Topic: Arduino + PING(( + MotorDriver (Quad Half HBridge) (Read 2869 times) previous topic - next topic
jiggles
G'day all,
Currently experimenting with Motor Drivers and PING(( together and new to the self experimentation. Have hit a problem and wondering if anybody knows where.
Problem:
-PING and MOTOR drivers work fine, until a second motor is added to the motor driver.
-Once 2nd motor added to circuit, The PING sensor starts to give false readings, and the motors do not run even if directly told to.
-Once removing the 2nd motor, circuit starts functioning correctly again.
Assumed cause: Power
How to fix:
-This is where i am stuck. Any suggestions or recommendations would be very helpful.
MAJOR PARTS USED:
-Arduino Duemilanove (ATMEGA328)
-Parallax PING Sensor
-SN754410 QUAD HALF-H DRIVER
---Sorry, unable to attach links to datasheets
The following may help; Code, Fritzing Image.
Code: [Select]
/* Autonomous Robot - Created By Carlin (Jiggles)
Last Modified 24/06/2010
-Coding Credits (Why re-invent the wheel?)
 +Ping))) Sensor - David A. Mellis & Tom Igoe
// ***** DEFINING VARIABLES to PIN NUMBERS *****
const int pingPin = 7;            // This constant won't change.  It's the pin number of the sensor's output:
int ledpin_ok = 3;                // Green Led to visually display returned value of ping sensor.
int ledpin_close = 2;             // Red Led to display if PING Value is "Too Close" to an object.
int motor_ONE_pin_ONE=6;          // Defines Arduino pin#6 to the pin connected to Motor Driver (PWM Pin)
int motor_ONE_pin_TWO=5;          // Defines Arduino pin#5 to the pin connected to Motor Driver (PWM Pin)
int motor_TWO_pin_ONE=9;          // Defines Arduino pin#9 to the pin connected to Motor Driver (PWM Pin)
int motor_TWO_pin_TWO=10;         // Defines Arduino pin#10 to the pin connected to Motor Driver (PWM Pin)
// ***** VOID SETUP - Self Explanitory *****
 Serial.begin(9600);                    // Initialize serial communication:
 pinMode(ledpin_ok, OUTPUT);            // Define Green Led as OUTPUT
 pinMode(ledpin_close, OUTPUT);         // Define Red Led as OUTPUT
 pinMode(motor_ONE_pin_ONE,OUTPUT);     // Define Motor1pin1 as OUTPUT
 pinMode(motor_ONE_pin_TWO,OUTPUT);     // Define Motor1pin2 as OUTPUT
 pinMode(motor_TWO_pin_ONE,OUTPUT);     // Define Motor2pin1 as OUTPUT
 pinMode(motor_TWO_pin_TWO,OUTPUT);     // Define Motor2pin2 as OUTPUT
// ***** VOID LOOP - Self Exlpanitory *****
 long duration, cm; // Define variables for duration of the ping and the distance result in centimeters:
 // *** PING CODE***
 // The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
 pinMode(pingPin, OUTPUT);             //PING Pinmode has
 digitalWrite(pingPin, LOW);           // LOW pulse beforehand to ensure a clean HIGH pulse:
 delayMicroseconds(2);
 digitalWrite(pingPin, HIGH);          // HIGH PULSE for Signal
 delayMicroseconds(5);
 digitalWrite(pingPin, LOW);           // Low pulse Afterwards
 pinMode(pingPin, INPUT);                    // Reconfigure PING Pin as INPUT to recieve Pulse already sent.
 duration = pulseIn(pingPin, HIGH);          // Give PING value to Duration Variable of result
 cm = microsecondsToCentimeters(duration);   // convert the time into a distance
 //EVENTS FOR PING VALUE
 Serial.print(cm);       //Serial Monitor shows/prints value of variable "cm"
 Serial.print("cm");     //Serial Monitor shows/prints words "cm"
 Serial.println();       //Serial Monitor goes to next line
 if (cm <= 10) {                       //Determines if sensor is too close to object
   digitalWrite(ledpin_close,HIGH);    //Red Led on - Visual Status of Reading
   digitalWrite(ledpin_ok,LOW);        //Green Led off - Visual Status of Reading
   drive_stop();                       //*FUNCTION CALL - DRIVE STOP
 }else{
   digitalWrite(ledpin_close,LOW);     //Red Led off - Visual Status of Reading
   digitalWrite(ledpin_ok,HIGH);       //Green Led on - Visual Status of Reading
   drive_forward();                    //*FUNCTION CALL - DRIVE FORWARD
 } //END OF IF (cm<=10) STATEMENT
 delay(100);
//***************************FUNCTIONS / SUB ROUTINES********************************
------- CONVERSION FUNCTIONS -------
long microsecondsToCentimeters(long microseconds)
 // The speed of sound is 340 m/s or 29 microseconds per centimeter.
 // The ping travels out and back, so to find the distance of the
 // object we take half of the distance travelled.
 return microseconds / 29 / 2;
------- DRIVE FUNCTIONS -------
//Forward
void drive_forward(){
 digitalWrite(motor_ONE_pin_ONE,HIGH);
 digitalWrite(motor_TWO_pin_ONE,HIGH);
 return;
//Stop
void drive_stop() {
 digitalWrite(motor_ONE_pin_ONE,LOW);
 digitalWrite(motor_TWO_pin_ONE,LOW);
 digitalWrite(motor_ONE_pin_TWO,LOW);
 digitalWrite(motor_TWO_pin_TWO,LOW);
 return;
//Reverse   - Not yet being Used
void drive_reverse(){
 digitalWrite(motor_ONE_pin_TWO,HIGH);
 digitalWrite(motor_TWO_pin_TWO,HIGH);
 return;
Fritzing Image:
- Cant post image
Thankyou in advance :)
4defcon
Hi I am having a similar issue with Ping giving false readings, have you tried putting supression capacitors across your motors + and - terminals to avoid noise getting back into your circuit?
jiggles
G'day,
Thanks for reply. Fixed this one a couple of days ago.
Solution:
-Independent motor power source added (Into PIN8 - [Vcc2] ), solved motor issue
-Caps across the DC motors solved the PING incorrect readings.
4defcon
No worries.  Glad the capacitors sorted your PING issue out, that was one was driving me nuts! :)
Grumpy_Mike
Quote
Just for reference cause was power supply decoupling - lack of
http://
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
sirknroc
Hi Jiggles, I have similar project also have problem at ping reading. Can you post the fixed fritzing image, how you wire the caps and motors.
pocketscience
Quote
You simply place a cap across the motor terminals - nothing fancy.
G.
sirknroc
Hello guys, this thread really help me solved my problem. Now I can get correct readings on my sensors :D Thanks!
Da5id
I'm working on basically the same thing right now, I was wondering where you hooked up the power source for the motors? Mine can't seem to draw enough power from the arduino to turn the wheels and the treads. A revised fritzing would be great :)
