Topic: Sony IR Remote Library (Read 3362 times) previous topic - next topic
KWaterston
Mar 07, 2010, 09:23 am Last Edit: Mar 07, 2010, 09:24 am by KWaterston Reason: 1
Hi I'm new to the arduino ( got it yesterday :) ) and after blinking a LED and playing with some CdS cells and a servo I got the arduino reading a sony remote.  The code worked great, it was giving me the codes when i pressed buttons on my remote.
Now I wanted to try and learn how to make my own libraries so I thought I would turn this one into a library using the tutorial on the arduino website, problem is I'm stuck.  Any help would be appreciated as I really want to know what I'm doing wrong.
First working code:
Quote
Program that reads key presses of a sony remote control
Created by Kurtis Waterston, March 6 2010
Realesed into the public domain
int irDet = 2;
int key = 0;
int data[12];
int state;
 Serial.begin(9600);                         //For debugging
 pinMode(irDet, INPUT);                      //IR detector connected to digital pin 2
void loop() {                                //Main loop
 if (pulseIn(irDet, LOW) > 2200) {          //Check for start pulse
   getIRkey();
   Serial.print("Key press is = ");
   Serial.println(key);
int getIRkey() {                             //Read pulses
 data[0] = pulseIn(irDet, LOW);
 data[1] = pulseIn(irDet, LOW);
 data[2] = pulseIn(irDet, LOW);
 data[3] = pulseIn(irDet, LOW);
 data[4] = pulseIn(irDet, LOW);
 data[5] = pulseIn(irDet, LOW);
 data[6] = pulseIn(irDet, LOW);
 data[7] = pulseIn(irDet, LOW);
 data[8] = pulseIn(irDet, LOW);
 data[9] = pulseIn(irDet, LOW);
 data[10] = pulseIn(irDet, LOW);
 data[11] = pulseIn(irDet, LOW);
 for(int x = 0; x <= 11; x++) {              //Decide wether pulses are 1's or 0's
   if(data
  • > 1000) {
         data
  • = 1;
       else {
         data
  • = 0;
     int result = 0;                            //Convert array into interger
     int seed = 1;
     for(int i=0;i<11;i++) {
       if(data == 1) {
         result += seed;
       seed = seed * 2;
     key = result;
     return result;
Header file:
Quote
IrRemote.h - A library for Sony tv remote control
Realeased into the public domain
#ifndef IrRemote_h
#define IrRemote_h
#include "WProgram.h"
class IrRemote
public:
 IrRemote(int pin);
 int IrReady();
 int IrKey();
private:
 int _pin;
 int _data[12];
 int _seed;
 int _result;
#endif
CPP file:
Quote
IrRemote.cpp - A library for sony tv remote control
Released into the public domain
#include "IrRemote.h"
IrRemote::IrRemote(int pin)
 pinMode(pin, INPUT);
 _pin = pin;
int IrRemote::IrReady()
 if(pulseIn(_pin, LOW) > 2200) {
   return 1;
 else {
   return 0;
int IrRemote::IrKey()
 _data[0] = pulseIn(_pin, LOW);
     _data[1] = pulseIn(_pin, LOW);
     _data[2] = pulseIn(_pin, LOW);
     _data[3] = pulseIn(_pin, LOW);
     _data[4] = pulseIn(_pin, LOW);
     _data[5] = pulseIn(_pin, LOW);
     _data[6] = pulseIn(_pin, LOW);
     _data[7] = pulseIn(_pin, LOW);
     _data[8] = pulseIn(_pin, LOW);
     _data[9] = pulseIn(_pin, LOW);
     _data[10] = pulseIn(_pin, LOW);
     _data[11] = pulseIn(_pin, LOW);
     if(_data
  • > 1000) {
           _data
  • = 1;
         else {
           _data
  • = 0;
     _result = 0;
     _seed = 1;
       if(_data == 1) {
         _result += _seed;
       _seed = _seed * 2;
     return _result;
New Code using created library:
Quote
#include <IrRemote.h>
int key;
int State = 0;
IrRemote IrDet(2);
 State = IrRemote.IrReady();
 key = IrRemote.IrKey();
 Serial.print("Remote Key = ");
The problem is when I try and verify the new code I get this error:
Quote
In function 'void loop()':
error: expected primary-expression before '.' token
Again any help would be appreciated as I really want to learn how to work with this awesome tool and create more libraries.  Thanks in advance.
Nadir
Hi Curtis,
Use the instance of class in your skecth,
Code: [Select]
State = IrDet.IrReady();
key = IrDet.IrKey();
KWaterston
Thanks a lot Nadir I got it working now, although its still probably not the best way to do things, but that's why I'm still learning  ;D .
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
