Topic: i2c LCD Display (Read 23552 times) previous topic - next topic
dwentz
Mar 04, 2009, 11:03 pm Last Edit: Mar 05, 2009, 03:13 pm by dwentz Reason: 1
For those of you that are interested, I have created a library for the i2c LCD display that is available from web4robot.com. I have not financial interest in web4robot, I purchased one of their displays, and thought it would be nice to have a library.
The following commands are supported.
init()                              Init the LCD and library functions, Clears the display, turns off the cursors
commandWrite(command)      Write a command not supported yet in the library to the display
position(Row, Column)      Move the cursor to position valid range is Row[0-3], Column[0,19]
print(char)                        Send the single character char to the display at the cursor position.
println(string)                  Send the String to the display at the cursor position.
clear()                        Clear the display and place the cursor at 0,0
home()                        Home the cursor to 0,0 but do not clear the display
on()                              Turn the LCD display on
off()                              Turn the LCD display off
cursor_on()                  Turn the blinking line cursor on
cursor_off()                  Turn the blinking line cursor off
blink_on()                        Turn the blinking block cursor on
blink_off()                        Turn the blinking block cursor on
left()                              Move the cursor to the left
right()                        Move the cursor to the right
keypad()                        Read a value from the keypad. Returns 0 if no key press is in the buffer
Dale
I forgot to add a link to my webpage that has the library.
http://www.wentztech.com/radio/arduino/projects.html
Nachtwind
Believe me, Mike, I calculated the odds of this succeeding against the odds I was doing something incredibly stupid[ch8230] and I went ahead
GordonEndersby
Nice one.
Ive got one of there lcd controlers as well but had trouble getting it working.
May I see your code and give it a try?
Thanks
Gordon
dwentz
Gordon,
 I am sorry I forgot to put the link in when I posted this. I have added it to the bottom of the message. All the source code and samples are included in the zip file.
Dale
GordonEndersby
Thanks,
Ive got a realtime clock on the bench running with I2C. Ill try your library in conjunction with that over the next couple of days.
Gordon
skumlerud
Nice project :-) I've made a similar library myself for the I2C-LCD-driver from ByVac. One suggestion though - you can inherit the print-class so you don't have to implement your own print. This will let you print strings, integers and floats for "free" :-)
GordonEndersby
Guess what Ive got one of those byvac boards as well.
Any chance you can post your library?
Maybe there is some common ground and we can merge the libraries.
I should imagine the main differences will be the command codes and the rest very similar.
They both support keyboard input as well.
Gordon
skumlerud
#7
Mar 07, 2009, 10:08 pm Last Edit: Mar 07, 2009, 10:10 pm by skumlerud Reason: 1
Quote
Sure, no problem. I have only used it for one small project, so it's not tested very well. It does work fine for me, but consider this beta software. It's mostly compatible with LiquidCrystal, and also contains some methods for reading and writing the EEPROM on the controller. This will let you store strings on the controller and enable you to print directly from this, thus saving precious flash on the Arduino.
Btw I also got one of these: http://www.byvac.com/bv/bv4219.htm. I'm in the process of writing a library for this as well.
ByVacLCD.cpp:
Code: [Select]
#include "ByVacLCD.h"
#include <stdio.h>
#include <string.h>
#include <inttypes.h>
#include "WProgram.h"
#include <Wire.h>
#define BACKLIGHT_ON 0
#define BACKLIGHT_OFF 1
#define LCD_ON 1
#define LCD_OFF 0
ByVacLCD::ByVacLCD(uint8_t adr, uint8_t columns, uint8_t rows)
 _adr = adr;
 _columns = columns;
 _rows = rows;
void ByVacLCD::init()
 delay(15);
 command(0x0c); // Display on, cursor off, blink off
 command(0x06); // Increment mode, shift on
 clear();
void ByVacLCD::clear()
 command(0x01);  // clear display, set cursor position to zero
 delayMicroseconds(2000);
void ByVacLCD::home()
 command(0x02);  // set cursor position to zero
void ByVacLCD::setCursor(int col, int row)
 int row_offsets[] = { 0x00, 0x40, 0x14, 0x54 };
 command(0x80 | (col + row_offsets[row]));
void ByVacLCD::command(uint8_t value) {
 send(value, LOW);
void ByVacLCD::write(uint8_t value) {
 send(value, HIGH);
void ByVacLCD::send(uint8_t value, uint8_t mode) {
 Wire.beginTransmission(_adr);
 if (mode) // Write data
   Wire.send(2);
 else      // write command
   Wire.send(1);
 Wire.send(value);
 Wire.endTransmission();
 delayMicroseconds(45);
void ByVacLCD::backlightOn()
 Wire.send(3);
 Wire.send(BACKLIGHT_ON);
void ByVacLCD::backlightOff()
 Wire.send(3);
 Wire.send(BACKLIGHT_OFF);
void ByVacLCD::displayOn()
 Wire.send(5);
 Wire.send(LCD_ON);
void ByVacLCD::displayOff()
 Wire.send(5);
 Wire.send(LCD_OFF);
// Upload a user-defined character (5x8)
// See http://www.quinapalus.com/hd44780udg.html for
// character generator.
void ByVacLCD::uploadUdef(uint8_t character, uint8_t *data)
 uint8_t c = character << 3, i;
 for (i = 0; i < 8; i++)
   command(0x40 | c | i);
   write((uint8_t)data[i]);
void ByVacLCD::printFromEEPROM(uint8_t addr)
 Wire.send(4);
 Wire.send(addr);
uint8_t ByVacLCD::EEPROM_startAdr()
 Wire.send(6);
 Wire.requestFrom((int)_adr, 1);
 if (Wire.available() == 1)
   return Wire.receive();
 return 0;
uint8_t ByVacLCD::EEPROM_endAdr()
 Wire.send(0x93);
 return 0;
uint8_t ByVacLCD::EEPROM_read(uint8_t addr)
 Wire.send(0x90);
 Wire.send(addr);
   return (byte)Wire.receive();
 return 0;
void ByVacLCD::EEPROM_write(uint8_t addr, char *data)
 Wire.send(0x91);
 Wire.send(addr);
 Wire.send(data);
 Wire.send('\0');
void ByVacLCD::EEPROM_write(uint8_t addr, char data)
 Wire.send(0x91);
 Wire.send(addr);
 Wire.send(data);
Code: [Select]
** Library for the ByVac BV4208 I2C-driver for HD44780 LCD displays.
** See www.byvac.com for datasheet.
#ifndef ByVacLCD_h
#define ByVacLCD_h
#include "Print.h"
class ByVacLCD : public Print {
public:
 ByVacLCD(uint8_t, uint8_t, uint8_t);
 void init();
 void clear();
 void home();
 void setCursor(int, int);
 virtual void write(uint8_t);
 void command(uint8_t);
 void backlightOn();
 void backlightOff();
 void displayOn();
 void displayOff();
 void uploadUdef(uint8_t, uint8_t*);
 void printFromEEPROM(uint8_t);
 uint8_t EEPROM_startAdr();
 uint8_t EEPROM_endAdr();
 uint8_t EEPROM_read(uint8_t addr);
 void EEPROM_write(uint8_t addr, char *data);
 void EEPROM_write(uint8_t addr, char data);
private:
 void send(uint8_t, uint8_t);
 uint8_t _adr;
 uint8_t _columns;
 uint8_t _rows;
#endif
keywords.txt:
Code: [Select]
# Syntax Coloring Map For ByVacLCD
# Datatypes (KEYWORD1)
ByVacLCD      KEYWORD1
# Methods and Functions (KEYWORD2)
init      KEYWORD2
clear      KEYWORD2
home      KEYWORD2
print      KEYWORD2
setCursor      KEYWORD2
backlightOn      KEYWORD2
backlightOff      KEYWORD2
displayOn      KEYWORD2
displayOff      KEYWORD2
uploadUdef      KEYWORD2
printFromEEPROM      KEYWORD2
write      KEYWORD2
command      KEYWORD2
EEPROM_startAdr      KEYWORD2
EEPROM_endAdr      KEYWORD2
EEPROM_read      KEYWORD2
EEPROM_write      KEYWORD2
# Constants (LITERAL1)
Ran Talbott
Perfect timing,  Dale:  I just got mine a few days ago,  and was lamenting the lack of a driver   ;)
Are you planning to do further development on it?  I'm interested in adding code support its bargraph and custom character features,  and would like to coordinate development with you  if you're going to be changing code.
Thanks,
Ran
dwentz
I have updated the drivers for the i2c LCD's
I have changed some of the commands to bring them in line with the crystal drivers. They have been optimized, for speed and code size. I have also inherited the print-class as recommended in this thread so you can do things like lcd.print(int,DEC)
I am willing to support other intelligent i2c LCD character displays within the library, if you manufacture a display and would like to send me a sample to write and test with please contact me.
i2c Library home: http://www.wentztech.com/radio/arduino/files/LCDI2C.html
Dale
jener8tionx
great!  I am using the original library with my 20X4 display....works great.
fortynine
Hello, I have got the LCD 4x20 display, LCD03 - I2C, from robot-electronics.co.uk. The display is working well, after some testing, but not the keypad that is interfaced on backside of the display. Is there anyone who have got the keypad at LDC03 working on I2C?
Ran Talbott
The docs for that Robot Electronics module say that the keypad only works in serial mode,  so the answer to your question is almost certainly "no".
Ran
Ran Talbott
I've written some new routines to use the graph features of the web4robot module,  and am testing them now.  I should have them ready for release in the next day or so.
I've written one example program that reads the values of the analog inputs and graphs them.  Does anyone have suggestions for other examples?
Ran
dwentz
Ran,
 If you would send me your code and I will include them in the library.
I have received a 4 line display, and have tested it with the library. It works as is, but I have some changes that I want to make to make things more universal.
Dale
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
