Topic: Unable to send any midi message with my seeeduino! (Read 652 times) previous topic - next topic
GDLive
Nov 26, 2010, 07:07 pm Last Edit: Nov 27, 2010, 10:59 am by GDLive Reason: 1
Help help !  :-/
I'have done lot of tests, but I'm definitely unable to send (and correctly receive) midi messages, using :
- wire : the tx pin, the 5v + 220 ohm Resistor, ground
- the serial baud rate 31250
When I'm checking the com port, I'm able to read note on messages.
My prg is basic and for me, it works : (same from here :)
http://arduino.cc/en/Tutorial/Midi
I have checked and checked the wiring, It seems to be right.
I was wondering if on usb mode, the seeeduino wasn't able to set the baud rate to 31500. Then I used external power. Doesn't change anything.
I've checked different options, the midi signal isn't received / or recognized by :
- my soundcard
- my synthesisers
- my pedal board
To complete my tests, i've tried to send midi messages via xbee (at 31500) and wiring xbee to midi port as here without the 7404N component
http://www.ladyada.net/images/midibee/midibeebb.png
Idem : I'm receiving what seems to be midi messages but they are not seen on my hardware !!
I'm very disappointed and have no more idea what to test !!!!!  :'(
Help would be much appreciated !
Thanks
GDLive
Nobody has an idea ?
I saw some rare people use a different schema :
http://www.thebox.myzen.co.uk/Hardware/MIDI_Shield.html
Does it say that the original wiring could have some issues ?
http://tomscarff.110mb.com/MIDI_IN_OUT_ARDUINO/midi_in_out_arduino.htm
Whatever I try, I can't get this midi out working ! :-X
GDLive
Ok, thanks for your help  ;)
- 1st problem :
One of the midi cables I used wasn't a real midi cable  >:( no conduction trough pin 4 - 5 but 1 - 3
- 2nd problem :
For one raison that I ignore, I can finally send midi message both from arduino and xbee, with simple wiring or more complex with 2 PNP transistors :
http://www.neufeld.newton.ks.us/electronics/?p=250&cpage=1#comment-23104
but I can only see those messages with
- a mbox 2 soundcard
- my Roland D10
I can't see those messages using the same cable with :
- my hoontech DSP24 sound card
- my berhinger FCB1010 pedal board
Any suggestion from a midi or electronic genius to solve this problem would be much appreciated !
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
