Topic: Interfacing Arduino with 3.3V Parallax Propeller (Read 2791 times) previous topic - next topic
fj604
Hi all,
I would like to use the Parallax Propeller Demo Board as an video controller for Arduino. The Propeller chip uses 3.3V logic - what is the safe way to interface it with 5V Arduino? Is it just a matter of adding a 1K resistor between Arduino output and Propeller input?
fj604
Hi Richard,
Thanks for your reply - this will stop me from looking for cheap solutions for this :)
fj604
#2
Dec 11, 2010, 07:59 pm Last Edit: Dec 11, 2010, 08:01 pm by fj604 Reason: 1
Richard,
Thank you for pointing me to the right direction:
http://en.wikipedia.org/wiki/Voltage_divider
Is it safe to connect Arduino ground to Propeller ground if they are powered by different sources?
PaulS
Quote
Safe and essential.
fj604
I checked - 3.3V to 5V direction works without any additional components such as BSS138 - Arduino properly sees 3.3V as HIGH.
For the 5V to 3.3 direction I will add a voltage divider with two 10K resistors.
PaulS
Quote
Check whether this is really necessary. Many 3.3V devices are 5V tolerant of input signals.
fj604
I have tested it with two a voltage divider (2 x 11k resistors) on 5V input to Propeller - and it works :)
The Propeller chip does not like 5V input at higher currents - it can get warm:
http://forums.parallaxinc.com/forums/default.aspx?f=25&m=124837
Thanks to everyone for suggestions.
