Topic: Bluetooth Module - Soldering/Connecting Question (Read 2080 times) previous topic - next topic
Eight
I have one of these serial Bluetooth modules which I was going to attempt to use with an Arduino --
I think the pitch is 1.5mm, so I was wondering if anyone could tell me how best to solder some kind of connectors to these pins? Can't find a suitable pin strip and using individual bits of wire looks like an unbelievable pain.
What would be the usual practice?
Cheers.
jluciani
No one makes a 1.5mm pitch header?
If those edge connections are scalloped soldering wires would be very easy.
1. Take one long length of buss wire and wrap it around the body making
   sure that the buss wire connects to each scallop.
2. Solder the buss wire in each scallop.
3. Cut the buss wire flush on the top
4. Trim the buss wire to the desired length on the bottom.
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
Eight
ibster
#3
Jan 19, 2011, 10:06 pm Last Edit: Jan 19, 2011, 10:07 pm by ibster Reason: 1
Hello,
I have the same problem.
But I don't know what "buss wire" is.
Could you add an image?
Cheers!
jluciani
Buss wire is solid tinned copper wire. If you type in buss wire
at Digikey you will get a number of hits.
(* jcl *)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
