Topic: Serial Not Working With External Power (Read 603 times) previous topic - next topic
DeuceBox
I have an Arduino Mega and have had no problems until I tried using an external power supply for the first time tonight. I'm simply trying to use a parallax RFID reader and my sketch works fine when the board is connected through USB, however, when connected to only an external power supply, the code seems to execute but the serial part does not work.
My Code:
Quote
int  val = 0;
char code[10];
int bytesread = 0;
pinMode(52,OUTPUT); //Enable/Disable RFID pin
pinMode(13,OUTPUT); //LED used to make sure the loop is running
digitalWrite(52, LOW); //Enable the RFID
Serial1.begin(2400); //Arduino Mega RX1 (Pin 19) connected to SOUT from RFID reader
  digitalWrite(13, HIGH); //Blink the LED to show we're in the loop
  delay(100);
  digitalWrite(13, LOW);
  delay(100);
 if(Serial1.available() > 0) {          // if data available from reader
   if((val = Serial1.read()) == 10) {   // check for header
     bytesread = 0;
     while(bytesread<10) {              // read 10 digit code
       if( Serial1.available() > 0) {
         val = Serial1.read();
         if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
           break;                       // stop reading
         code[bytesread] = val;         // add the digit
         bytesread++;                   // ready to read next digit
     if(bytesread == 10) {              // if 10 digit read is complete
       digitalWrite(52, HIGH);          // Disable and re-enable after 2 seconds when a card has been read
       delay(2000);
       digitalWrite(52,LOW);
     bytesread = 0;
          delay(500);                       // wait for a second
When connected through USB the pin13 light blinks as it should and when a card is held up, the parallax led goes from red to green for 2 seconds then changes back. Perfect.
When connected through an external power supply, the pin13 light blinks which means the sketch has made it into the loop, but nothing happens when I hold a card up to the RFID reader.
Any thoughts/suggestions would be greatly appreciated.
pluggy
Your external power supply isn't up to scratch ?
Have you tried another one ?
If its on the edge for smoothing or voltage, you can get unexpected problems.
http://pluggy.is-a-geek.com/index.html
DeuceBox
That was the problem, it was that simple. Thanks.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
