Topic: NoClassDefFoundError: processing/app/Base (Debian) (Read 1 time) previous topic - next topic
Thempra
I try to install arduino IDE in my debian SID with this how to:
http://www.arduino.cc/playground/Linux/Debian
then I install the package  sun-java5-jre sun-java6-jre librxtx-java
but when I run /usr/lib/arduino/arduino , I get an error:
Exception in thread "main" java.lang.NoClassDefFoundError: processing/app/Base
Where is the problem????
Thempra
I try again with the copy in the svn ( arduino-0009 ) and I get the same error:
mellis
I'm not sure quite how the debian package is set up, but it sounds like you need to add a directory to your CLASSPATH environment variable.  There should be a pde.jar somewhere from the Arduino package, and it or the directory it's in needs to be in your classpath.  You can try something like in a terminal:
export CLASSPATH=/usr/lib/arduino:$CLASSPATH
And then run Arduino.
Thempra
Thank you for the idea !!
I run it, I edit the file arduino an put at the end in the line CLASSPATH:
Code: [Select]
CLASSPATH=java/lib/rt.jar:lib:lib/build:lib/pde.jar:lib/core.jar:lib/antlr.jar:lib/oro.jar:lib/registry.jar:lib/mrj.jar:lib/RXTXcomm.jar:/usr/lib/arduino
Only work if I run it since the path /usr/lib/arduino, but .... RUN !!! ;)
af3556
You will see this problem if you start arduino from outside of its "home".
e.g. if you don't want to fiddle with CLASSPATH, this should work:
Code: [Select]
$ cd /path/to/arduino-008/ && ./arduino
Rgds,
Ben
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
