Topic: can you independently control 3 servos? (Read 1 time) previous topic - next topic
budsiskos
Jun 15, 2009, 02:37 am Last Edit: Jun 15, 2009, 02:37 am by budsiskos Reason: 1
is it possible to use an arduino duemilanove to control 3 servos independently?
thanks
Mike Mc
#1
Jun 15, 2009, 03:05 am Last Edit: Jun 15, 2009, 03:06 am by zooto68 Reason: 1
With the Mega Servo Library you can control 12 servos (48 if you have a Mega)
With the Software Servo library you can control 20 Servos at the same time.
Take a look at the Servo section in the Playground.
afap
well i spent about an hour looking where you told me to, and here is what i came up with. Can you please look over it and tell me if its right? I have lots of wires to hook up and i need the code to be right.  Thank you!
Code: [Select]
#include <Servo.h>
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
Servo myservo3;  // create servo object to control a servo
Servo myservo4;
int potpin1 = 0;  // analog pin used to connect the potentiometer
int potpin2 = 1;
int potpin3 = 2;  // analog pin used to connect the potentiometer
int potpin4 = 3;
int val;    // variable to read the value from the analog pin
 myservo1.attach(9);  // attaches the servo on pin 9 to the servo object
 myservo2.attach(10);  // attaches the servo on pin 10 to the servo object
 myservo3.attach(5);  // attaches the servo on pin 5 to the servo object
 myservo4.attach(6);  // attaches the servo on pin 6 to the servo object
 val = analogRead(potpin1);            // reads the value of the potentiometer (value between 0 and 1023)
 val = map(val, 0, 1023, 179, 0);     // scale it to use it with the servo (value between 0 and 180)
 myservo1.write(val);                  // sets the servo position according to the scaled value
 val = analogRead(potpin2);            // reads the value of the potentiometer (value between 0 and 1023)
 val = map(val, 0, 1023, 0, 179);     // scale it to use it with the servo (value between 0 and 180)
 myservo2.write(val);
 val = analogRead(potpin3);            // reads the value of the potentiometer (value between 0 and 1023)
 myservo3.write(val);
 val = analogRead(potpin4);            // reads the value of the potentiometer (value between 0 and 1023)
 myservo4.write(val);                  // sets the servo position according to the scaled value
 delay(15);                           // waits for the servo to get there
Groove
#3
Jul 07, 2009, 08:14 am Last Edit: Jul 07, 2009, 09:24 am by GrooveFlotilla Reason: 1
looks reasonable to me, apart from the first line.
The standard servo library only controls two servos.
Code: [Select]
#include <MegaServo.h>
#define N_SERVOS 4
Servo myservo [N_SERVOS];  // create servo object to control a servo
const byte servoPin [N_SERVOS] = {9, 10, 5, 6};
const byte potPin [N_SERVOS] = {0, 1, 2, 3};
int i;
 for (i = 0; i < N_SERVOS; i++) {
   myservo [i].attach(servoPin[i]);
   myservo[i].write(map(analogRead(potPin [i]), 0, 1023, 179, 0));
 delay(15);
Per Arduino ad Astra
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
