Topic: New arduino sketch software (Read 3102 times) previous topic - next topic
db4linq
Sep 17, 2009, 03:46 am Last Edit: Sep 17, 2009, 03:49 am by db4linq Reason: 1
New arduino sketch software for window and .net platform
http://www.electoday.com/bbs/viewthread.php?tid=1899&extra=page%3D1
retrolefty
#1
Sep 17, 2009, 07:44 am Last Edit: Sep 17, 2009, 07:45 am by retrolefty Reason: 1
Wow, this looks pretty impressive. Is there any documentation that one could look over before actually having to install the package and the .net package?
Is it possible to contiune running the current version of the Arduino IDE once this program is installed?
Lefty
db4linq
#2
Sep 17, 2009, 08:58 am Last Edit: Sep 17, 2009, 09:01 am by db4linq Reason: 1
befor use this software.
you must install .net framework 3.5 sp1 http://download.microsoft.com/download/2/0/e/20e90413-712f-438c-988e-fdaa79a8ac3d/dotnetfx35.exe
now this woftware running under original arduino environment you can set in menu Tool -> Arduino Setting or first startup program
:-[ sorry in my English
Nachtwind
Scintilla is missing, can you provide a compatible download or include it into your install? I would love to see your prog working :0)
Believe me, Mike, I calculated the odds of this succeeding against the odds I was doing something incredibly stupid[ch8230] and I went ahead
db4linq
CaptainObvious
I'm sorry, but I couldn't help but pointing out in the 2nd picture you posted, Arduino is spelled wrong at the top.:D
But I agree, looks very impressive, I'll be looking into this software :P
mem
I have a similar question to Lefty, is there any documentation available for download?
Also, how is this software licensed and is source code available?
db4linq
#7
Sep 17, 2009, 01:30 pm Last Edit: Sep 17, 2009, 01:32 pm by db4linq Reason: 1
Thanks you CaptainObvious. I'm sorry for "Arduino" spelled wrong  :-[ I'll change it next version
Hi mem
software license is open source and source code is comming soon.  :) in next version source code include into install file
BenF
A .Net version building on the Windows GUI is an interesting alternative. I tried it briefly, but it it seems a lot more work is still needed:
For starters:
- If I hoover the mouse over the application title bar - the Editor pane goes bananas.
- If I open a sketch by pointing at its skecth directory it will not open (Sketch does not exist). Are you handling directory/filenames with spaces properly?
- Compile fails - references to the source files are incorrect (space in directory/filenames?)
- If I open a sketch.pde file, only the main source file is opened
- How do we create additional profiles (it doesn't seem to read "boards.txt".
TeamMCS
#9
Sep 17, 2009, 03:17 pm Last Edit: Sep 17, 2009, 03:24 pm by TeamMCS Reason: 1
That looks rather funky, nice work mate
[edit]
That link is slow: I've mirrored it here for you
http://download.milesburton.com/Arduino/db4linq/Release.rar
db4linq
Hi BenF. I have answers for you
     Maybe is bug. if you run this application  is not vista or win7
     this application have 2 mode
     1. single file is means .pde file you can open and compile
     2. project solution is means you can create one or more project (.pde file)  by menu Sketch -> New
     Maybe you file path have space. ok I'll fix this bug
     this function not yet.  maybe next release
document is coming soon...
Thank alot TeamMCS.  Maybe link in thailand is slow  :-[
I'm sorry my English is bad  :-[
db4linq
I have some fixed bug and new release 1.0.3
http://ifile.it/07earzk
frank26080115
#12
Oct 04, 2009, 09:00 pm Last Edit: Oct 04, 2009, 09:17 pm by frank26080115 Reason: 1
wow that is a ridiculously slow download speed, why not open source it and post it on google code or sourceforge or codeplex or something like that?
i wasn't able to start using it until the arduino folders were correct, which is fine, except it never told me why i was clicking ok and nothing was happening
the minimize, maximize, and close buttons are missing after startup
the editor crashed when i un-maximized it and dragged it around, but most of the time i can't even drag the window around or un-maximize it
you are definitely not handling file paths properly, a space in the path to arduino will cause it to freak out. a quick fix for this is to surround the path with quotes when using it as an argument when running avr-g++
there's no way to use libraries, i tried including
I'm using Windows 7 RC build 7100
I suggest you stop using ribbon, it's a huge waste waste of screen space and resources. it is also probably what is causing all your problems
Freelance engineer, consultant, contractor. Graduated from UW in 2013.
db4linq
Hi frank26080115
thank for you suggest :)
I already create project at codeplec.com this link http://arduinosketch.codeplex.com/ and fix sume bug for ribbon menu
[size=14]Now open source[/size]
frank26080115
I don't see where you have comment stripping or function collapsing, those are vital to the arduino build process, or else you will be creating a bunch of function prototypes for your if/while/for statements, and also things like atomic blocks
without comment stripping, you'll create prototypes for functions that do not exist, or create duplicates of the prototypes with the wrong parameters, and also include libraries that were not meant to be included.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
