Topic: Uno USB invisible to OS X (Read 4866 times) previous topic - next topic
scruss
[font=Georgia]Just got my Uno after finding semi-permanent projects for two previous Duemilanoves. Upgraded to Arduino 0020. After rebooting, and power cycling the Uno, there's still no serial port for the Uno.
The board is noted under Linux, which reports an unknown device with ID 2341:0001. On my MacBook (10.6.4), System Profiler lists:
Code: [Select]
Communication Device:
 Product ID:      0x0001
 Vendor ID:      0x2341
 Version:       0.00
 Speed:      Up to 12 Mb/sec
 Location ID:      0x24110000
 Current Available (mA):      500
 Current Required (mA):      Unknown (Device has not been configured)
There are no /dev/tty* or /dev/cu* devices that correspond to the device.
Please let me know what I'm doing wrong.[/font]
mariod
I have a similar problem with my new Uno board.
I'm using Ubuntu 10.4 32bit and only the ttyS0 looks up under the IDE.
After connecting the Uno to the Laptop this is the message of dmesg:
Code: [Select]
[  142.968435] lib80211_crypt: registered algorithm 'CCMP'
[  143.205626] padlock: VIA PadLock not detected.
[  143.240799] lib80211_crypt: registered algorithm 'TKIP'
[  172.148099] usb 4-1: new full speed USB device using uhci_hcd and address 2
[  172.350490] usb 4-1: configuration #1 chosen from 1 choice
[  172.601905] cdc_acm 4-1:1.0: ttyACM0: USB ACM device
[  172.609577] usbcore: registered new interface driver cdc_acm
[  172.609585] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
I tried to link the ttyACM0 to ttyUSB0 and now the device shows up, but I'm not able to program the board:
Code: [Select]
Binary sketch size: 960 bytes (of a 30720 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0xf9
Hope anybody can help...
James C4S
I am also running 10.6.4.
Whenever I connected the UNO, I would get a message about "New network interface has been connected but not configured."  I kept hitting cancel or ignoring it.  Finally I clicked configure and was brought to the Network panel of System Preferences.  Clicked "Apply" and closed preferences.
After that my profiler says then when Uno is connected:
Code: [Select]
Arduino Uno:
 Product ID:      0x0001
 Vendor ID:      0x2341
 Version:       0.00
 Serial Number:      649383233313512172C0
 Manufacturer:      Arduino (www.arduino.cc)
 Location ID:      0xfd340000
 Current Required (mA):      100
And a new /dev/tty.usbmodemXXXXXX device shows up (with a /dev/cu counterpart.)
You might re-connect it and check System Preferences -> Network to see if you have a Arduino Uno interface listed.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
westfw
Note that the the Arduino Uno shows up on Macs as a /dev/tty.usbmodemXXXX instead of a /dev/tty.usbserial-YYYYYY as it did with the FTDI-based Arduinos.
mellis
scruss: weird.  The correct USB VID and PID are showing up, which means that the ATmega8U2 on the Uno should be running the right firmware (that's what supplies those IDs).  I don't know why you'd get them, but not the "Arduino Uno" name - both should be in the same USB metadata.
Do you have an AVR ISP?  You could trying reburning the firmware onto the ATmega8U2 (it comes in the Contents/Resources/Java/hardware/arduino/firmwares/ directory, with instructions in the readme).
What do you see in the Console application when you plug in the board?  I get:
10/2/10 4:54:49 PM      kernel      AppleUSBCDCACMData: Version number - 4.0.1, Input buffers 8, Output buffers 16
10/2/10 4:57:07 PM      kernel      AppleUSBCDCACMData: Version number - 4.0.1, Input buffers 8, Output buffers 16
scruss
I don't get anything in the console.
I've been using a hub up to now to protect my Mac. When I directly connected the Uno to the computer, I got the Network Preferences dialogue like everyone else. This worked fine.
When I plugged the Uno back into the hub, I got the same Network Preferences dialogue, and a new Uno USB serial device. I switch to it in the programming interface, but got 'avrdude: stk500_recv(): programmer is not responding' timeouts.
Basically, the thing doesn't work unless it's directly connected, and I now have to lop off the excess non-functional "Arduino Uno 2" and "Arduino Uno 3" devices when I start up. Frustrating.
Incidentally, a friend who is a USB developer at Apple recommended I install the USB debug kit, http://developer.apple.com/hardwaredrivers/download/usbdebug.html. I haven't, yet.
James C4S
#6
Oct 03, 2010, 03:36 am Last Edit: Oct 03, 2010, 03:38 am by cmiyc Reason: 1
For what it is worth, my Arduino UNO had only been connected through a USB 2.0 Hub until your most recent post.  (For the same reason you post, to protect my Mac while I do stupid---er try different things.)
However, when I switched to a built-in USB port, I got the "Network Interface" dialog again.  And a new usbmodem device.
Each time I plug into a new Port, the same thing occurs.  Whether that port is on my Hub or built-in.  (Which from an implementation point makes sense.  At least one if not all Ports on a Mac laptop are connected through a Hub chip.)
It is rather frustrating that I have to change the device I'm using, depending on which Port I'm connected to.  Reminds me of using USB devices in Windows.
scruss
On the Console, I'm now getting:
[font=Courier New]10-10-12 21:46:17       kernel      USBF:      64159.957      AppleUSBEHCI[0x8143000]::Found a transaction which hasn't moved in 5 seconds on bus 0x26, timing out! (Addr: 6, EP: 0)
10-10-12 21:46:29       kernel      0        0 AppleUSBCDC: start - initDevice failed
[/font]
Bus 0x26 is the hub I use.
Directly connected, I get:
[font=Courier New]10-10-12 21:49:49       kernel      AppleUSBCDCACMData: Version number - 4.0.1, Input buffers 8, Output buffers 16
[/font]
I no longer get new network devices (what would be the settings if I did?). Only direct connection works; through the hub doesn't. So the only way I can get an Uno to work along with my two other Arduino boards is to have two USB cables, and make sure I never draw any current that could come close to doing damage to my Mac ...
James C4S
Quote
The Mac USB ports have resettable-fuses (similar to the one on the Arduino itself.)  You'll get an error dialog about excessive current draw and then power is shut off to the port.  Sometimes a power cycle will be necessary to restore power to the port.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
