Topic: Using extra serial pins on mega board (Read 2413 times) previous topic - next topic
Bruce H
This may be a dumb question, but in order to use RX/TX1, RX/TX2 and RX/TX3 on a mega board do I use the software serial library?  I guess I get confused when people say the mega board has 3 extra sets of RX/TX pins, but as far as I can tell, I don't see any way to access those extra pins using the normal serial library or even anything to say whether the atmel chip treats those pins any differently than any other pins.
mem
#1
May 08, 2009, 02:40 pm Last Edit: May 08, 2009, 02:41 pm by mem Reason: 1
You access it using the hardware serial library using the following names for the ports:
[font=Courier New]
Port Name   Transmit Pin       Receive Pin
Serial          1(Also USB)        0 (Also USB)
Serial1         18                 19
Serial2         16                 17
Serial3         14                 15
[/font]
aboxdc
Is it possible to use serial1 instead of serial to load program? I would like to use one serial for xbee, other for usb and third for gps... But both serials    ( serial and serial 1 ) should be for program loading into arduino mega.
Thank you in advance for help
D.
Hallicarnassus
You can't have anything plugged into Serial when uploading firmware, figured that out after trying to use a Sparkfun BlueSmirf serial adaptor to upload code wirelessly (would have been cool but it doesn't work).
Graynomad
#5
Aug 09, 2010, 03:53 am Last Edit: Aug 09, 2010, 03:56 am by graynomad Reason: 1
Quote
In theory yes, but you'd have to modify the boot loader. But with an extra 3 ports is there any need to?
Rob Gray aka the GRAYnomad www.robgray.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
