Topic: Arduino NG to DB9 serial (Read 2729 times) previous topic - next topic
gschoppe
Feb 10, 2007, 12:23 am Last Edit: Feb 10, 2007, 12:26 am by gschoppe Reason: 1
oddly enough, I bought an Arduino NG because i had no DB9 serial on my new computer, however, now I need to use it on a computer that lacks USB...
can someone explain what pins on a DB9 would go to what ports on Arduino?
is it just:
rx to rx
tx to tx
+5v to +5v
ground to ground
or is there more to it?
Daniel
#1
Feb 10, 2007, 01:20 am Last Edit: Feb 10, 2007, 01:21 am by Daniel Reason: 1
hi
if you mean that you want to connect the DB9 serial port pins to the Arduino NG's headers, then there is more to it.
The DB9 version had some transistors to do RS232-TTL level conversion. You'll need some kind of level conversion... you could use a MAX232, which is a common chip. Not sure if the polarities will be right, but it is a start. Alternatively you could build the RS232 version form the schematic on the Arduino main site.
D
brainfart
The easiest way is probably getting an internal USB-PCI card for that computer.
kg4wsv
TX to RX, RX to TX, ground to signal ground, but you must do voltage and level translation.  RS232 uses different voltages and levels than TTL.
Fairly easy way: build a circuit with a MAX232 and 5 caps, connect the arduino tx, rx, gnd, and +5 (to power the MAX232), add a DB9.
Easier way: build a circuit with a MAX233 which doesn't even need the caps (but the 233 is more expensive than the 232).
Cheapest way: build a circuit with some transistors and other components to steal voltage levels from the host 232 port and invert the levels for you.  The Arduino serial does this, check the schematic for details.
Easiest way: buy an Arduino serial.
-j
gschoppe
well, i'm working on the rs232 method shown at http://www.arduino.cc/en/Tutorial/ArduinoSoftwareRS232, but until i find a local (read: in vermont, the great non-electronic wasteland) source for the max3323 chip i'm stuck... i figure i'll add a usb pcmcia card, but I can't remember if its 98se on the notebook or 98, if the latter, I wont be able to get usb, as the cd is dead, and there's no floppy, so upping the OS would be hard.
Daniel
#5
Feb 11, 2007, 05:53 am Last Edit: Feb 11, 2007, 05:59 am by Daniel Reason: 1
hey
Maxim, makers of the all kinds of interface chips including the ones above, are kind enough to provide a sample service...  for (a few) chips, go to http://www.maxim-ic.com/ and register.  Once you do this, you will be able to request up to three free samples per device type, through their automated sample system. Only drawback is that it is slow-- sometimes take a couple of weeks as the parts often come from Malaysia.
Digikey will also sell them to you via mail or UPS.
http://www.digikey.com
D
PS: non-electronic wasteland = unspoiled nature = good thing, or at least it used to be. :)
gschoppe
#6
Feb 11, 2007, 12:34 pm Last Edit: Feb 11, 2007, 12:35 pm by gschoppe Reason: 1
definitely nice living here, especially in the fall and winter, but there are drawbacks, such as lack of ECE jobs and difficulty of getting parts without ordering.
still, you can see which side i lean toward, as I still live here.
btw, placed a sample request... thanks for the info
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
