Topic: Seeeduino - an unofficial update of Diecimila (Read 10522 times) previous topic - next topic
seeedstudio
Arduino is great, so does the team. While enjoying Aduino , we found there are several inconvenices could be improved. People in Arduino forum has some discussions in improving it. Thanks to open source, freshman like us could take gut to try.
Albert and I have spend some time for a new board in fixing the obvious drawbacks and made some improvements. The new board will base on Diecimila, and 100% compatible to its shields, cases, software? You should have no problem adopting it to your current projects. The changes are:
1. Align the header with 2.54mm grid.
Related discussions: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1206626508
Place an second row of header align to standard grid. So it will be compatible to existing shield and your proto board. Both of the headers will be soldered, or either of them.
2. A jumper to disable auto-reset.
Related discussions: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1213719666
DIP switches.
3. Possibility for USB HID support.
Related discussions: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1172471904
We want to use CP2102 instead of FT232, it's smaller form factor, cheaper and it has a stronger brother F32x & F34x. These USB MCU F32x could be programed to many USB devices easily. Example for HID:http://www.cygnal.org/ubb/Forum9/HTML/001381.html
4. Make it flat
We want place a proto board directly onto Arduino? The B-type USB, power jacks are standing in the way.
Alternatives will be mini-USB,  ext power pin plug. Moreover, the reset button is moved to the edge of the board, so that we can reset easily while bearing shields.
5. Two extra Analog - ADC6, ADC7
6. 3.3V and 5V switch
7. Full UART pin out
8. Other trival improvement
9. Reorganize the PCB
The v1.0b PCB and Scheme will be released very soon, under Creative Commons Attribution-ShareAlike 3.0 License. Suggestion sincerely welcomed! It's not an official version, and we would like to call it Seeeduino ^^
http://www.seeedstudio.com/blog/
macegr
Ah.....nice.
Good idea with the second header on .1 inch centers, but not throwing away compatibility with old shields. Using this board, people can throw together custom shields with cheap proto donut board.
For USB, maybe place two jumpers that switch the USB D+ and D- lines to an ATTiny45. It would take up almost zero space. Now you can load the USBTiny or AVRUSB code and implement an HID separately from the main Arduino processor. Provide a couple female headers to run communication pins to the Arduino. I have firmware that allows an ATTiny45 to act as an I2C gateway for another controller, to appear as a mouse, joystick, or keyboard on a computer. Or, if you don't want to include the ATTiny45, at least provide the footprint and USB jumpers so users can populate that part of the PCB if they want to.
Unique RGB LED Modules and Arduino shields: http://www.macetech.com/store
kg4wsv
Quote
The CP2102 device has poor support under Mac OS X (that driver is the only software ever to crash the mac os x kernel on me).  IIRC it lacks a unique identifier, which is very important if you use more than one device at a time.
I have used lots of these things at work, and FTDI is the best solution out there.
-j
seeedstudio
#3
Sep 05, 2008, 01:57 pm Last Edit: Sep 05, 2008, 01:57 pm by seratechi Reason: 1
Combine from the other duplicate thread:
Melka's reply:
Is it possible to do ? What solution do you have ? Headers with a 1.27mm pitchs ?
Great ! Worth trying, I think.
Maybe you could include the side switch instead of the jumper for selecting between USB and external power.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1218817652
Maybe the same switch for the auto-reset.
Nice update to the board family, in any case ^^
Oracle's reply:
Quote from melka on Yesterday at 17:27:46:
Easily.  I suggested this ages ago in the bugs and suggestions forum.  Imagine the standard Arduino Diecimila board.  Now along the digital IO connectors put a second row of IO connectors 0.1 inches closer to the edge of the board (you may need to make the board 0.1 inches wider).  The second row can easily be attached to the first row on the PCB (each pin is just a 0.1 inch jump away), but now on the second row, correct the spacing to 0.2 inches between the two headers.
You can connect a shield to the old connectors or a standard perf board to the new headers.
seeedstudio
Quote
Quote
-j
It's a serious problem to consider...  I have sent mail to silabs with your comments. We might stick to FT232 if there is no news for CP2102 Mac OS support.  Or, is there other USB-UART chips could be a better alternative? Like PL2302 for example. It'll help reduce the final price remarkably.
Thanks ;)
seeedstudio
#5
Sep 05, 2008, 03:02 pm Last Edit: Sep 05, 2008, 03:03 pm by seratechi Reason: 1
Quote
Ah.....nice.
Yes, it's a easy. We would add this feature by 1) Pin out USB D+ and D-, 2) setup a jumper to bypass the onboard USB chip.
kg4wsv
Quote
That one has the same issue with serial number.  Not sure if it even has Mac OS X support, but that would be worth checking before making a design decision.
Quote
Not that I've seen, but I've only been doing computer support for 18 years, so I could have missed a few...
Quote
Eh?  The FT232 is only $3.99 in single unit quantities at digikey.  You can save at most a couple of dollars, and in return you get an (IMO) inferior product that is not compatible with existing Arduinos.
It's your design, though, so of course it's your call.
-j
bwevans
Im with kg4wsv, the CP2102 is a seriously flawed device and would make your board no longer 100% compatible IMHO.
If size is the problem you can get the ftdi chip in a MLF package which would be great for machine assembly but good luck to you if you want to hand solder your protos. For that mater the same goes for the ATmega168 just look at pololu's mini orangutans.
Finally reconsider your license... there has been these debates on the fora about derivative works and how they should always be distributed with the same license as the original. Last I knew Arduino was under the cc2.5 license.
Best,
B
westfw
Quote
TI has something, and apparently cypress has (or will have) one of their USB-capable micros re-spun as a USB/RS232 bridge.  They all seem to have "issues" with OS support other than windows...
I don't think I understand the "reduce the final price considerably" issue; on the sites I've looked at, the FTDI chip currently used and the CP2102 are very close in price.
In the real open-source mindset, perhaps the dedicated USB/Serial bridge should be replaced with a general purpose micro that supports USB.  Cypress, Microchip, and even Atmel have relatively small and inexpensive micros that include HW USB support, frequently at per-chip costs lower than an FTDI chip.  (AT90USB82 $2.32 in 25s at digikey.)  However, the difficulty and cost of supporting yet another bit of firmware and three OS drivers (N versions each) is NOT to be underestimated.  FTDI has done a really good job of keeping up with things...
seeedstudio
#9
Sep 06, 2008, 02:47 am Last Edit: Sep 06, 2008, 02:48 am by seratechi Reason: 1
So we would switch back to FTDI, thanks for the suggestions.
Here is feedback from Silabs about the compatible issue, for your reference:
Quote
When a CP210x device (and any other USB device as well - no matter who the manufacturer is) is connected to the PC, it is uniquely identified by a combination of three identifiers - Vendor ID (VID), Product ID (PID), and Serial Number. If two or more devices with identical information are connected to the PC simultaneously, the operating system is unable to distinguish between them and only the first device or none of them will work correctly.
But if your application needs two or more CP210x devices connected to the PC simultaneously, there is a very simple solution, the CP210x devices should be programmed with unique serial numbers. The serial numbers can be modified in the CP210x EEPROM using the CP210xSetIDs.exe utility available as part of our application note AN144. AN144 can be found on our web site here:
https://www.silabs.com/products/mcu/Pages/ApplicationNotes.aspx
It is also strongly recommended that you use a unique  VID / PID  combination for your product to prevent conflicts with another manufacturer's products, more details about this can be found in our Knowledge Base article # 87271:
http://portal.knowledgebase.net/article.asp?article=87271&p=4120
seeedstudio
#10
Sep 06, 2008, 03:08 am Last Edit: Sep 06, 2008, 03:12 am by seratechi Reason: 1
Quote
Best,
B
It will be our first time releasing designs under cc lincenses. We read about the guideline, but not sure if we are doing in the right way. Thanks for the reminder!
Seeeduino, will be compatible with Arduino's CC2.5 share alike license. We see a explanation in http://creativecommons.org/licenses/by-sa/2.5/: A new version of this license is available. You should use it for new works, and you may want to relicense existing works under it. No works are automatically put under the new license, however. So we adopt cc3.0 share-alike licenses.
Please help correct us if wrong. Appreciated :)
melka
I just thought of it : you might want to add this little hack (if you use the FTDI chip)
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1217113409/
http://melka.one.free.fr/blog/
http://www.flickr.com/photos/melkaone/
seeedstudio
melka
#13
Sep 07, 2008, 04:22 am Last Edit: Sep 07, 2008, 04:23 am by melka Reason: 1
Xie Xie ^^
seeedstudio
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
