Topic: 7 Segment Display with NewSoftSerial (Read 3927 times) previous topic - next topic
sys_spud
This is a follow-up to a post in the 7 Segment Display with SPI (different thread): http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1247533060/2#2. I'm starting a new thread in case people wanted to see how to use the TTL Serial input side of the SparkFun LED Serial Breakout Board (http://www.sparkfun.com/commerce/product_info.php?products_id=9230).
Wiring is easy, GND, Vcc and Rx from pin 3 of arduino. Code is also easy, just send Serial.print statements, or mySerial.print statements in this example. Remember to send four print statements to fill out all four digits in the display, see the SFE docs for details.
Hint: for controlling the output, the ASCII Table is your friend - http://www.asciitable.com/
The code example is for an XBee temperature monitor receiving module. I wanted to be able to print the temps out with Serial.print statements and also send the temps to the LED display via mySerial.print statements.
Not the best code in the world, and if you have helpful hints, they're appreciated. Be gentle, I'm a noob.
Code: [Select]
// NOTES:
// Using SparkFun Serial LED with XBee receiver
//      2009-08-03
#include <NewSoftSerial.h>
NewSoftSerial mySerial(2, 3);      // Tx from arduino is pin 3, connect to Rx on SFE LED Serial
// following variables for receiving XBee Serial info and displaying them
byte incomingByte;
int j =0;
int prtout = 0;            // flag to know when to send to LED display
int digitcnt = 0;      // count the number of digits in incoming temperature
char temps[5];          // temperature array
// start serial port at 9600 bps
Serial.println("Ready!");
mySerial.begin(9600);
j =0;
prtout =0;      // don't print out until set to 1, then turn off flag immediately
digitcnt = 0;   // count the number of digits of temperature for later use with index j
// Note: Sending XBee transmits temperature in degrees F, terminated by CR and LF (Serial.println(mytemp) on sending XBee)
//      Need to remove the CR/LF or not send it to LED digits
while(Serial.available())       // are there any bytes available on the serial port ???
prtout =1;                          // if bytes available set flag to print them later
incomingByte = Serial.read();        // NOTE: value for temp PLUS CR and LF included in read, see above
temps[j]=(byte(incomingByte));       // store the temperature digits in an array
Serial.print(temps[j]);
j++;
delay(200);                  // achieved experimentally - need some kind of delay between iterations to receive properly
if (prtout)
 digitcnt = j-2;       // digitcnt holds the highest used index value for temp digits + 1 for use as conditional stop statement, ignore CR and LF
     if (digitcnt == 3)
     { mySerial.print("x");}
     if (digitcnt == 2)
   for(j=0;j < digitcnt;j++)
       {Serial.print(temps[j]);   // now print temperature values left-to-right, but right-justified
       mySerial.print(temps[j]);
 Serial.println(" ");
prtout = 0;
3d29
Hi
I'm trying to do something like you did but my display only shows 0000.
Any advices? I got a arduino mega, using analog pin 3 conected to rx in the 7-segment serial display, using 5v from arduino to vcc and gnd from arduino to gnd on display.
Thanks
ps: I didn't solder the wires I'm just using jumper cables. Think maybe that's my problem?
sys_spud
I used digital pin 3, not analog pin 3. The analog pins can also be used as digital input pins: analog 0 through 5 are digital 14 through 19.
See http://www.arduino.cc/en/Tutorial/AnalogInputPins for more information.
You can use analog pin 3 if you want, but you have to refer to it as digital pin 17.
Hope this helps....
3d29
wpongp
Thanks for the example. I am trying to use TTL serial to control my sfe 7 segment display too. In this first stage, I would like to display simple numbers mannually(As it is said, it should be easy).
Below is my code that tried to display "1420" on the board, I could not figure out what's wrong as I am very new to arduino and coding.
//Serial.println("Ready!");
//delay(1000);
Serial.write(0x01);
Serial.write(0x04);
Serial.write(0x02);
Serial.write(0x00);
Your help will be much appreciated.  :)
sys_spud
I think you have your Serial and mySerial switched. mySerial is what you are using to print to the SFE Serial LED, attached to pin 3 in your example.
Your code was:
Code: [Select]
Serial.write(0x01);
Serial.write(0x04);
Serial.write(0x02);
Serial.write(0x00);
Try this instead:
Code: [Select]
mySerial.print(0x01);
mySerial.print(0x04);
mySerial.print(0x02);
mySerial.print(0x00);
Note: ONLY send 4 numbers to the SFE LED. You had a Serial.println(" "); in your code after printing 4 numbers. Don't do that.
Hope this helps.
wpongp
Thank you for your help :), I have changed my code again, but still no luck. Any suggestion?
Code: [Select]
 pinMode(11, OUTPUT);
 Serial.print(0x02);
 Serial.print(0x03);
 Serial.print(0x04);
 Serial.print(0x05);
Rp3
I just did this and it works fine.  I did however have to enter the delay(1000) for the numbers to show correctly, it was off by one digit for some reason, but it works as expected.
Code: [Select]
NewSoftSerial RpSerial(2, 3);    // Tx from arduino is pin 3, connect to Rx on SFE LED Serial
RpSerial.begin(9600);
RpSerial.print(0x01);
RpSerial.print(0x04);
RpSerial.print(0x02);
RpSerial.print(0x00);
About as simple as it can get, RX on the SFE unit is tied to Digital Pin 3.
Hope this helps.   ;D
wesley
Hi, everyone.
I'm having the toughest time communicating with the 7-seg serial display. My MCU is an ATmega8, with Arduino targeting atmega8_noxtal, which I got from todbot (website).
I'm wondering if there's a clocking issue, since I think the atmega8 is 8MHz and all the others are 16MHz.
If I begin the NewSoftSerial port at 9600 baud and then try to send data, I get a display full of zeroes.
If I begin the NewSoftSerial port at 19200 baud, I get gibberish.
Any ideas?
wesley
OK, I'm now even more confident that this is a timing problem. I think the lesson learned is not to try asynchronous TTL serial w/o an external crystal.
Unless someone knows how to make that work...?
2xyo
#10
Aug 16, 2010, 08:39 pm Last Edit: Aug 16, 2010, 08:46 pm by 2xyo Reason: 1
I have this 7 segment Display and i use serial port to display data. I use the following code :
Code: [Select]
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
void setup()  {
 // define pin modes for tx, rx, led pins:
 pinMode(rxPin, INPUT);
 pinMode(txPin, OUTPUT);
 // set the data rate for the SoftwareSerial port
 //set the data rate on 7 segment 0x02 = 9600bps
 delay(100);
 mySerial.print(0x79);
 delay(100);
 // set brightness brighter
 delay(100);
 mySerial.print(0x7A);
 delay(100);
 delay(2000);
 mySerial.print(0x06);
   delay(2000);
 mySerial.print(0x09);
 delay(2000);
 mySerial.print(0x08);
Sometimes, the 7 segment don't display this :
Quote
1664
1496
1988
BUT this :
Quote
6641
4961
9881
There is an offset.. How correct this ? I search a special Commands in datasheet, but i found nothing..
Any help would be appreciate :-)
tkbyd
I have an "How To" essay online about this at....
http://www.arunet.co.uk/tkboyd/ec/ec1led4x7ser.htm
2xyo
Thanks a lot tkbyd !
My code is now :
Code: [Select]
// library
// Pin for 7 segment display
#define rxPin 2
#define txPin 3
void setup()  {
 // set up Serial library at 9600 bps for debug
 Serial.println("Ethylometre v0.01");
 Serial.println("Set pin mode");
 Serial.println("Set data rate for the SoftwareSerial port");
 //v=0x76. To reset display module
 mySerial.print("vv");
 Serial.println("# START Loop");
 displaySeg(1);
 displaySeg(12);
 displaySeg(123);
 displaySeg(1234);
Serial.println("# END Loop");
void displaySeg(int mg) {;
 if(mg < 10) {
   mySerial.print("   ");
   mySerial.print(mg);
 } else if(mg < 100) {
   mySerial.print(mg);
 } else if(mg < 1000) {
   mySerial.print(mg);
   mySerial.print(mg);
   mySerial.print(mg);
Volkemon
#13
Aug 17, 2010, 03:19 am Last Edit: Aug 17, 2010, 03:34 am by Volkemon Reason: 1
[glow]@Wesley-[/glow][/b]
I found out the hard way that software generated serial ports are restricted to 9600. Not sure if that applies to all, but a point to ponder. :)
@tkbyd-
WOW! Nice link. I will have to study that much more. My blue displays come in tomorrow. :)
PaulS
Quote
The NewSoftSerial library supports rates up to 57.6K.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
