Topic: ServoTimer2 - drives up to 8 servos (Read 71886 times) previous topic - next topic
mem
Dec 28, 2008, 04:59 pm Last Edit: Dec 29, 2008, 02:13 am by mem Reason: 1
The following code was posted in a giant thread called 3 axis auto stabilized platform, but it may be difficult to find in the hundreds of posts there.  I will put the code in the playground with a more complete writeup when I can find the time, but for now here is the code. Please do post your comments and suggestons - as well as information on the projects you build using the code.
Have fun!
The library uses Timer2 to drive up to 8 servos using interrupts so no refresh activity is required from within the sketch.
The usage and method naming is similar to the Arduino software servo library http://www.arduino.cc/playground/ComponentLib/Servo
 except that pulse widths are in microseconds not degrees.
 A servo is activated by creating an instance of the Servo class passing the desired pin to the attach() method.
 The servo is pulsed in the background to the value most recently written using the write() method
 Note that analogWrite of PWM on pins 3 and 11 is disabled when the first servo is attached
 The methods are:
  ServoTimer2 - Class for manipulating servo motors connected to Arduino pins.
  attach(pin )  - Attaches a servo motor to an i/o pin.
  attach(pin, min, max  ) - Attaches to a pin setting min and max values in microseconds
   default min is 544, max is 2400
  write()     - Sets the servo pulse width in microseconds.
  read()      - Gets the last written servo pulse width in microseconds.
  attached()  - Returns true if there is a servo attached.
  detach()    - Stops an attached servos from pulsing its i/o pin.
The library takes about 824 bytes of program memory and 32+(1*servos) bytes of SRAM.
The pulse width timing is accurate to within 1%
p.s. here is my list of potential enhancements:
- add method to read and write angle (in as an alternative to  microseconds) axis
- A variant that uses timer1 - offering greater precision and the potential to drive more than eight servos.
mem
#1
Dec 28, 2008, 05:02 pm Last Edit: Dec 28, 2008, 05:04 pm by mem Reason: 1
The following two files should be placed in a directory called ServoTimer2 in the hardware/Libraries directory
ServoTimer2.h
Code: [Select]
 ServoTimer2.h - Interrupt driven Servo library for Arduino using
 This library uses Timer2 to drive up to 8 servos using interrupts so no refresh activity is required from within the sketch.
 except that pulse widths are in microseconds.
 The methods are:
// ensure this library description is only included once
#ifndef ServoTimer2_h
#define ServoTimer2_h
#include <inttypes.h>
typedef uint8_t boolean;
typedef uint8_t byte;
#define MIN_PULSE_WIDTH       750        // the shortest pulse sent to a servo
#define MAX_PULSE_WIDTH      2250        // the longest pulse sent to a servo
#define DEFAULT_PULSE_WIDTH  1500        // default pulse width when servo is attached
#define FRAME_SYNC_PERIOD   20000        // total frame duration in microseconds
#define NBR_CHANNELS 8                   // the maximum number of channels, don't change this
typedef struct  {
     uint8_t nbr        :5 ;  // a pin number from 0 to 31
     uint8_t isActive   :1 ;  // false if this channel not enabled, pin only pulsed if true
  } ServoPin_t   ;
typedef struct {
 ServoPin_t Pin;
 byte counter;
 byte remainder;
}  servo_t;
class ServoTimer2
 public:
     // constructor:
     ServoTimer2();
     uint8_t attach(int);     // attach the given pin to the next free channel, sets pinMode, returns channel number or 0 if failure
                              // the attached servo is pulsed with the current pulse width value, (see the write method)
     uint8_t attach(int, int, int); // as above but also sets min and max values for writes.
   void detach();
   void write(int);         // store the pulse width in microseconds (between MIN_PULSE_WIDTH and MAX_PULSE_WIDTH)for this channel
   int read();                    // returns current pulse width in microseconds for this servo
     boolean attached();      // return true if this servo is attached
private:
      uint8_t chanIndex;      // index into the channel data for this servo
// the following ServoArrayT2 class is not implemented in the first version of this library
class ServoArrayT2
 public:
     // constructor:
     ServoArrayT2();
                              // channels are assigned consecutively starting from 1
   void detach(int);        // detach the servo on the given channel
     void write(int,int);     // store the pulse width in microseconds (between MIN_PULSE_WIDTH and MAX_PULSE_WIDTH)for the given channel
   int read(int);                    // returns current pulse width in microseconds for the given channel
     boolean attached(int);   // return true if the servo on the given channel is attached
private:
#endif
mem
servoTimer2.cpp
Code: [Select]
/* ServoTimer2.cpp*/
extern "C" {
 // AVR LibC Includes
 #include <avr/interrupt.h>
 #include "WConstants.h"
#include <wiring.h>
#include "ServoTimer2.h"
static void initISR();
static void writeChan(uint8_t chan, int pulsewidth);
#define FRAME_SYNC_INDEX   0             // frame sync delay is the first entry in the channel array
#define FRAME_SYNC_DELAY   ((FRAME_SYNC_PERIOD - ( NBR_CHANNELS * DEFAULT_PULSE_WIDTH))/ 128) // number of iterations of the ISR to get the desired frame rate
#define DELAY_ADJUST       8             // number of microseconds of calculation overhead to be subtracted from pulse timings
static servo_t servos[NBR_CHANNELS+1];    // static array holding servo data for all channels
static volatile uint8_t Channel;   // counter holding the channel being pulsed
static volatile uint8_t ISRCount;  // iteration counter used in the interrupt routines;
uint8_t ChannelCount = 0;          // counter holding the number of attached channels
static boolean isStarted = false;  // flag to indicate if the ISR has been initialised
ISR (TIMER2_OVF_vect)
 ++ISRCount; // increment the overlflow counter
 if (ISRCount ==  servos[Channel].counter ) // are we on the final iteration for this channel
     TCNT2 =  servos[Channel].remainder;   // yes, set count for overflow after remainder ticks
 else if(ISRCount >  servos[Channel].counter)
     // we have finished timing the channel so pulse it low and move on
     if(servos[Channel].Pin.isActive == true)           // check if activated
         digitalWrite( servos[Channel].Pin.nbr,LOW); // pulse this channel low if active
       Channel++;    // increment to the next channel
     ISRCount = 0; // reset the isr iteration counter
     TCNT2 = 0;    // reset the clock counter register
     if( (Channel != FRAME_SYNC_INDEX) && (Channel <= NBR_CHANNELS) ){           // check if we need to pulse this channel
            digitalWrite( servos[Channel].Pin.nbr,HIGH); // its an active channel so pulse it high
     else if(Channel > NBR_CHANNELS){
        Channel = 0; // all done so start over
ServoTimer2::ServoTimer2()
  if( ChannelCount < NBR_CHANNELS)
     this->chanIndex = ++ChannelCount;  // assign a channel number to this instance
     this->chanIndex = 0;  // todo      // too many channels, assigning 0 inhibits this instance from functioning
uint8_t ServoTimer2::attach(int pin)
     if( isStarted == false)
      initISR();
     if(this->chanIndex > 0)
      //debug("attaching chan = ", chanIndex);
      pinMode( pin, OUTPUT) ;  // set servo pin to output
      servos[this->chanIndex].Pin.nbr = pin;
      servos[this->chanIndex].Pin.isActive = true;
     return this->chanIndex ;
void ServoTimer2::detach()
   servos[this->chanIndex].Pin.isActive = false;
void ServoTimer2::write(int pulsewidth)
  writeChan(this->chanIndex, pulsewidth); // call the static function to store the data for this servo
int ServoTimer2::read()
 unsigned int pulsewidth;
  if( this->chanIndex > 0)
     pulsewidth =  servos[this->chanIndex].counter * 128 + ((255 - servos[this->chanIndex].remainder) / 2) + DELAY_ADJUST ;
      pulsewidth  = 0;
  return pulsewidth;
boolean ServoTimer2::attached()
   return servos[this->chanIndex].Pin.isActive ;
  // calculate and store the values for the given channel
  if( (chan > 0) && (chan <= NBR_CHANNELS) )   // ensure channel is valid
     if( pulsewidth < MIN_PULSE_WIDTH )                // ensure pulse width is valid
         pulsewidth = MIN_PULSE_WIDTH;
     else if( pulsewidth > MAX_PULSE_WIDTH )
         pulsewidth = MAX_PULSE_WIDTH;
       pulsewidth -=DELAY_ADJUST;                   // subtract the time it takes to process the start and end pulses (mostly from digitalWrite)
     servos[chan].counter = pulsewidth / 128;
     servos[chan].remainder = 255 - (2 * (pulsewidth - ( servos[chan].counter * 128)));  // the number of 0.5us ticks for timer overflow
     for(uint8_t i=1; i <= NBR_CHANNELS; i++) {  // channels start from 1
        writeChan(i, DEFAULT_PULSE_WIDTH);  // store default values
     servos[FRAME_SYNC_INDEX].counter = FRAME_SYNC_DELAY;   // store the frame sync period
     Channel = 0;  // clear the channel index
     ISRCount = 0;  // clear the value of the ISR counter;
     /* setup for timer 2 */
     TIMSK2 = 0;  // disable interrupts
     TCCR2A = 0;  // normal counting mode
     TCCR2B = _BV(CS21); // set prescaler of 8
     TCNT2 = 0;     // clear the timer2 count
     TIFR2 = _BV(TOV2);  // clear pending interrupts;
     TIMSK2 =  _BV(TOIE2) ; // enable the overflow interrupt
     isStarted = true;  // flag to indicate this initialisation code has been executed
mem
ServoTimer2 test sketch
Code: [Select]
// this sketch cycles three servos at different rates
#include <ServoTimer2.h>  // the servo library
// define the pins for the servos
#define rollPin  2
#define pitchPin 3
#define yawPin   4
ServoTimer2 servoRoll;    // declare variables for up to eight servos
ServoTimer2 servoPitch;
ServoTimer2 servoYaw;
 servoRoll.attach(rollPin);     // attach a pin to the servos and they will start pulsing
 servoPitch.attach(pitchPin);
 servoYaw.attach(yawPin);
// this function just increments a value until it reaches a maximum
int incPulse(int val, int inc){
  if( val + inc  > 2000 )
     return 1000 ;
      return val + inc;
int val;
  val = incPulse( servoRoll.read(), 1);
  servoRoll.write(val);
  val =  incPulse( servoPitch.read(), 2);
  servoPitch.write(val);
  val = incPulse(servoYaw.read(), 4);
  servoYaw.write(val);
  delay(10);
Erik
Helo,
I get these errors using this library
Quote
ServoTimer2.cpp: In constructor 'ServoTimer2::ServoTimer2()':
ServoTimer2.cpp:59: error: a function-definition is not allowed here before '{' token
ServoTimer2.cpp:73: error: a function-definition is not allowed here before '{' token
ServoTimer2.cpp:78: error: a function-definition is not allowed here before '{' token
ServoTimer2.cpp:83: error: a function-definition is not allowed here before '{' token
ServoTimer2.cpp:93: error: a function-definition is not allowed here before '{' token
ServoTimer2.cpp:98: error: a function-definition is not allowed here before '{' token
ServoTimer2.cpp:114: error: a function-definition is not allowed here before '{' token
ServoTimer2.cpp:132: error: expected `}' at end of input
ServoTimer2.cpp: At global scope:
ServoTimer2.cpp:10: warning: 'void initISR()' declared 'static' but never defined
ServoTimer2.cpp:11: warning: 'void writeChan(uint8_t, int)' declared 'static' but never defined
ServoTimer2.cpp:23: warning: 'isStarted' defined but not used
Code: [Select]
How do I solve this?
Erik
mem
#5
Jan 09, 2009, 04:50 pm Last Edit: Jan 09, 2009, 04:52 pm by mem Reason: 1
Hi Erik, it looks like a bracket got dropped off that post, the fragment should look like this:
Code: [Select]
} // <- put the closing bracket here
Good luck!
aercam
Hey MEM,
One question:
Is the ServoTimer2 library compiling on 0012 now? I had it working on 0011 but would not run on 0012.
I just corrected the .cpp file also.
Can ST2 be used with ServoDecode to command the servos?
Jim
mem
#7
Jan 09, 2009, 08:25 pm Last Edit: Jan 09, 2009, 08:32 pm by mem Reason: 1
Yes, the code above (with the missing bracket added) should compile under 0012. If its not for you, let me know what error messages you are getting.
Yes, ServoTimer2 works with ServoDecode.
You may be able to find some examples burried in this giant thread:http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1204020386
aercam
#8
Jan 09, 2009, 10:46 pm Last Edit: Jan 09, 2009, 10:48 pm by aercam Reason: 1
Hey MEM,
Yes sir, I am glad to report that ST2 does in fact compile and run on 0012 now.. The missing } was the issue before. The following code I got from the Giant thread and it compiles fine but keeps getting the message that there is no decoder input. If I run the ServoDecode test code only, the test code compiles and runs just fine. This co-mingled code seems to stumble on the capturing a valid run state.
Code:
Quote
// ServoDecodeTest
#include <ServoDecode.h>
// define the servo pins
#define servo1Pin  2   // the pin the servo is attached to
#define servo2Pin  3
ServoTimer2 servo1;    // declare variables for the servos
ServoTimer2 servo2;
 Serial.begin(38400);
 servo1.attach(servo1Pin);
 servo2.attach(servo2Pin);
 ServoDecode.begin();
 int pulsewidth;  //[MAX_CHANNELS];
 if( ServoDecode.getState()!= READY_state) {
   Serial.println("The decoder is not ready");
 else {
   // decoder is ready, do somthing with the channel pulse widths
   if( ServoDecode.GetChannelPulseWidth(1) > 1500){  // run script 1 if pulse width greater than 1500 ;
     int argumentA = (2250 - ServoDecode.GetChannelPulseWidth(2)) / 200; // some values proportional to stick position
     boolean argumentB = ServoDecode.GetChannelPulseWidth(2) < 1500; // true if channel 2 less than than 1500
     runScript1(argumentA, argumentB);
 delay(100); // update 10 times a second
void  runScript1(int argumentA, boolean argumentB){
 // do something here to control servo...
 servo1.write(2000);
 delay(5000);  // note that all servo are pulsed by the interrupt handler with their current value every 20ms
 if(argumentA)
    servo2.write(2000);
 delay(argumentB * 10); //delay a time determined by the transmitter stick position
 servo1.write(1000);
 servo2.write(1000);
I understand the logic flow, but the mechanics of coding seem to get convoluted when I try to write some code. The code logic is:
Get receiver output on Arduino pin 8
Decode the PPM into channel pulsewidths
Convert the pulsewidths to servo friendly values
do this as rapidly as possible( using interrupts if necessary)
pass the pulses to the servo outpins on manual :-/
pass control to Arduino as option :-/
Thanks in advance :)
mem
The values from ServoDecode.GetChannelPulseWidth should be servo friendly - they would be the same value as the servo would get if it was plugged directly into the channel.
Perhaps try the following logic to get you started:
In the else part of your loop:
  int chan1 = ServoDecode.GetChannelPulseWidth(1);
  int chan2 = ServoDecode.GetChannelPulseWidth(2);
     Serial.println(chan1);
     Serial.println(chan2);
     Servo1.write(chan1);
     Servo2.write(chan2);
Once you confirm that works, you can start manipulating the values you get from ServoDecode before sending them to the servos.
eustace
Thanks, Mem.  I'm going to try this library and code on my robot arm as soon as I free up some pins (I'm using switches to control three of the servos - once I get my micro joysticks I can reduce the control lines to one per axis).
aercam
Good afternoon MEM,
Thank you once again for your assistance.
The code now runs as expected and better in fact, than the attempts I made using SoftwareServo. With this code you provided and my sketch, the servos move now just as if they were connected directly to the receiver with NO JITTER at the center throw position. Next step is to create some mixing schemes to move the servos as needed and then to use Gyros to assist with the servo placements in assist mode. :D :D
Thank you once again.
Jim
mem
Hi Jim, good to hear that you are making progress  :)
Looking forward to hearing more about your project when you have the servo mixing coded.
Combust
Hi Guys,
Im currently trying to get this program reading a potentiometer value. Ive mashed it together with the following program:
Quote
// Controlling a servo position using a potentiometer (variable resistor)
// by Michal Rinott <people.interaction -ivrea.it /m.rinott>
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
Servo myservo2;  // create servo object to control a servo
int potpin0 = 0;  // analog pin used to connect the potentiometer
int potpin1 = 1;  // analog pin used to connect the potentiometer
int val1;    // variable to read the value from the analog pin
int val2;    // variable to read the value from the analog pin
 myservo1.attach(9);    // attaches the servo on pin 9 to the servo object
 myservo2.attach(10);  // attaches the servo on pin 9 to the servo object
 int test = 1;
 val1 = analogRead(potpin0);            // reads the value of the potentiometer (value between 0 and 1023)
 val2 = analogRead(potpin1);            // reads the value of the potentiometer (value between 0 and 1023)
 val1 = map(val1, 0, 1023, 27, 160);     // scale it to use it with the servo (value between 0 and 180)
 val2 = map(val2, 0, 1023, 27, 160);     // scale it to use it with the servo (value between 0 and 180)
 myservo1.write(val1);                         // sets the servo position according to the scaled value
 myservo2.write(val2);                         // sets the servo position according to the scaled value
 if (test)
   Serial.print(val1);
   Serial.print(" ");
   Serial.print(val2);
 delay(15);                           // waits for the servo to get there
And the result is:
Quote
// this sketch no longer cycles three servos at different rates
#define rollPin  2
#define pitchPin 3
#define yawPin   4
int potpin2 = 2;  // analog pin used to connect the potentiometer
int val0;    // variable to read the value from the analog pin
 int test = 1;
 val0 = analogRead(potpin0);            // reads the value of the potentiometer (value between 0 and 1023)
 val1 = analogRead(potpin1);            // reads the value of the potentiometer (value between 0 and 1023)
 val2 = analogRead(potpin2);            // reads the value of the potentiometer (value between 0 and 1023)
 val0 = map(val0, 0, 1023, 27, 160);     // scale it to use it with the servo (value between 0 and 180)
 servoRoll.write(val0);                         // sets the servo position according to the scaled value
 servoPitch.write(val1);                         // sets the servo position according to the scaled value
 servoYaw.write(val2);
 if (test)                            //If int test = 1 will display the value of the pots
   Serial.print(val0);
   Serial.print(val1);
   Serial.print(" ");
   Serial.print(val2);
It reads the pot value but doesnt output to the servo so im thinking it doesnt work in the same way as the other program.
Im a programming novice so any help would be greatly appreciated at this point :)
mem
The input to ServoTimer2 is pulse width in microseconds, not degrees.
Replace the map functions in your sketch with the following code:
Code: [Select]
#define MIN_PULSE  750
#define MAX_PULSE  2250
val0 = map(val0, 0, 1023, MIN_PULSE , MAX_PULSE );     // scale it to use it with the servo
val1 = map(val1, 0, 1023, MIN_PULSE , MAX_PULSE );     // scale it to use it with the servo
val2 = map(val2, 0, 1023, MIN_PULSE , MAX_PULSE );     // scale it to use it with the servo
