Topic: Cartes petit prix (Read 4022 times) previous topic - next topic
Simpower
Quelques bonnes affaires suite a destockage :
des cartes arduino/seeeduino a 9 euros. elles intègrent un atmega 168 CMS :
Des modules xbee 802.15.4 a 14 euros (au liau de 25), 18 euros complet avec le shield (ensemble courament vendu plus de 40 euros)
Le tout neuf bien entendu.
Cordialement
Améliorations de ces boards :
1. Duplicate digital IO to 100mil grid for prototype board compatibility.
Adding an second row of header align to standard 100mil grid, so it will be compatible both to existing shield and to a cheap 100mil grid prototype board. By default, the traditional IO is soldered instead or new headers, and you may add the new header yourself.
2. Shrink componets height below female headers.
Seeeduino is made as flat as possible, even the crystals are SMD version. So we may put your soldered prototype board onto it with less worry.
3. Easier access to buttons and switches.
All buttons or switches are moved nearer to the edges, so we may reach them easier under the shield or from the wire forests.
4. Change Type-B USB port to Mini USB.
Consideration for dimensions.
5. Replace 3.5mm DC power Jack to battery 2 Pin plug.
Soldering the 3.5mm DC power jack is usually the most difficult part, and we think it's too giant. Maybe a battery pack is more convenient than power adapters? Don't worry about abandoning your 12V adapter, we have a simple convertor.
6. Reset and power indicator near RST button.
We use one LED for power indicator and the other for reset (it will also lid when downloading programs).
7. Auto-reset selection.
Auto-reset is a great feature loved by many. But sometimes we would also like to disable it in production-like mode.
8. 3.3V Operating Voltage selection.
The Vcc could be selected by a switch, for making life easier dealing 3.3v devices.
9. Pin out UART for FTDI232 bit-bang operation.
At least you can burn bootloader without an ISP cable now
10. Pin out 2 extra ADC.
Why not? There are spaces Smiley
11. Pin out for I2C and sensors.
Easier connection to I2C and sensors by a bended femail header.
12. Second power supply for 5V direct input.
Sometimes we would need to apply 5 VDC to Seeeduino either for higher power effeciency or just because having 5VDC in hand. Now you may use these 5V supply to directly power Seeeduino. [Caution] USE 5V ONLY!
13. ReRoute PCB
SMD version Atmega168 give us more space to route, so we carefully rearranged them for us to see the flow more clearly.
Please visit the supporing thread >>here for suggestions on next revision.
14.Easy Uart connection
15.Extra row reserved for DIY pin headers.
You may now use female, male, or DUAL male headers on these pins as well.
16.Extra 3.3V regulator for higher current supply
It's dedicated 150mA now, rather than 50mA supplied by FT232.
Luj06
Pas encore d'acheteur depuis le 28 mars ?
Simpower
Si, mais il y en avait beaucoup. Il en reste donc.
ekaki
Il en reste combien ? Moins de 1000 ?
Simpower
Oui environ 100 cartes et 60 xbee.
nestea57
C'est quel carte arduino ? nano ?
Simpower
#6
May 08, 2010, 08:16 pm Last Edit: May 08, 2010, 08:17 pm by Simpower Reason: 1
Seeduino (arduino) : http://www.simpower.fr/2120.jpg
rK2
Salut,
Aurais-tu des infos supplémentaires sur les modules Xbee ?
Tu entends quoi par "complet avec le shield" ?
Cdlt,
rK2
Simpower
Le xbee : http://fr.farnell.com/digi-international/xb24-aci-001/module-zigbee-xbee-1mw-antenne/dp/1337913?crosssellid=1337913&crosssell=true&in_merch=true&
Exemple pack complet : http://www.libelium.com/tienda/catalog/product_info.php?cPath=21&products_id=47
Franxoois
Pour les frais de port ou la remise en main propre ça se passe comment ?
Simpower
Remise en main propre A Bordeaux
Frais de port=frais postaux. Soit 3,5 euros jusqu'a 2 cartes, 4.5 euros jusqu'a 6 et 8.7 euros au dela.
pharaon909
#11
May 10, 2010, 10:27 am Last Edit: May 10, 2010, 10:29 am by pharaon909 Reason: 1
Bonjour,
Je suis intéressé par deux cartes comment doit-on procéder ?
bozoo0038
bonjour,
ca m'intéresse aussi.
comment on fait pour commander ?
Fab
flaith
Je viens de commander en passant par pm  ;)
Klehm
Je suis intéressé par une carte  ;)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
