).
If you still need more digital outs use 74hc595 shiftregisters to add more.
tkbyd
A RBBB Arduino clone (http://www.moderndevice.com/) kit costs $12.50 + very reasonable p&p. Easy to assemble, and if you don't want to assemble, assembled units are also available.
Could your project be done simply by using two Arduinos?
leppie
#4
Jun 21, 2010, 10:35 am Last Edit: Jun 21, 2010, 10:35 am by leppie Reason: 1
MCP23xxx series  8/16 port(pin really) I/O expanders. I2C or SPI.
Grumpy_Mike
For analogue multiplexing see this project:-
http://www.thebox.myzen.co.uk/Hardware/MIDI_Footsteps.html
For extra I/O with fast access use the MCP23S17 - 16 extra I/O and you can use up to 8 of them directly giving up to 128 digital I/O.
leppie
Quote
I'm so badly trying to get hold of them, but RS has no stock currently...  :(
leppie
Quote
Farnell have 457 in stock:-
Pity that I am in South Africa.  Should have asked the English football team to bring me some   ::)
bastukee
#10
Jun 21, 2010, 04:06 pm Last Edit: Jun 21, 2010, 04:07 pm by bastukee Reason: 1
Why not use 2 or more Arduinos to do this?
No trees were harmed by the transmission of this message. However a few million electrons were temporarily inconvenienced.
Ron C
Not sure how quick shipping would be to you from Taiwan (it took about 10 days to Kentucky in the US),
but Futurlec has the MCP23S17 for $1.35 US.
http://www.futurlec.com/cgi-bin/search/qty_price.cgi?part_no=MCP23S17
macegr
I've got the I2C version of that chip already built up into a shield: Centipede Shield
Though the default Arduino I2C speed is 100KHz, it's still pretty fast. We've had no problems detecting lots of simultaneous button presses just by polling, not even bothering with the interrupt and latch feature. The MCP23017 can support up to 1.7MHz I2C so there is room to tweak the Arduino I2C implementation if more speed is really needed.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
leppie
Quote
I got a couple of MCP23016's.
Mine runs pretty good at 400khz, after I tweaked the Wire libs.
With a few other I2C devices, I had to drop it to 300khz though.
leppie
Finally found the local distributors for Farnell. Pretty close to me in fact.
Thanks Grumpy_Mike  :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
