Topic: Imcompatible LiquidCrystal.h & DS1307 librarys (Read 649 times) previous topic - next topic
Baltasar
Nov 19, 2009, 05:53 pm Last Edit: Nov 19, 2009, 08:01 pm by baltasar Reason: 1
Hi, just one problem I'm facing with.
My sketch starts like this:
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h> // OPTION 1
#include <LiquidCrystal.h> // OPTION 2
LiquidCrystal lcd(8, 9, 4, 5, 6, 7); // OPTION 2
My problem is stopping having PWM on pin 3, only works if I either comment option 1 or both 2.
Can anyone confirm that problem? Is there a workaround?
I'm using Arduino Duemilanove + Sparkfun RTC + LCD Keypad Shield from DFROBOT.
Thanks.
Check all my projects based on Atmel/Arduino -> www.aqualed-light.com
Baltasar
Solution for now is using only Wire.h library and not the RTC DS1307.h one and talk to RTC manually like this for example:
 Wire.begin();
 Wire.beginTransmission(DS1307_I2C_ADDRESS);
 Wire.send(0);
 Wire.send(0x00);
But I hope soon anyone can find out a solution for using back the DS1307.h lib as is much easier with the commands.
If anyone wants to see the error/bug I'm talking about, just need to load the FADE example from Arduino IDE, change the led pin var to D3 (pin3) and even not having an LCD shield or RTC load this as I mention on previous post:
#include <Wire.h>
#include <DS1307.h>
You going to realize that the led doesn't do nothing, or my Arduino is totally crazy and is the only one with this behavior...
:o
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
