Topic: rotary encoder limiting (Read 4459 times) previous topic - next topic
thereyouare
How to limit the newposition between 0 to 4?
I don't want it to count bigger than 4 and count smaller than 0
Code: [Select]
#include <Encoder.h>
Encoder myEnc(5, 6);
  pinMode(9, OUTPUT);
    pinMode(10, OUTPUT);
      pinMode(11, OUTPUT);
        pinMode(12, OUTPUT);
  Serial.println("Basic Encoder Test:");
long oldPosition  = -999;
  long newPosition = myEnc.read();
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
   if (newPosition ==1)
  digitalWrite(9,LOW);
digitalWrite(10,LOW);
digitalWrite(11,LOW);
digitalWrite(12,HIGH);
if (newPosition ==2)
digitalWrite(11,HIGH);
digitalWrite(12,LOW);
if (newPosition ==3)
digitalWrite(10,HIGH);
if (newPosition ==4)
digitalWrite(9,HIGH);
jremington
#1
Jan 07, 2014, 12:50 am Last Edit: Jan 07, 2014, 04:11 am by jremington Reason: 1
if counting forwards, use
if (newPosition > 4) newPosition = 0;
if counting backwards, use
if (newPosition < 0) newPosition = 4;
thereyouare
#2
Jan 07, 2014, 09:12 am Last Edit: Jan 07, 2014, 11:35 am by thereyouare Reason: 1
Thanks but still having a problem.I have used this.
Code: [Select]
if (newPosition > 4) newPosition = 4;
if (newPosition < 0) newPosition = 0;
It doesn't print bigger than 4 but it counts.When I turn the knob 10 steps forward,in serial monitor arduino prints  "1,2,3,4,4,4,4,4,4,4"   .It's OK.But from that position ,when I turn the knob 10 steps backward,arduino prints "4,4,4,4,4,4,4,3,2,1." instead of  "4,3,2,1,0,0,0,0,0,0".
How to resume counting if it is bigger than 4 or smaller than 0?
elac
Try this:
Code: [Select]
/* interrupt routine for Rotary Encoders
The average rotary encoder has three pins, seen from front: A C B
Clockwise rotation A(on)->B(on)->A(off)->B(off)
CounterCW rotation B(on)->A(on)->B(off)->A(off)
and may be a push switch with another two pins, pulled low at pin 8 in this case
// usually the rotary encoders three pins have the ground pin in the middle
enum PinAssignments {
  encoderPinA = 2,   // right (labeled DT on our decoder, yellow wire)
  encoderPinB = 3,   // left (labeled CLK on our decoder, green wire)
  clearButton = 8    // switch (labeled SW on our decoder, orange wire)
                // connect the +5v and gnd appropriately
volatile byte encoderPos = 0;  // a counter for the dial
byte lastReportedPos = 1;   // change management
static boolean rotating = false;    // debounce management
// interrupt service routine vars
boolean A_set = false;
boolean B_set = false;
int pressCount = 0;
  pinMode(encoderPinA, INPUT_PULLUP); // new method of enabling pullups
  pinMode(encoderPinB, INPUT_PULLUP);
  pinMode(clearButton, INPUT_PULLUP);
  pinMode(9, OUTPUT);
  pinMode(13, OUTPUT);
  // turn on pullup resistors (old method)
  //digitalWrite(encoderPinA, HIGH);
  // digitalWrite(encoderPinB, HIGH);
  // digitalWrite(clearButton, HIGH);
  // encoder pin on interrupt 0 (pin 2)
  attachInterrupt(0, doEncoderA, CHANGE);
  // encoder pin on interrupt 1 (pin 3)
  attachInterrupt(1, doEncoderB, CHANGE);
  Serial.begin(9600);  // output
// main loop, work is done by interrupt service routines, this one only prints stuff
  rotating = true;  // reset the debouncer
  if (lastReportedPos != encoderPos) {
    Serial.print("Index:");
    Serial.println(encoderPos, DEC);
    lastReportedPos = encoderPos;
  if (digitalRead(clearButton) == LOW )  {
    /*delay(300);
     pressCount ++;
     //Reset count if over max mode number
     if(pressCount > 2)
     pressCount = 0;
     switch (pressCount) {
     case 0:
     digitalWrite(13, LOW);
     case 1:
     analogWrite(9,25);
     case 2:
     analogWrite(9,0);
     digitalWrite(13, HIGH);
    encoderPos = 0;
  switch (encoderPos) {
    case 0:
      digitalWrite(9, LOW);
    case 1:
    case 2:
      digitalWrite(9, HIGH);
    case 3:
// Interrupt on A changing state
void doEncoderA() {
  // debounce
  if ( rotating ) delay (1);  // wait a little until the bouncing is done
  // Test transition, did things really change?
  if ( digitalRead(encoderPinA) != A_set ) { // debounce once more
    A_set = !A_set;
    // adjust counter + if A leads B
    if ( A_set && !B_set && encoderPos != 5)
      encoderPos += 1;
    if ( A_set && !B_set && encoderPos == 5)
      encoderPos = 0;
    rotating = false;  // no more debouncing until loop() hits again
// Interrupt on B changing state, same as A above
void doEncoderB() {
  if ( digitalRead(encoderPinB) != B_set) {
    B_set = !B_set;
    //  adjust counter - 1 if B leads A
    if ( B_set && !A_set && encoderPos == 0)
      encoderPos = 5;
    if ( B_set && !A_set )
      encoderPos -= 1;
    rotating = false;
Works well for limiting encoder, sketch is set for a limit of 4.
Check on serial monitor.
It's all about the skills
3dprinter
#4
Jan 08, 2014, 09:15 pm Last Edit: Jan 08, 2014, 09:53 pm by Msquare Reason: 1
I always get nervous when people who have not mastered the intricacies of the "%" operator (modulus) and are sensible enough to use a nice library which hides some complications are given long code to do interrupts.
Try
Code: [Select]
for ( int i = 0; i<20; i++ )
Serial.print(i%5) ;
To get rid of negative numbers use the abs() function
3dprinter
Oh, I forgot, if you did want to have a ceiling/floor type functionality use the constrain() function
Code: [Select]
Serial.print(constrain(i,0,4));
You question about "Limiting it between 0 and 4" is a ambigious.
jremington
Quote
Evidently, the library code is incrementing some variable other than newPosition, then returning the result. To fix that you will have to modify the original library code. Find the place where the position variable is incremented or decremented in response to each impulse from the encoder. That is where you want to impose limits on the position. For example, if the code has something like
Code: [Select]
  position++;
you can add a line as follows:
Code: [Select]
  position++;
  (if position>4) position = 4;
Similarly for the decrement.
thereyouare
Try this:
Code: [Select]
int pressCount = 0;
  pinMode(9, OUTPUT);
    /*delay(300);
     pressCount ++;
     if(pressCount > 2)
     pressCount = 0;
     case 0:
     case 1:
     analogWrite(9,25);
     case 2:
     analogWrite(9,0);
    encoderPos = 0;
    case 0:
    case 1:
    case 2:
    case 3:
void doEncoderA() {
  // debounce
    A_set = !A_set;
      encoderPos += 1;
      encoderPos = 0;
void doEncoderB() {
    B_set = !B_set;
      encoderPos = 5;
      encoderPos -= 1;
    rotating = false;
This script  resets counter to 0 if it is bigger than 4.It isn't what I want  but  a little modification it works like a charm.
Code: [Select]
  encoderPinA = 3,   // right (labeled DT on our decoder, yellow wire)
  encoderPinB = 2,   // left (labeled CLK on our decoder, green wire)
  clearButton = 12    // switch (labeled SW on our decoder, orange wire)
int pressCount = 0;
  pinMode(4, OUTPUT);
  pinMode(A2, OUTPUT);
    pinMode(A3, OUTPUT);
  if (digitalRead(clearButton) == HIGH )  {
    /*delay(300);
     pressCount ++;
     if(pressCount > 2)
     pressCount = 0;
     case 0:
     case 1:
     analogWrite(9,25);
     case 2:
     analogWrite(9,0);
    encoderPos = 0;
    case 0:
         digitalWrite(4, HIGH);
      digitalWrite(A2, LOW);
      digitalWrite(A3, LOW);
    case 1:
    case 2:
      digitalWrite(4, LOW);
      digitalWrite(A2, HIGH);
    case 3:
      digitalWrite(A3, HIGH);
void doEncoderA() {
  // debounce
    A_set = !A_set;
      encoderPos += 1;
      encoderPos = 4;
void doEncoderB() {
  // debounce
  if ( digitalRead(encoderPinB) != B_set ) { // debounce once more
    B_set = !B_set;
    if ( !A_set && B_set && encoderPos != 0)
      encoderPos -= 1;
    if (!A_set && B_set && encoderPos == 0)
      encoderPos = 1;
Thank you very much. :)
Jaxon_Shredda
I managed this with the following code:
Code: [Select]
 while(newPosition != oldPosition) { // only do stuff if something changed
   if (newPosition > oldPosition) {  // one of two options, up or down, pick one
     relativePosition += 1;          // it went up
   else {
       relativePosition -= 1;        // it went down
   if (relativePosition > 7)  {      // did we reach our + limit? - Could use a variable here
      relativePosition -= 1;         // reset the position to just one before our limit
   if (relativePosition < -7) {      // did we reach our - limit? - Could also use a variable here
      relativePosition += 1;         // reset the position to just one before our limit
   Serial.println(relativePosition);
Jaxon_Shredda
Cleaned it up a bit more:
Code: [Select]
/* Input Encoder Limiting Example
Encoder myEnc(2, 3);                          // Sets input pins on input encoder
int tickLimit = 10;                           // Maximum we want to go with the input encoder in either direction
long oldPosition  = 0;                        // Referance for manual encoder positioning comparisons
long relativePosition = 0;                    // Pointer for ticks that fall in the tickLimit window
  long newPosition = myEnc.read();            // Get the current position of the manual encoder
  while (newPosition != oldPosition) {        // only adjust output if input changed
      if (relativePosition != tickLimit)  {   // did we reach our positive tick limit?
        relativePosition += 1;                // it went up so bump the relative position up by one tick
    else {
      if (relativePosition != -tickLimit) {   // did we reach our negative tick limit?
        relativePosition -= 1;                // it went down so bump the relative position down by one tick
    oldPosition = newPosition;                // Reset the oldPosition referance
