Loading...
Pages: [1] 2   Go Down
Author Topic: Uploading problem  (Read 627 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hello!
I can't upload any program to my Arduino. When I try to upload a program this error shows up: avrdude: ser_send(): write error: sorry no info avail. I already tried everything on the toubleshooting page but nothing helped. Any suggestions what shoud I do now? Or is my Arduino just broken? Also, when Arduino is connected to the computer the Arduino program becomes very slow.
OS: Windows 7
Board: Duemilanove 328
Logged
Connecticut
Offline Offline
Edison Member
RTFD (Datasheet in our case)
View Profile
Hi Make!
Usually that error comes from a Serial port problem.
Make sure that you have the right serial port selected (under Tools>Serial Port) and that you installed the USB driver.
Hope it helps!
Logged
I'm not kidding. If I am asking a question whose answer is found within the concerned product's datasheet, shame on me. If I am answering a similar question, shame on you!
0
Offline Offline
Newbie
Arduino rocks
View Profile
I made sure that I have the right port selected but still I can't upload programs. smiley-sad
Logged
Houston, TX USA
Offline Offline
Newbie
Arduino rocks
View Profile
This is probably a dumb question, but are you sure you have the right board type selected?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Yes. I made sure that I have the right board selected.
Logged
Connecticut
Offline Offline
Edison Member
View Profile
But have you installed the driver from FTDI?
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Has this ever worked in the past? Or is this a new installation you are trying to get to work?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
My Arduino has worked without problems in the past. The problem occured just a little while ago.
Logged
France
Offline Offline
Newbie
Arduino rocks
View Profile
WWW
did you do anything that might have dammaged your board?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I'm a newbie.  Had my Arduino Duemilanove for couple weeks.  Completed couple dozen tutorials and other sketches.  Now, all of the sudden, can't upload anymore.  Sounds like same as Make's problem.  Correct USB port, correct board.  Plug into usb - PWR LED on, TX/RX both flash 3 times, LED on pin 13 flashes several times.  Upload attempt only RX blinks 3 times -  then once several seconds later.  Window Vista error is:
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
On Mac, plug into usb - PWR LED on, TX/RX both flash 2 or 3 times much more rapidly than PC, LED on pin 13 does not flash.  Upload attempt only RX blinks 3 times -  then once several seconds later.
Mac OSX (10.6.4 most recent) error is:
I tried everything I read on this forum and couple others.  Also reinstalled everything.  Have I damaged my board?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
I think no. I have just connected a few motors, leds and an ultrasonic ranger. I followed the instructions carefully before connecting anything.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I produced this error by screwing my arduino to a piece of foam-board without spacers. A capacitance effect interfered with the USB connection. Check clearance underneath the board.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Quote
I made sure that nothing touches underneath the board.
« Last Edit: August 22, 2010, 05:21:26 am by Make » Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
I hand tighten three 1" nylon flat head screws into the three holes in my Arduino board, acts like table legs, and that keeps up and out of harms way.
Lefty
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
The same happened to my second arduino board. With the first one (original duemilanove) I may have pressed reset for too long, because I got frustrated. But the nano just stopped loading programs with the same error - programmer does not respond - without any clue.
I tried to burn bootloader that did not change anything.
Logged
Pages: [1] 2   Go Up
Print
Jump to:
